2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
Liqui Moly Special Tec AA 5w20 API SN
by Johnny248. 12/11/18 08:15 PM
Buy a brand new 1966-1977 Ford Bronco
by StevieC. 12/11/18 07:50 PM
ariefnrst, tcoffin014, Schm1d, EagleC, Dinka
66655 Registered Users
89 registered members (beanoil, BeerCan, 53' Stude, aba4430, 2004tdigls, Astro14, 11 invisible), 1,546 guests, and 35 spiders.
Topics294,967
Posts4,925,051
Members66,655
Most Online2,553
Oct 27th, 2018
Degreasing threads #4496349
08/23/17 05:43 PM
08/23/17 05:43 PM
Indiana
VeeDubb Offline OP
VeeDubb  Offline OP
Indiana
I wanted to degrease some threads on my bike before using the torque wrench since the torque specs are for dry threads. I'm curious - what is a safe way to degrease aluminum and steel threads? I thought about using a speed degreaser and then it occurred to me it might be harmful to aluminum. Would rubbing alcohol be okay?
Thanks
Re: Degreasing threads [Re: VeeDubb] #4496359
08/23/17 05:50 PM
08/23/17 05:50 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Yes, I use it to clean threads and many other things when I work on all my stuff.
Re: Degreasing threads [Re: VeeDubb] #4496367
08/23/17 06:01 PM
08/23/17 06:01 PM
Central Coast, Calif.
tom slick Offline
tom slick  Offline
Mineral spirits degrease well and doesn't affect most surfaces.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Degreasing threads [Re: VeeDubb] #4496383
08/23/17 06:18 PM
08/23/17 06:18 PM
USA
ArcticDriver Offline
USA
I have no proof but I don't believe a degreaser is going to damage aluminum threads.
Perhaps a resident metallurgist will chime in.
Multiple Diesel and Gasoline vehicles
Re: Degreasing threads [Re: VeeDubb] #4496391
08/23/17 06:26 PM
08/23/17 06:26 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
Rubbing alcohol or brake cleaner. Be careful about getting the brake cleaner on painted or plastic surfaces. Both of these are volatile and will evaporate with no residue, except for the alcohol leaving a little bit of water behind depending on the purity but usually the common 70% leaves so little water it evaporates as well. I use these two to clean everything, my tools, auto parts, et cetera.
Certain degreasers can cause awful etching/staining of aluminum if left in contact for too long, allowed to dry or directly in the sun. For steel, degreasers can cause hydrogen embrittlement. There are metal-safe degreasers out there like Simple Green Pro HD. If you're going to use degreasers make sure to rinse it well.
http://www.velonews.com/2005/11/bikes-an...le-green-2_9216
I left an aluminum casting for a distributor soaked in Purple Power + water mixture to degrease and it came out stained a dull gray.
2015 Civic LX Coupe
Re: Degreasing threads [Re: VeeDubb] #4496398
08/23/17 06:38 PM
08/23/17 06:38 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Id use brake parts cleaner.
Re: Degreasing threads [Re: VeeDubb] #4496401
08/23/17 06:40 PM
08/23/17 06:40 PM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
we use starting fluid alot at work to clean. seemed odd at first but works well and is mild on painted surfaces.
2013 escape 2.0 awd mobil 1 10w30ep
2008 fusion 2.3 mtx redline 0w20
1996 f150 4.9 2wd mtx mobil 1 10w30hm
1999 kaw zrx 1100 redline 10w40
many husqvarnas
Re: Degreasing threads [Re: tom slick] #4496409
08/23/17 06:49 PM
08/23/17 06:49 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
THIS + TOOTHBRUSH!
Re: Degreasing threads [Re: VeeDubb] #4496428
08/23/17 07:12 PM
08/23/17 07:12 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Isopropyl is what I use to clean basically everything. I keep a 5 gallon can around. In a good spray bottle, it's very good for flushing out contaminants and quickly.
Many common degreasers are harmful to aluminum if left in contact long term - like inside a blind hole or a lap joint. Simple Green stands out as a common degreaser that is harmful to aluminum. It should be diluted for use and flushed heavily with water afterwards. Even then, you may get some streaking on an aluminum part.
"Zed's dead baby, Zed's dead."
Re: Degreasing threads [Re: rooflessVW] #4496440
08/23/17 07:22 PM
08/23/17 07:22 PM
USA
USA
There appears to be two different conversations going on.
The OP asked specifically about aluminum threads and many of the responses have discussed aesthetic issues on aluminum surfaces.
Can someone please tell me how these various degreasers destroy aluminum bolts or threading? Do they cause oxidation? Do they cause brittleness?
I have used Brakleen and PB Blaster for decades on aluminum bolts with no apparent ill effect. I have never later had one of these bolts snap off or show any other signs of fatigue. I would like to know how degreasers destroy an aluminum bolt.
Acids? Yes.
Degreasers? Please explain.
Thanks
Re: Degreasing threads [Re: ArcticDriver] #4496446
08/23/17 07:29 PM
08/23/17 07:29 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Acids? Yes.
Thanks
What do you think streaking or oxidation on aluminum is? It is corrosion. Normally it stops by itself - the oxidized layer acts like a barrier.
Most degreasers are heavy alkaline solutions and will continue to corrode aluminum. Think Simple Green, Purple Power, Grez-off, etc.
Brakleen and PB Blaster are solvent degreasers, PB Blaster has oil in it as well. Much safer for aluminum, and not what came to mind when I posted.
Re: Degreasing threads [Re: NoNameJoe] #4496450
08/23/17 07:32 PM
08/23/17 07:32 PM
USA
USA
I read the link of hydrogen embrittlement on a SRAM chain which was left soaking for 6 months. The concern is the mixture became acidic over that long period of time.
When I read the OP, I did not see that he intended to soak the aluminum bolts for several months.
I don't use Simple Green or Purple Power since a thorough rinse is necessary and that defeats the point of it for cleaning threads IMO. I would use a wire brush and brakleen.
Re: Degreasing threads [Re: VeeDubb] #4496453
08/23/17 07:34 PM
08/23/17 07:34 PM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
Kind & gentle - WD40 to remove grease & Dawn to remove WD40 ...
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: Degreasing threads [Re: rooflessVW] #4496458
08/23/17 07:38 PM
08/23/17 07:38 PM
USA
USA
Acids? Yes.
Thanks
Yes, its corrosion. So you are saying that the threads on the aluminum bolts will corrode right off?
The alkaline degreasers that you mention...how do you stop them from causing corrosion? Rinse them thoroughly with water?
I guess I never considered that someone would not rinse a bolt in water after it was soaked in a Simple Green or purple Power. I used PP once and found it left a noticeable film of the surface of the material I was degreasing even after I rinsed it. That is why I stick with Brakleen. It evaporates quickly and displaces water.
To the OP...I will include a disclaimer that i did not think was necessary. If you are going to use a degreaser such as SG or PP, then don't leave the bolts in there for several months and do be sure to thoroughly rinse the bolt in water when finished.
grin
Re: Degreasing threads [Re: VeeDubb] #4496466
08/23/17 07:46 PM
08/23/17 07:46 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
I'm saying that given enough time and vibration, bad things can happen. With enough time to work, I suspect aluminum threads could come right out with the fastener the next time it is removed.
He asked about cleaning threads but he never said bolts specifically. If would think that cleaning bolt threads would be obvious and wouldn't merit a post, so my mind went cleaning blind holes. Plenty of steel fasteners pull out aluminum threads to begin with - no need to help the process along.
