Has anyone used either the AC Delco 41-985 or NGK 7164, both iridium, in the 5.3 or similar truck engines? And if so, was there any noticeable difference between either plug and stock?
The stock plug is a platinum NGK 7862, but GM's recommended replacement is the AC iridium. However, the manual and underhood decal spec a .060 gap. The AC plugs are set at .040, with instructions to not re-gap. The NGK's are factory gapped at .060.
Could the new gap recommendation from GM mean that .060 was not optimum for the engine, or would it just be something about the replacement plug's design? If the smaller gap would help this pig's hot-weather ping, I'll use the AC's. I just want to make the right choice the first time, because the plugs are$6-$8 each, and the stock platinums are over $12. I have been using Fuel Power since fall, so maybe that will help the ping when the weather warms up.
Thanks for any input.
