Torque Pro app for iPhone?
by Ed_Flecko. 03/23/19 08:18 AM
Sharpening Drill Bits
by ET16. 03/23/19 08:03 AM
more dumb questions!! infiniti Q50
by Robertslowpoke. 03/23/19 06:23 AM
VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
93 registered members (advocate, BeerCan, Audios, alarmguy, 4WD, berlyn, 5 invisible), 1,601 guests, and 56 spiders.
Topics286,273
Posts4,905,725
Members67,589
Most Online2,967
Mar 10th, 2019
Amsoil 5W30 SS, Nissan SR20DET, storage UOA #4504676
09/01/17 05:31 PM
09/01/17 05:31 PM
Canada
Boosted240 Offline OP
Canada
My Nissan 180SX was in storage for just over 2 years on this oil. Filter was a Mobil1 EP. I took it out this summer to give the car a good check up on it's health which included giving it a shakedown on a chassis dyno. I was pleased the 80,000 mile motor from 1994 was making more than factory power with just a aftermarket exhaust and air filter. Compression numbers were all good as well.
I was concerned about fuel dilution due to lots of idling and short trips, so I decided to dump the oil and collected a sample at 200 miles/2 years on the oil. I also pulled the pan and cut the filter. I saw lots of small reflective specs/dust in the residual oil in the pan under the sunlight and about a dozen <1mm flakes in the filter which were not magnetic. After getting my UOA report and seeing the numbers I wonder if this is due to the oil doing a cleanup, along with the shakedown it had on the dyno. I ran the pre- pureplus Pennzoil Plat the oil change before hand for about 800 miles. And before that the car was still in Japan with it's previous owner and I don't know if it was ever run hard.
Those not familiar with the motor, it's a aluminum block, timing chain, journal bearing turbo.
Re: Amsoil 5W30 SS, Nissan SR20DET, storage UOA [Re: Boosted240] #4504876
09/01/17 08:58 PM
09/01/17 08:58 PM
Georgia
DeepFriar Offline
DeepFriar  Offline
Georgia
The SR20 is one of the great engines. It was always much better than it had to be, expensive to build due to its design and doomed by the resulting expense. Even low tech finger followers couldn't tarnish its rep. Too bad Nissan couldn't have wrapped more expensive subsystems, like stronger transmissions, around them. It looks like you have a good example to go forward with.
Re: Amsoil 5W30 SS, Nissan SR20DET, storage UOA [Re: Boosted240] #4504890
09/01/17 09:13 PM
09/01/17 09:13 PM
Canada
Canada
Ah yes, never understood why they didn't use shim over bucket on the SR since it's a rev happy motor. Perhaps because it would put more strain on the chain? I know on the KA24 with the shim over bucket design they use 2 seperate chains tied together by a central sprocket and the top chain is a beefy double wide chain.
