B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
99 registered members (Bama, 240_Ed, aquariuscsm, AdditiveOCD, 12 invisible), 2,327 guests, and 45 spiders.
Topics296,878
Posts4,960,710
Members66,987
Most Online2,688
Jan 19th, 2019
Safe/Compatible Top-Off Coolant for Toyota Pink? #4509976
09/07/17 12:21 PM
09/07/17 12:21 PM
Alabama
CrackyWainwright Offline OP
Alabama
Vehicle is a 2013 Toyota Tacoma 4.0L with the bright pink long life coolant. Is there a safe and compatible aftermarket coolant that I can use for topping off, or should I just bite the bullet and purchase a gallon from the dealership? Thanks, fellows.
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: CrackyWainwright] #4509981
09/07/17 12:26 PM
09/07/17 12:26 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I believe this is what the guys on here recommend:
http://www.ebay.com/itm/OEM-Concentrate-...291&vxp=mtr
Or Walmart has the nonconcentrated stuff around the same price from Valvoline:
https://www.walmart.com/ip/Valvoline-Asian-Vehicle-Antifreeze-Ready-To-Use-1-Gallon/49660461
I think the dealer charges $33 for a gallon of their nonconcentrated coolant.
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: CrackyWainwright] #4509983
09/07/17 12:31 PM
09/07/17 12:31 PM
MN
ZebRuaj Offline
ZebRuaj  Offline
MN
I've drained and filled with the OEM brand concentrate + distilled water. Not a problem.
I've also topped off with Valvoline Zerex found at auto part stores and Walmart. Not a problem either.
Some folks are OEM dealer fanatics and stick to it and their pricing. No problems with that either.
~Shade tree mechanic for friends and family.
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: SatinSilver] #4509995
09/07/17 12:43 PM
09/07/17 12:43 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
I'd say use what makes you happy, aftermarket or dealer oem. That said, imo no reason to pay more than the two choices listed by SatinSilver. Normally I'd prefer the PB OEM concentrate, but just for a top off Valvoline Asian Vehicle (same as ZAF) at WM readily available, relatively inexpensive (~$12/gal) and convenient use as premix. But either will do nicely.
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: CrackyWainwright] #4510015
09/07/17 12:56 PM
09/07/17 12:56 PM
South Texas
Insertcoolname Offline
South Texas
Toyota pink super long life or equivalent
I'm getting by nicely with my entire cooling system filled with super tech universal 50/50 . This formula satisfies toyota pink requirements. Super long life non silicated ethylene glycol based. And 50/50 premix less than $8 each gallon.
It states on the bottle compatible with other long life coolants and provides the same extended life properties when added to another long life coolant.
https://www.walmart.com/ip/Super-Tech-50-50-Antifreeze-Coolant-Pre-Mix/16928010#read-more
04 Camry 2az-fe 209k
M1 5w30
PremiumGuard filter
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: CrackyWainwright] #4510019
09/07/17 12:58 PM
09/07/17 12:58 PM
Oklahoma
CELICA_XX Offline
CELICA_XX  Offline
Oklahoma
cool truck
why do you need to top off / where are you loosing coolant ?
I would use the OEM 50/50 Pink if it were my truck.
15 Toyota Prius - M1 EP 0w20 SN+
02 Toyota ECHO - Valv MaxLife Full Syn 5w30 SN+
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - Valv MaxLife Full Syn 5w30
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: CrackyWainwright] #4510109
09/07/17 02:29 PM
09/07/17 02:29 PM
WA (USA)
Y_K Offline
Y_K  Offline
WA (USA)
None of the compatible ones list all the ingredients Toyota Pink does. Does it make any difference? I have no clue. I can get the 'compatible' by GC cheaper than any option above, but still pay $21 per gallon to a local dealer. It's not a daily expense in my case. With that being said, I have used Zerex Red equivalent mixed with the SLLC in a pinch from 150k through 180k mile period in a LandCruiser with no ill effects.
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: CrackyWainwright] #4510117
09/07/17 02:37 PM
09/07/17 02:37 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
Toyota Super Long Life Pink
AKA Pentosin Pentofrost A4
Available at most Autozone/AAP for ~$18 to the premixed gallon
Why pay more for a Toyota label, or the same for something incompatible
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: CrackyWainwright] #4510173
09/07/17 03:36 PM
09/07/17 03:36 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Zerex Asian Vehicle Coolant made by Ashland. Same as the high priced Toyota pink. You can get the same coolant at Walmart.
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: CrackyWainwright] #4510180
09/07/17 03:45 PM
09/07/17 03:45 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
I have mixed Toyota pink with Zerex Asian without issues.
1997 Maxima 195k, Castrol GTX Synblend 5W-30, FL400S
2004 Corolla 196k, VWB 5w20 + SSS 10w40, MGL4967
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: CrackyWainwright] #4510236
09/07/17 04:43 PM
09/07/17 04:43 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
As others have suggested, Zerex Asian would work great.
Another option is Pentosin Pentofrost A4
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 268,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 61,000mi
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: CrackyWainwright] #4510251
09/07/17 05:03 PM
09/07/17 05:03 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
I use only Toyota pink in my 4Runner. Lots of desert driving on unimproved roads towing. There may be cheaper substitutes but this is such a small part of the expense of maintaining the vehicle that I'll stick with pink.
The level in the overflow bottle sometimes drops a half inch or so in 10K miles and when it does I top off with distilled water.
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: CrackyWainwright] #4510270
09/07/17 05:27 PM
09/07/17 05:27 PM
WA (USA)
Y_K Offline
Y_K  Offline
WA (USA)
Zerex Asian is the Red equivalent, not the SLLC (Pink), still works fine in practical terms - per Toyota TSB Pink and Red are miscible. Pentosin doesn't list ingredients list in their product information sheet. FWIW.
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: Y_K] #4510592
09/08/17 05:43 AM
09/08/17 05:43 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Quote:
...Zerex Asian is the Red equivalent, not the SLLC (Pink)....
Not in terms of being a 'Long Life' PHOAT it isn't. ZAF/WM Valv Asian Vehicle are Long Life, longer service interval AFs and like the new(er) oems come as a premix. Old Toyota Red concentrate is the older shorter service interval PHOAT (~2yrs/30k) as recommended by Toyota. Toyota says red and SLL are compatible but to get the longer service interval a complete exchange/flush must be done to SLL.
SLL premix is newer longer service interval PHOAT. As is ZAF/(WM VAV) which in addition to coming in red(ish)/pink tint now also comes in blue tint to match Honda Type 2, Subaru and Nissan Long Life AF tint. They are all ~5year/50k mile AFs on subsequent maintenance service. The S in SLL just means it's a longer service interval the old Red (LL).
IMO, the key to compatibility is being the same 'type' AF as vehicle spec'd. With the exception of the WM Super Tech mentioned which is a universal DexClone with 2eha, all those mentioned in this thread are Asian PHOAT AFs. No Asian vehicle recommends or uses 2eha an inhibitor in AF.
If having the Toyota name on the SLL is worth the price premium, that's an individual decision. With all the Long Life Asian PHOATs available now, it isn't for me.
Re: Safe/Compatible Top-Off Coolant for Toyota Pink? [Re: Sayjac] #4510882
09/08/17 12:34 PM
09/08/17 12:34 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Excellent, informative post Sayjac. Thank you!
