Originally Posted By: ChrisD46
Do you follow the inside door plaque for OEM vehicle recomended tire pressure - or do you prefer to go a little over by a few pounds ?
Yes, because this is something that's thoroughly tested. The OEMs don't just pull a number out of their [censored]. Being off by 1 or 2 psi is fine, but I wouldn't intentionally over or underinflate -- big safety risk.
Many manufacturers actually have a matrix on those plaques in case you will be running with a full load and/or an alternate snow tire.
