Originally Posted By: PandaBear
Personally I think OEM is the right way to go. My stant got stuck closed, and somehow it causes pressure / vacuum problem inside the radiator that end up warping my head, yet the engine temp gauge never move away from the middle until it suddenly reach 3/4 to red. That's just a couple minutes and it was enough to warp my head.
From now on I'd put stat in the OEM only list. I don't even trust STANT for that now.
Your description of the temperature gauge is par for the course for modern cars, where the temp gauge is often not much more than a glorified idiot light.
Specifically, on most modern cars the gauge will creep up to operating temperature and then park mid-range as long as the engine stays within "acceptable" temperatures. Usually, the only time the needle moves past half range is if the car is truly overheating. There are often two positions past center-a "things are getting really hot" position and a "shut the engine down now" position. I had a small issue with an air bubble on a temp sensor in my LS a while back, and it went into "limp home mode" because it thought the engine was at the "dangerous" point.
If you're inclined, you can tap into the ACTUAL temps with an OBD-II reader and see that the temperature does vary and doesn't stay centered like the needle suggests.
