2006 F150 5.4L short trips
by db500
03/20/18 08:13 PM
Where is recent Pennzoil question and answer?
by mbacfp
03/20/18 08:07 PM
Versatrak rear diff groan?
by 55Test
03/20/18 07:58 PM
Sea Doo/Rotax 900 ACE oil capacity only 2 qts!!!
by tomcat27
03/20/18 07:53 PM
Wheel Horse tractor
by HM12460
03/20/18 07:17 PM
Anything wrong with rubber edge guards?
by NoNameJoe
03/20/18 07:05 PM
centric stop tech street
by spasm3
03/20/18 06:58 PM
Mobil 1 0w-40, 10.5k MI, '07 Infiniti G35x 3nd UOA
by cutlassvillager
03/20/18 06:33 PM
CVT Formulation for Multi-Vehicle CVT VOA
by MolaKule
03/20/18 06:03 PM
My predictions
by CourierDriver
03/20/18 05:59 PM
Unclog a drain with a shop vac :-)
by Oldtom
03/20/18 05:04 PM
by Warstud
03/20/18 04:56 PM
SynPower 0w20 - 9,455 miles - CX5 w/ 2.5l
by RamFan
03/20/18 04:29 PM
do you change WIFI name (SSID) a LOT?
by HondaBroMike
03/20/18 04:23 PM
Kendall GT-1 5W-30 FS D1G2 NOACK?
by dailydriver
03/20/18 04:17 PM
Phillips 66 Shield Choice
by JPP
03/20/18 04:01 PM
Thoughts on the STP Extended Life Oil Filters?
by johnnyz73
03/20/18 03:47 PM
200,000 miles extended warranty from Kia and Hyund
by 2008wrx
03/20/18 03:12 PM
Pour Point of Delvac 1 ESP 5W-40
by njohnson
03/20/18 02:54 PM
USS Juneau discovered.
by PimTac
03/20/18 02:37 PM
rockyraj, Viking1313, Greengo, VooDoo_Pistons, TroubledGnom
64511 Registered Users
109 registered (55Test, 93cruiser, 40w8, 92saturnsl2, 11 invisible), 1719 Guests and 100 Spiders online.
64511 Members
68 Forums
280142 Topics
#4502630 - 08/30/17 06:55 PM WIX 1348 age failure?
Jason_Michaels Offline
Loc: Toms River, NJ
Bought a 1987 Toyota 2WD half-ton pickup with 147K on it. 22R carburated. Windshield sticker said last OC was 2/16 15W40 unknown type. I found several holes in the media. I attribute to OCI neglect and the fact that there is evidence the truck sat idle for several years. Very happy with my purchase. No frame rust, recent clutch and brakes and other items. Love tinkering with it and changing all her fluids. I plan on using all Supertech and Smitty fluids when possible, and NAPA silver filters. I changed the diff fluid today with Supertech 80-90 conventional and plan on doing the trans soon with the same. Diff fluid came out very clean, probably changed within the last 30K mi. Oil was Supertech conventional 10W-30 AND 21516 NAPA filter and some MMO for cleaning. Will refill with Supertech conventional 10W-40 and same filter for the winter.
Edited by Jason_Michaels (08/30/17 06:59 PM)
#4502645 - 08/30/17 07:18 PM Re: WIX 1348 age failure? [Re: Jason_Michaels]
FlyNavyP3 Online   content
Loc: Jacksonville, FL
You will absolutely want to refrain from putting in any GL-5 gear oil in your manual transmission. Super Tech or any other brand. The Toyota manual transmission REALLY REALLY needs a GL-4 to shift properly. I personally use Red Line MT-90 but any GL-4 will do. It's much more difficult to find than GL-5 but its absolutely worth it. Nice truck. I have an 86 4x4 and 2 87 4Runner's with the 22R/RE engine.
#4502742 - 08/30/17 08:26 PM Re: WIX 1348 age failure? [Re: Jason_Michaels]
danez_yoda Online   content
Loc: texas
those 22R engines are bulletproof. My dad put 300K miles on his 87 before retiring it to feed and seed duty.
#4502745 - 08/30/17 08:30 PM Re: WIX 1348 age failure? [Re: Jason_Michaels]
earlyre Offline
Loc: Lima, Ohio, USA
that's not a filter age failure... if i'm seeing that right, that filter was made just before Halloween last year.
wix uses a plain date code. so 102716 is... October 27, 2016...
09 Mercury Sable : 6qts VSP 0w20, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts VWB 5w30,WIX 51394
#4502878 - 08/30/17 11:11 PM Re: WIX 1348 age failure? [Re: Jason_Michaels]
Linctex Offline
Loc: Waco, TX
I've never seen one twisted like that........???
#4502901 - 08/30/17 11:58 PM Re: WIX 1348 age failure? [Re: Linctex]
BigJakeChevy Offline
Loc: Alberta
Not sure what caused the element to twist like this but i see it a lot on my ecotec during the winter months. Always wondered if it was due to thick oil at startup. Op is using 15w40 wonder if maybe thats the reason? Sure would like to know what causes this as its very disconcerting when it happens.
2007 Silverado Classic 5.3L
#4502959 - 08/31/17 03:12 AM Re: WIX 1348 age failure? [Re: FlyNavyP3]
Loc: Toms River, NJ
OK thanks Ill wait on the trans. Is the GL5 ok for the diff?
#4503016 - 08/31/17 06:43 AM Re: WIX 1348 age failure? [Re: Jason_Michaels]
Hootbro Offline
That brings back memories. My first brand new vehicle was a 1986 Toyota PU with the 22R also. Great truck and regretted it when I traded it in for then new 1988 Dodge Dakota.
That is a good looking specimen.
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
2016 Nissan Frontier Crew Cab 4.0L (Havoline 5W-30)
2013 Jeep Wrangler JK 3.6L (PUP 5W-30)
#4503022 - 08/31/17 06:57 AM Re: WIX 1348 age failure? [Re: Jason_Michaels]
BigD1 Offline
Loc: NC
Yes GL5 is OK for the rear. I have SuperTech in my 92 rear right now, and it's doing just fine.
GL4 only in the trans! I had to go cheap at the time, so I used Sta-Lube 85W-90 GL4 available at my local NAPA. I bought a gallon on sale for $27. Going to use Redline MT-90 before Winter comes.
I bought a 92 Toyota pickup 2wd with manual 5 speed earlier this year. Keep a check on the coolant level. If it slowly disappears, and it's not running hot, and it's not leaking it is going out the tail pipe. I had to change head gasket, and while I was in there I went ahead, and installed a new timing kit too plus other new parts. Also, installed a new complete cylinder head, because the cost of rebuilding a used head equals cost of new head.
I have that same Wix oil filter waiting to be used. I have been using Motorcraft 910S, and I have not seen any problems with them when I cut them open.
1992 Toyota Pickup--Havoline HM 10W-30--Motorcraft FL-910S
#4503696 - 08/31/17 06:42 PM Re: WIX 1348 age failure? [Re: BigD1]
Loc: Toms River, NJ
Thanks for the help and kind words all. Its gonna be a great cold weather truck.
