silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
PC not charging
by sleepery. 09/20/18 01:53 PM
Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
77 registered members (Ablebody, A310, 69Torino, AMC, alphadog, ABCarr, 12 invisible), 1,362 guests, and 38 spiders.
Topics290,738
Posts4,849,384
Members66,033
Most Online3,590
Jan 24th, 2017
Lower ball joint 09 CRV #4514171
09/12/17 11:09 AM
09/12/17 11:09 AM
PA
Chester11 Offline OP
PA
Anyone ever done a lower ball joint on a 09 CRV?
I have a creak when I turn right at low speed (like into a parking spot).
It looks like an involved job - but all I can find is videos for older models.
Re: Lower ball joint 09 CRV [Re: Chester11] #4514186
09/12/17 11:34 AM
09/12/17 11:34 AM
California
Kool1 Offline
Kool1  Offline
California
I have aftermarket ball joints in my 03 CRV. I had a creaking noise in one of my ball joints at low speed and decided to grease them. I bought a Harbor Freight ball joint tool for $20.00 to pop off the ball joint, I used a needle fitting on my grease gun and greased the ball joint by fitting the needle fitting between the ball joint stud and rubber boot. After greasing the ball joint, the noise is gone and I'm a happy camper.
Re: Lower ball joint 09 CRV [Re: Chester11] #4514191
09/12/17 11:37 AM
09/12/17 11:37 AM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
It looks like that generation CR-V utilizes bolt in ball joints - no need to press in/out. So, in order to replace them, you'll need enough access to remove the fasteners and then remove the ball joint itself. I don't know how much work that entails on that particular model, but it shouldn't be too bad a job, honestly.
Re: Lower ball joint 09 CRV [Re: Chester11] #4514192
09/12/17 11:41 AM
09/12/17 11:41 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Ya, it is a 15 minute job.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Lower ball joint 09 CRV [Re: Chester11] #4514208
09/12/17 12:10 PM
09/12/17 12:10 PM
PA
PA
Thanks! Is this something I can figure out with a Haynes or Chilton manual?
Re: Lower ball joint 09 CRV [Re: Chester11] #4514304
09/12/17 02:39 PM
09/12/17 02:39 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
Oh yes. This is a very generic repair and you can find instructions online, and much better than those mediocre manuals.
But before you launch into it, jack up the front end and test the wheel to diagnose it properly, and check the condition of the tie rod ends and bearings, as well as 1/2 shaft. I would also suspect, based on your description, there's an even chance it's not a ball joint. This can be done very simply by jacking it and supporting it, then manipulating the wheel and components. Check each side. Lots of how-to videos and diy pages out there.
Re: Lower ball joint 09 CRV [Re: Chester11] #4514321
09/12/17 03:11 PM
09/12/17 03:11 PM
Ontario, Canada
Ontario, Canada
Actually more common for the upper strut bearings to be noisy. Lift it up and pinpoint where the noise is coming from.
Mighty Mouse Tech
Re: Lower ball joint 09 CRV [Re: Chester11] #4514340
09/12/17 03:42 PM
09/12/17 03:42 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Re: Lower ball joint 09 CRV [Re: cpayne5] #4514341
09/12/17 03:43 PM
09/12/17 03:43 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Sounds like the ball joints on my 97 civic. Needed to remove the knuckle to remove the ball joint and press a new one in. Eric the car guy had a video on it.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Lower ball joint 09 CRV [Re: JC1] #4514407
09/12/17 05:31 PM
09/12/17 05:31 PM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
No...bolt in vs press in. ^^^
Re: Lower ball joint 09 CRV [Re: Chester11] #4514415
09/12/17 05:44 PM
09/12/17 05:44 PM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
It's a straight forward job. Just mind spring tension from bushings and whatnot
Also: Don't buy moog
2005 Tahoe - 135k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Lower ball joint 09 CRV [Re: Chester11] #4514423
09/12/17 05:52 PM
09/12/17 05:52 PM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
Here's the procedure. Book time for it at the shop is 1 hour for reference
2005 Tahoe - 135k
Re: Lower ball joint 09 CRV [Re: cpayne5] #4514473
09/12/17 06:44 PM
09/12/17 06:44 PM
JC1 Offline
JC1  Offline
[quote=cpayne5]It looks like that generation CR-V utilizes bolt in ball joints - no need to press in/out. So, in order to replace them, you'll need enough access to remove the fasteners and then remove the ball joint itself. I don't know how much work that entails on that particular model, but it shouldn't be too bad a job, honestly.
No...bolt in vs press in. ^^^ [/quote
Thanks. My 98 Sienna was like that.
Re: Lower ball joint 09 CRV [Re: Chester11] #4514501
09/12/17 07:20 PM
09/12/17 07:20 PM
ME
eljefino Offline
eljefino  Offline
ME
Jack both front wheels up or the sway bar will fight ya.
I find the hardest part to be removing little rusted bits of cotter pin from the castle nut. After that's out, finally, a few whacks with the pickle fork, zaps with the impact gun, and she's out!
If the cotter pin gives you too much grief you can just mow it over unscrewing the nut anyway. thumbsup
Re: Lower ball joint 09 CRV [Re: JC1] #4514590
09/12/17 08:35 PM
09/12/17 08:35 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
At least he doesn't weld those in...
Never gonna let him live that down grin
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
