Pennzoil - SN Plus and 0W-16 Q&A
Click here to participate in the Pennzoil Q&A
Pennzoil Pure Plus EU 0W-40 question
by mctmatt
03/17/18 11:15 AM
2016 Chrysler Town and country metal specs in oil
by turboaccord1
03/17/18 10:07 AM
Wood boards as a backup for Rhino ramps—how high?
by paulri
03/17/18 10:01 AM
Anyone cringe when someone drives your car?
by BAJA_05
03/17/18 09:47 AM
Servicing TUFF TORQ K61 & K62
by Gebo
03/17/18 09:33 AM
GE 9x first flight
by tom slick
03/17/18 08:15 AM
What kind of vehicle ramps do you use?
by ZZman
03/17/18 08:01 AM
Storing your new truck?
by Char Baby
03/17/18 06:33 AM
Perfect Stop Ceramic Brake Pads (Copper-Free)
by The Critic
03/17/18 06:07 AM
Flennor parts?
by dlundblad
03/17/18 05:50 AM
Car broken into...
by InvalidUserID
03/17/18 01:22 AM
Changing my oil too infrequently? PCV problem?
by BlakeB
03/16/18 11:50 PM
What is a spongy pedal?
by motor_oil_madman
03/16/18 10:57 PM
Leave it to UVa... .
by bbhero
03/16/18 10:25 PM
great hospital. Wesley
by red7404
03/16/18 10:24 PM
Oil Filter Opinions
by BigJakeChevy
03/16/18 10:15 PM
GM 89021806 ? Gimmick? Alternatives?
by mdocod
03/16/18 09:43 PM
Delco filters original vs. Ecore
by Oily_Thing
03/16/18 09:19 PM
that town again.
by Silk
03/16/18 08:54 PM
To change or not to change?
by dan_erickson
03/16/18 08:42 PM
bumpasmerc, SuperBird4404BBL, Oily_Thing, Altima2, jtwork
64478 Registered Users
88 registered (ammolab, 4WD, Altima2, AITG, 2K2AcuraTL, 2015_PSD, 9 invisible), 1850 Guests and 104 Spiders online.
64478 Members
67 Forums
279933 Topics
#4496411 - 08/23/17 07:50 PM MI-T-M pressure washer
mobilaltima Offline
Loc: Golden Meadow, LA
We bought a new pressure washer at work a month ago, 3000 psi. Works great and the lil Honda knock off engine runs fine. It calls for straight 30 or 10W30. I ran the factory fill for 5 hrs or so, drained it and filled it up with Havoline straight 30 and ran that for another 10 hrs and drained it and it now has Rotella 15W40 which I'll use from here on out at 25 hr intervals. It gets a good bit of use. I called MI-T-M and they said I need to use Straight 30 non detergent pump oil in the pump. I couldnt find any locally so I used some Napa straight 30 non detergent ISO 100 oil. I havent ran it yet it with the Napa oil as I just changed it today. Should it work fine with the Rotella and the Napa 30, or should I switch to a 30 weight for the engine and different oil for the pump?
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
#4496592 - 08/24/17 01:40 AM Re: MI-T-M pressure washer [Re: mobilaltima]
Colt45ws Offline
Loc: Central Washington
Both of those will be fine.
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
#4497254 - 08/24/17 07:27 PM Re: MI-T-M pressure washer [Re: mobilaltima]
Donald Offline
Loc: Upstate NY
I would not change the pump oil so soon. Once every few years would be fine.
2015 Ford F250 w/Powerstroke
