ACDelco Dexos 0W20 UOA
by DanMiller
Today at 10:44 AM
Mopar window regulator (some assy. rqd.)
by dlundblad
Today at 10:27 AM
5.3L Silverado Water Pump Torque Specs
by Gito
Today at 10:25 AM
Rhino Ramps at Canadian Tire 50% off
by Snagglefoot
Today at 10:18 AM
What to do when your Glock jams
by bigj_16
Today at 10:13 AM
Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
Today at 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
Today at 09:03 AM
Brisket flat on charcoal
by 04SE
Today at 08:45 AM
Weird Oil level question
by audia6
Today at 08:27 AM
DNA test and opening a can of worms
by WhyMe
Today at 08:11 AM
Ghetto testing a wheel speed sensor
by Nayov
Today at 06:23 AM
dash cam
by DAC2018
Today at 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
Today at 01:08 AM
Plastic burning smell when WOT
by Jaha24k
Today at 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
Today at 12:00 AM
Ruger LCP .380
by PW01
Yesterday at 11:24 PM
Launching boat with stick shift
by troutfisher
Yesterday at 11:22 PM
Free oil
by Spitter
Yesterday at 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
Yesterday at 10:04 PM
RC cars
by red7404
Yesterday at 09:36 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
67 registered (93cruiser, AdmdeVilleneuve, andyd, 4WD, ammolab, 11 invisible), 1495 Guests and 62 Spiders online.
65303 Members
67 Forums
285902 Topics
Page 1 of 2 1 2 >
#4506296 - 09/03/17 01:29 PM Do you fog OPE for storage ? What do you use?
andyd Online   content
Loc: Marshfield , MA
Just curious. I tried MMO a few times, only to discover that B+S 3.5 HP flat heads will run on it
Thick oil is better grin2
#4506332 - 09/03/17 02:21 PM Re: Do you fog OPE for storage ? What do you use? [Re: andyd]
motor_oil_madman Offline
Loc: Houston, Texas
This is a waste of time imo
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4506336 - 09/03/17 02:28 PM Re: Do you fog OPE for storage ? What do you use? [Re: andyd]
Spike555 Offline
Loc: West Michigan
Never done it. Never will. I make sure I use E-free fuel, add a stabilizer and run the carb dry before storage.
#4506351 - 09/03/17 02:55 PM Re: Do you fog OPE for storage ? What do you use? [Re: andyd]
Ethan1 Offline
Loc: 'murica
Gather 'round and I'll share with you the secret to winterizing all your power equipment... hide
The secret is... make sure to store it in the corner of the garage so you don't trip over it all winter! I've never been able to find a difference between storing OPE with a full tank of gas, 1/2 tank of gas, running it dry, storing it with the fancy engineered fuel, running it dry on engineered fuel and putting it away, running Stabil through it, filling the tank with a gas/Stabil mix and putting it away, or any other procedure. I never have problems in the spring and I never have to do anything but preventative maintenance. My family's equipment, however, keeps me busy.
#4506386 - 09/03/17 03:54 PM Re: Do you fog OPE for storage ? What do you use? [Re: andyd]
Happy Birthday toneydoc Offline
Loc: War Eagle
Never have and never will. It fires up in the spring
1994 Jeep 158k Mobil 5000 5w30
2014 Camry 32k QS AD 5w30
2018 Jeep Cherokee 1k factory fill
2014 HD Ultra 35k Mobil1 15w50
2012 Rav4 35k PP 5w20
#4506406 - 09/03/17 04:21 PM Re: Do you fog OPE for storage ? What do you use? [Re: andyd]
iahawk Offline
Loc: Iowa
yep, fog the lawnmower, trimmer and snowblowers...have some no name can of fogging oil...seems to have lasted for a number of years, now. Is it necessary?..probably not...do I still do it?..yes.
#4506410 - 09/03/17 04:26 PM Re: Do you fog OPE for storage ? What do you use? [Re: andyd]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
I use Sta-Bil spray fogging oil in my generators, but after 3 or 4 uses it does seam to foul the spark-plug.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#4506438 - 09/03/17 05:09 PM Re: Do you fog OPE for storage ? What do you use? [Re: andyd]
xxch4osxx Offline
Loc: Cedarbrae, Ontario
Never fogged anything I have stored for the winter and never had a problem in the spring.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
#4506548 - 09/03/17 06:58 PM Re: Do you fog OPE for storage ? What do you use? [Re: andyd]
CT8 Offline
Loc: Idaho
I fill the tank and pull the engine over to top dead center to close the valves then push what ever ope out of the way. They start up right away. I have a pressure washer I didn't use for 3 years and after about ten pulls I drained the float bowl and the gas looked like oil when it drained out . After draining the float bowl the engine fired up after about 3 pulls and ran fine that was with the 3 year old gas. Marketing works well.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4506696 - 09/03/17 08:22 PM Re: Do you fog OPE for storage ? What do you use? [Re: Ethan1]
Spike555 Offline
Loc: West Michigan
Tell that to the technician at the lawn mower repair shop, he'll make sure to have a new carb on hand for you. Ethanol will ruin a carb quick from sitting, it will attract moisture from the air and the fuel will break down and you'll need a new carb.
They see it all the time after a power outage, generators that were shoved in the corner of the garage and forgotten about until needed, they won't run.
At the very least install a fuel shut off valve in the fuel line and run the carb dry.
#4507104 - 09/04/17 10:14 AM Re: Do you fog OPE for storage ? What do you use? [Re: Spike555]
Ethan1 Offline
Loc: 'murica
You're purposely comparing apples to oranges. OP asked about outdoor power equipment. Generators are a little different because a certain percentage of people will let them sit for years, not months like a lawnmower. A carb will not be ruined in a few months.
#4508197 - 09/05/17 03:47 PM Re: Do you fog OPE for storage ? What do you use? [Re: andyd]
BrianF Offline
Loc: Sask, Canada
Never have and I dont plan on starting. Never ran into any issue on any OPE with the cylinder rusting. I remember finding this old riding mower in a junk pile some years ago. The fuel tank was rotting away, the metal was rusted through as well. It was ancient and eft in the elements for must be over 20 years by my guess. I turned the flywheel over by hand. It turned and felt smooth.
In all the small and medium engines I ripped apart over the years and there have been lots of barn finds, scrapyard finds, the only cylinder I ever found rust in was the old 440 block that was stripped bare and sat on a shop floor for a few decades.
Just my 2 cents.
2006 Trailblazer LT. Castrol Edge with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. It has oil and still runs
#4509014 - 09/06/17 12:27 PM Re: Do you fog OPE for storage ? What do you use? [Re: andyd]
Kamele0N Offline
Loc: Slovenia
I use a 2stroke oil or a ballistol....
Few squirts into cylinder and then I pull the rope for 2-3 times and its done...
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4509544 - 09/06/17 09:48 PM Re: Do you fog OPE for storage ? What do you use? [Re: andyd]
jeepman3071 Offline
Loc: Storrs, Connecticut
I've never fogged OPE, and I've been working on them for 14 years on the side and never fogged any customer equipment. If I knew it was being stored for a few years I might squirt some Marvel Mystery Oil or Transmission fluid into the cylinder and rotate the engine over.
2000 Jeep Cherokee 4.0L (180k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (32k) - Castrol Edge Euro 0w40, MANN HU816X
#4509605 - 09/06/17 11:23 PM Re: Do you fog OPE for storage ? What do you use? [Re: andyd]
AMC Offline
Loc: South Eastern, CT
I do it for my snow blowers because they only get used about 2 months out of the year.
I use Sta-bil fogging oil because the aerosol makes it convenient. I have heard of people using MMO, WD-40, Motor oil, 2 stroke oil, ATF, Gun lubes and almost anything oily. If I didn't have the Stabil fogging oil, I would probably use 2 stroke oil because it is fairly thick and sticky and should be safe and compatible with the rest of the engine components.
11 Chevy Silverado - PP 5w-30
10 Ford Focus - QSAD 5w-20
14 Yamaha Super Tenere - Delo 15w-40
Page 1 of 2 1 2 >
