I am in the process of replacing my valve cover gasket and plug tube gaskets and i am having a very difficult time getting the old plug tube gaskets off the valve cover...its on a 2003 1.7 liter vtec civic ex. Thanks in advance
I know what you're talking about. The last time I replaced some, I had to use a sharp pick as the tube gaskets were hardened. The tube gaskets came off in hard chunks.
Originally Posted By: HosteenJorje
Take a screwdriver(don't tell anyone) and drive the seals out from the top. Use oil on the new seal to facilitate installation.
Clutch! Got them off, everything buttoned up and good to go, thank you!
