'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
96 registered members (AndyB, 69GTX, anndel, 97f150, Anduril, 14Accent, 3 invisible), 2,106 guests, and 54 spiders.
Topics296,779
Posts4,958,714
Members66,969
Most Online2,577
Jan 14th, 2019
Which iridium plugs for my avalanche? #4496448
08/23/17 07:31 PM
08/23/17 07:31 PM
out there
spasm3 Offline OP
spasm3  Offline OP
out there
2003 avalanche 5.3 used for towing, usually in 3rd not OD.
Looking on rock auto, i see
Denso iridium long life 5090
Denso iridium TT 4713
NGK 1465 laser iridium
NGK 7397 iridium IX
Any experiences with one over the others?
Also what is a good set of coil wires?
Standard Motor Products Blue Streak
or
AC Delco professional?
Thanks
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: Which iridium plugs for my avalanche? [Re: spasm3] #4496452
08/23/17 07:34 PM
08/23/17 07:34 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Originally Posted By: 123
The laser is the best plug the ix the worst, the IX has a single precious metal electrode, the long like a thicker core and the laser has precious metal on both electrodes.
I just asked someone one here about this recently. Since this was via pm I changed their name in the quote above.
Re: Which iridium plugs for my avalanche? [Re: spasm3] #4496478
08/23/17 08:02 PM
08/23/17 08:02 PM
NY
Kage860 Offline
Kage860  Offline
NY
When I did my research for my vehicles I decided to go with the denso iridium long life. Best out of the platinum/iridium ones anyway.
2007 Jeep Liberty PP 0w-20 / Carquest Blue, 6k oci
2015 Nissan Rogue PP 0w-20 / Pronto, 5k oci
Re: Which iridium plugs for my avalanche? [Re: spasm3] #4496527
08/23/17 09:13 PM
08/23/17 09:13 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Laser iridium and Delco OE wires if they are available.
Re: Which iridium plugs for my avalanche? [Re: spasm3] #4496539
08/23/17 09:43 PM
08/23/17 09:43 PM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
You can't do wrong with the top three listed in your post. The Denso iridium LL's are the cheapest dual element spark plugs out there.
I have Denso's newly released Iridium TT's in my 5.3L right now. Can't really tell if it made a difference from the iridiums I pulled out.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: Which iridium plugs for my avalanche? [Re: spasm3] #4496547
08/23/17 10:01 PM
08/23/17 10:01 PM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
I used the Denso 5090 plugs and NAPA Belden wires and they seem to work fine.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Which iridium plugs for my avalanche? [Re: Kibitoshin] #4496579
08/23/17 11:59 PM
08/23/17 11:59 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
The TT's are a good plug. They aren't that new because I installed a set 2 years ago in a little Saturn SC2.
Re: Which iridium plugs for my avalanche? [Re: spasm3] #4496745
08/24/17 07:34 AM
08/24/17 07:34 AM
n.c.
gman2304 Offline
gman2304  Offline
n.c.
I used new OEM Delco plugs in my 2005 5.3 Avalanche last year. The original Delco plugs lasted for over 100,000 miles, so I didn't see a need to switch brands. I reused my old wires which still looked good and haven't had a problem with them so far. The wire boots are a bear to remove from the plugs without damaging the shields. I bought a wire removal tool, and used a can of PBblaster to get mine off. IIRC I had to loosen the PS pump to get the left front plug out. It also helps to be a contortionist for both rear plugs. YMMV.
Re: Which iridium plugs for my avalanche? [Re: gman2304] #4496809
08/24/17 08:24 AM
08/24/17 08:24 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
I would have replaced the wires too. AC Delco replacements are only about $40 on rockauto.
Re: Which iridium plugs for my avalanche? [Re: spasm3] #4496939
08/24/17 11:30 AM
08/24/17 11:30 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
Delcos +1,000
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Which iridium plugs for my avalanche? [Re: spasm3] #4496964
08/24/17 11:59 AM
08/24/17 11:59 AM
California
nthach Offline
nthach  Offline
California
I believe Denso or NGK makes the OEM Delco double-iridium plug, use any of them with confidence. I wouldn't waste time with single-iridium(NGK IX/Denso Iridium Power). GM used to make their own spark plugs, but it seems like Denso/NGK makes the Delco OE series, and Autolite/Federal-Mogul makes their copper and single-platinum/Rapidfire plugs.
OEM wires(Delco OE) are best, I did use the Professional line in a friend's truck and so far, so good.
Re: Which iridium plugs for my avalanche? [Re: spasm3] #4497398
08/24/17 09:59 PM
08/24/17 09:59 PM
The Rockies
Blang Offline
Blang  Offline
The Rockies
I've had good luck with ACDelco Iridium in Vortec V8s and my Ecotec. They're usually a decent deal, and even better you can get manufacture rebates as well right now.
03 Cavalier 239k M1HM 5w30
96 Mazda B2300 207k PennzPlat HM 5w30
11 200 105k PPHM 5w30
01 K1500 4.8 184k M1HM 5w30
Acdelco, Mopar, and MC filters
Re: Which iridium plugs for my avalanche? [Re: spasm3] #4497572
08/25/17 07:24 AM
08/25/17 07:24 AM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
NGK 7397 iridium IX
or
Thanks
NGK Laser Iridium (.6mm wire) and Denso Iridium Long Life (.7mm wire) compete against each other with the iridium tipped center electrode & platinum disc on the ground electrode.
Then Denso TT is the .4mm wire with a platinum alloy cylinder welded to the ground electrode, to reduce quenching of the flame kernel). It tries to balance performance with longevity
the NGK Iridium IX has a .6mm iridium wire with a tapered ground electrode to reduce quenching of the flame kernel. It would have the worst longevity, so if you don't mind replacing spark plugs more often, that's your choice.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Which iridium plugs for my avalanche? [Re: spasm3] #4497677
08/25/17 10:02 AM
08/25/17 10:02 AM
Middle of Iowa
DriveHard Offline
DriveHard  Offline
Middle of Iowa
I run the Denso TT's in my LS chevy.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Which iridium plugs for my avalanche? [Re: spasm3] #4497748
08/25/17 11:37 AM
08/25/17 11:37 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Those NGK hybrids (plat/iridium) are hard to beat, same as OEM. We try to get those out by 100k miles but depending on circumstances we have run them to ridiculous mileages.
The newer 6.0's with VVT seem to be the most fussy yet, they like new plugs at 100k miles or so.
Always change the wires, all you guys moaning about your pickups make sure and do a van some time!!!
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
