Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
captobvious, pgrkcs, 4Doors4Life, 780Ari, kayumb
66677 Registered Users
100 registered members (bdcardinal, 4WD, AndyB, AZjeff, Alfred_B, 14 invisible), 1,982 guests, and 43 spiders.
Topics295,061
Posts4,927,058
Members66,677
Most Online2,553
Oct 27th, 2018
Pennzoil Platinum Euro L 5W30 VOA #4514082
09/12/17 08:27 AM
09/12/17 08:27 AM
The land of USA-made Subies!
SubieRubyRoo Offline OP
OK guys, thought I'd post the Euro L 5W30 VOA since I had great success with the Euro 0W40 in my Odyssey. This oil went into my 01 Forester with 216k, so I will have a UOA sometime in the future.
First thoughts looking at the VOA, it is kind of a letdown (at least to me) when comparing to the 0W40 on the add pack. I understand this is a C3/SN oil, and the 0W40 is an A3/B4 oil, but at 7.6k UOA, the 0W40 TBN was only 1.0 lower than this VOA. Can somebody chime in on this? I know it's a serviceable oil, but this almost makes me want to just use the 0W40 in the Subaru as well as the Odyssey. I'll put the VOA up first, and my 0W40 UOA up second. VI does look to be impressive at 183, which is slightly higher than the PDS at 174. I'll toss the PDS clip in at the bottom.
For $22.97, it's not a BAD oil, but I think it's just OK. Thoughts on the Euro L 5W30?
VOA:
0W40 UOA:
PDS:
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: SubieRubyRoo] #4514091
09/12/17 08:40 AM
09/12/17 08:40 AM
Great Lakes
Quattro Pete Offline
Great Lakes
Thanks for the VOA.
If your engines don't call for low SAPS oil, then don't use it.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: SubieRubyRoo] #4514095
09/12/17 08:44 AM
09/12/17 08:44 AM
MA
Wolf359 Offline
Wolf359  Offline
MA
Yeah, if you read the spec, Euro L is meant more for diesel engines than gasoline engines. Probably fine for 5k, but not good for 10k. Stick with 0w40 or whatever the recommended oil is for your car. Basically it boils down to don't use a diesel oil in a gasser.
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: SubieRubyRoo] #4514104
09/12/17 08:53 AM
09/12/17 08:53 AM
Chicago, IL
dparm Offline
dparm  Offline
Chicago, IL
I wouldn't pay a premium for it, but it looks fine.
2017 Chevrolet Corvette Grand Sport
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: Quattro Pete] #4514283
09/12/17 01:03 PM
09/12/17 01:03 PM
[/quote]
Does SN still qualify, or is there enough overlap in the API/ACEA ratings that it can still meet SN and low SAPS for ACEA? I mean, technically the Subaru is SJ and the Odyssey is SL, but obviously it's pretty difficult to find anything that would only meet SJ or SL. What would be some good oils for these applications?
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: SubieRubyRoo] #4514306
09/12/17 01:41 PM
09/12/17 01:41 PM
Great Lakes
Great Lakes
Not sure what you mean by "still qualify"? An oil can meet API SN and still be low SAPS, if that's what you're asking.
It really depends on how long of an OCI you want to do.
Historically, US gasoline was not ultra low sulfur, which caused rapid TBN depletion in oil, which meant that low SAPS oils were poorly suited to handle long OCIs in gasoline engines here. Now, things are changing and supposedly US is moving over to ultra low sulfur gasoline, but I don't know where we are at with actual implementation of this, and if/how it varies by region, by state, by gasoline brand, etc.
On the other hand, low SAPS oils are designed to protect modern diesel emissions equipment, which neither one of your cars has, so it's of no benefit to you. They may also provide some benefit in DI engines (questionable), but again, your engines are not DI.
My recommendation for your applications, if you want to run long OCIs, would be to stick with full SAPS oils.
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: SubieRubyRoo] #4514349
09/12/17 02:56 PM
09/12/17 02:56 PM
So, Pete, please humor me. How do I determine a "full-SAPS" oil, and what are some examples of such? Thanks for the info!
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: SubieRubyRoo] #4514353
09/12/17 02:59 PM
09/12/17 02:59 PM
Great Lakes
Great Lakes
Anything that has reasonably high TBN, say above 8, I would consider full SAPS. Anything meeting ACEA A3/B4 spec will have TBN of 10 or higher, because that is what that spec calls for... Castrol 0w-40, Castrol 0w-30, Mobil1 0w-40, Pennzoil Euro 5w-40 or 0w-40, just to name a few.
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: SubieRubyRoo] #4514355
09/12/17 03:00 PM
09/12/17 03:00 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
The Euro L carries the BMW LL-04 rating, that is a low saps rating.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: mightymousetech] #4514366
09/12/17 03:24 PM
09/12/17 03:24 PM
Louisiana
camryrolla Offline
camryrolla  Offline
Louisiana
thanks Subie for posting the lackluster VOA of PP Euro 5w-30.
The PP Euro L 0w-40 is now my go-to oil for extended drain over 10K miles.
'11 Camry 2.5L 160K mi
'07 Corolla 1.8L 220K mi
Always Fram XG filter.
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: camryrolla] #4514375
09/12/17 03:43 PM
09/12/17 03:43 PM
Great Lakes
Great Lakes
It's not lackluster. It's exactly as it was designed, and exactly as required by modern diesel engines.
PP Euro 0w-40 doesn't have 'L' in it. If it did, it would have been a low SAPS oil, just like that 5w-30 that the OP posted. smile
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: SubieRubyRoo] #4514643
09/12/17 08:33 PM
09/12/17 08:33 PM
Thanks Pete. Glad everyone enjoyed the VOA!
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: camryrolla] #4514880
09/13/17 07:06 AM
09/13/17 07:06 AM
Ontario, Canada
Ontario, Canada
There is no such thing as PP Euro L 0W40?
Mighty Mouse Tech
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: SubieRubyRoo] #4514926
09/13/17 08:11 AM
09/13/17 08:11 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
OP, ~ 820 ppm Zinc and TBN of 7 looks about right to me for a 5W30 SN and mid-SAPS C3 oil.
A full SAPS A3 / B4 oil is required to have a TBN > 10 as SA between 1.0 and 1.6 %, typical values would be TBN of ~ 11 and SA of ~ 1.2 %.
A mid SAPS C3 oil is required to have TBN > 6 and SA < 0.8 %. Your results are fairly typical.
For the record, a low SAPS C4 oil is required to have SA < 0.5 %
But most Dexos1 / GF-5 oils have SA of ~ 0.8 % and a TBN of ~ 7.5 so you are very much in the same ball park as most people out there, except your C3 oils has a higher HTHS >= 3.5 cP instead of the usual 3.0 to 3.1 cP for an ILSAC 5W30.
I would run a Euro synthetic C3 oil 5,000 to 7,500 miles.
You could run a Euro Synthetic A3/B4 oil 10,000 to 15,000 miles.
BTW a Euro C3 oil is almost the same as a Dexos2 oil.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Pennzoil Platinum Euro L 5W30 VOA [Re: SubieRubyRoo] #4514993
09/13/17 09:19 AM
09/13/17 09:19 AM
Mightymouse, no, there is no Pennz Platinum Euro L 0W40. It is just Pennz Plat Euro 0W40. The L denotes the lower TBN due to lower SAPS content.
