Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
go green or Dexcool?
by umungus1122
06/20/18 04:50 PM
Latest info on ExxonMobil synthetic base stocks
by Gokhan
06/20/18 04:49 PM
Pennzoil Platinum 5w30 - $3.21/qt Amazon
by SnowmanCO
06/20/18 04:37 PM
What Is Dexos Oil?
by mx5miata
06/20/18 04:27 PM
Hail damage means newer vehicle time!
by ZZman
06/20/18 03:39 PM
Trouble with Grease Gun
by tc1446
06/20/18 02:30 PM
Toyota brand conventional (TGMO)
by Jaha24k
06/20/18 01:45 PM
Any synthetic oil rebates currently or soon?
by 07Piloteer
06/20/18 01:32 PM
2018 Hyundai elantra motor oil
by kapama
06/20/18 01:00 PM
SN Plus on shelves
by 03s
06/20/18 12:23 PM
Group 90 Battery - 45 vs 60aH rating
by The Critic
06/20/18 12:19 PM
Ilia, nmac9, Theraven, battleman13, Shassis
65278 Registered Users
106 registered (2009Edge, 01rangerxl, 10WSmuckers, 2002 Maxima SE, 2K2AcuraTL, 379KITTY, 12 invisible), 1232 Guests and 58 Spiders online.
65278 Members
67 Forums
285670 Topics
#4506387 - 09/03/17 03:55 PM Would you throw this flashlight away or not?
skyactiv Offline
Loc: The Midwest
I have a Rayovac Roughneck flashlight that is about 15 years old. It takes 2 AA's and has a reliable push button switch instead of a slider switch. It's made in the USA! It takes the same bulb as a AA cell Maglight. The cheapest bulb I've found is at a Batteries & Bulbs Plus at $3.99 plus tax. The flashlight has always killed batteries off fairly quick, but it takes cheap AA cells.
Would you replace it with a new flashlight that has an LED bulb or simply replace the bulb?
Me: 13' VW GTI 3 door 6 speed manual
#4506390 - 09/03/17 03:57 PM Re: Would you throw this flashlight away or not? [Re: skyactiv]
AirgunSavant Offline
Loc: MD
I'd give it away and not throw it away.
#4506396 - 09/03/17 04:03 PM Re: Would you throw this flashlight away or not? [Re: skyactiv]
FowVay Offline
Loc: Southeastern USA
Never throw in the trash something that is useful to someone else. You can donate it, give it to a neighbor who has nothing, or you can repair it and continue to use it.
Waste not - want not. We've had enough of the cash-for-clunker mentality to last a lifetime. Every person should do their part to conserve.
Quaker State across the board.
#4506397 - 09/03/17 04:05 PM Re: Would you throw this flashlight away or not? [Re: skyactiv]
eljefino Online   content
Loc: ME
My MIL's a nurse and she likes incandescent AA flashlights for checking pupils. Feels it's less harsh than the LEDs.
You can surely find a bulb for that on ebay for 50 cents including shipping from Malaychina.
#4506413 - 09/03/17 04:28 PM Re: Would you throw this flashlight away or not? [Re: skyactiv]
69GTX Offline
Loc: Connecticut
Batteries are expensive. I just use the Walmart $1 mini-flash lights that come with 3 AAA batteries. They last a few months. It's not really cost effective to put new batteries in....cheaper to buy another one for $1.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4506427 - 09/03/17 04:49 PM Re: Would you throw this flashlight away or not? [Re: skyactiv]
kc8adu Offline
Loc: dayton oh
i would bore out the ribs inside that center the aa s and drop in a 18650.
a spacer with a resistor to take up the space.
then plug a 5mm hi cri led into the bulb holder.
may have to drill the reflector hole to accommodate the led.
it will not only be twice the stock brightness but will run a week on a battery.
then you recharge it.
i did one that took a pr bulb and was able to use 3 leds and the resistor in the bulb base.
a friends son used it every night all night at a scout camp and didnt change the battery.
everyone else was chucking 2 d cells a night.
#4506436 - 09/03/17 05:02 PM Re: Would you throw this flashlight away or not? [Re: skyactiv]
oldhp Offline
Loc: USA
^^^^^^^^Hot Rodding a flashlight!!!....I love it!!!!^^^^^^^^^^
#4506460 - 09/03/17 05:27 PM Re: Would you throw this flashlight away or not? [Re: skyactiv]
mattwithcats Offline
Loc: Virginia
Put a small component LED in place of the bulb,
Less power draw, lasts forever.
Done lots of old Maglights this way...
Just remember, led's work one way, turn it around if it does not light...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#4506622 - 09/03/17 07:44 PM Re: Would you throw this flashlight away or not? [Re: skyactiv]
Wolf359 Offline
Loc: MA
I picked up a C8 from aliexpress recently. Has a Cree XP-L V5. It's pretty bright, a little over $16. They're always lying about how bright they really are as I had an XM-L2 U3 before and this is way brighter although they always claim that they're 2000 lumens. A regular 60 watt bulb is about 800 lumens. Anyway, that one is so bright it's almost painful to look at up close. Only does 18650's though.
[link removed - causing page width problems]
Edited by wwillson (09/03/17 08:46 PM)
Edit Reason: remove link
#4507009 - 09/04/17 08:27 AM Re: Would you throw this flashlight away or not? [Re: skyactiv]
kc8adu Offline
Loc: dayton oh
all the cheap chinese makers lie about lumens and mah.
i have a 12000 mah 18650 here that came with a $5 c8.
it struggles to make 1200.
chinese rating means divide by 10.
are you sure its an REAL CREE XP-L?
iirc there are already latticebright clones out there.
Edited by kc8adu (09/04/17 08:29 AM)
#4507430 - 09/04/17 05:45 PM Re: Would you throw this flashlight away or not? [Re: skyactiv]
Donald Offline
Loc: Upstate NY
Get a Pelican LED flashlight.
Saberlight.
Edited by Donald (09/04/17 05:46 PM)
2015 Ford F250 w/Powerstroke
#4507433 - 09/04/17 05:47 PM Re: Would you throw this flashlight away or not? [Re: kc8adu]
Wolf359 Offline
Loc: MA
Not really sure, but it's certainly a little brighter than the XP-L Hi V2 that I got last year. Oh yeah, those 12,000 mah batteries are always pretty funny. I think the only legit ones are in the 2000-3000 mah range. I got a nice set of Odec 2600 Mah ones on Amazon a while back. It was an intro price and now they've got back up again. They can't seem to help themselves and you see 4k, 6k, 8k all the time for 18650's.
#4507701 - 09/04/17 10:42 PM Re: Would you throw this flashlight away or not? [Re: skyactiv]
kc8adu Offline
Loc: dayton oh
highest real capacity is 3500mah.
3600 if you count panasonic 18650g
its a unicorn.
