New member here ..I recently bought a used 89 ford E350 class c motor home 460 engine with a aftermarket trans filter kit with a temp prob. The filter was so rusty that i could not pull any numbers off it. After tons of searching i was led here and found a list of #s that would fit the base and none would fit that i tried.. Well it turned out i have a 3/4 20 pitch thread . The ph8a would start to screw on but that was it. The filter that i finally found that fit was a napa gold 7134. I'm adding this here in hopes it helps someone else searching for a 3/4 20 pitch thread filter.
Not sure if this is right filter for trans application as it is a engine oil filter but its on there . If anyone knows the correct filter please let me know.
thanks all
thanks all
