Pennzoil Platinum 5w30 at walmart.com
by Irishman. 12/16/18 11:08 AM
pcv cleaning
by macdole99. 12/16/18 10:39 AM
Solar lights that last all night
by Snagglefoot. 12/16/18 09:20 AM
Things Santa might say......
by ZZman. 12/16/18 08:24 AM
ULTRA-POWER 57082
by ET16. 12/16/18 06:56 AM
No collision totaled vehicle
by madRiver. 12/16/18 06:32 AM
Brightest backup light for my daughters car?
by BobsArmory. 12/16/18 06:26 AM
M1 0W20 EP Good To At Least 10K Miles ?
by ChrisD46. 12/16/18 03:29 AM
Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Cpcz9382, PPWarrior, Robwashere4oil, saleen367, Rickeagle
66696 Registered Users
75 registered members (Anthony, ammolab, Astro_Guy, AP9, 8 invisible), 2,296 guests, and 39 spiders.
Topics295,145
Posts4,928,697
Members66,696
Most Online2,553
Oct 27th, 2018
oil viscosity to protect plastic from rubbing metal #4494959
08/22/17 06:11 AM
08/22/17 06:11 AM
il usa
merconvvv Offline OP
il usa
Will thick oil protect the plastic chain guides from the metal chains better than a thin oil such as say 5w20 ?
A timing chain covered with heavier oil seems like would cause less wear on the plastic guides or anything plastic in contact with the timing chain ???
Any metal on plastic wear studies smile
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: oil viscosity to protect plastic from rubbing metal [Re: merconvvv] #4495001
08/22/17 07:29 AM
08/22/17 07:29 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
I would think lubricity would be a quality independent from viscosity.
Reducing friction seems like the goal...and this can be accomplished in ways that even a thin oil can accommodate.
Re: oil viscosity to protect plastic from rubbing metal [Re: merconvvv] #4495009
08/22/17 07:36 AM
08/22/17 07:36 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
Sounds like a design defect to me.
Re: oil viscosity to protect plastic from rubbing metal [Re: merconvvv] #4495020
08/22/17 07:49 AM
08/22/17 07:49 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Nothing you can do. The TC will eat the guides over time. Some syn oils will soften the polymer and end their life fast. Some will go 200K.
This is what I am a proponent of DRY timing systems on DOHC motors.
I know, I lost a timing system on my BMW M Roadster (vanos) due to improper oil. (according to BMW tech) I bought the car used and didn't have its OC history.
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: oil viscosity to protect plastic from rubbing metal [Re: merconvvv] #4495035
08/22/17 08:16 AM
08/22/17 08:16 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
We do know that 30 viscosity oil is about the ideal viscosity for chains of all sorts. Thinner oils tend not to have the film thickness and therefore the ability to protect the chain against common particulate related wear. We also know that certain engines, such as the Ford Modular engine achieve exceptionally long life on 30 or even 40 viscosity oils. There are multiple reasons for this. However, chain and guide wear are chief among them.
Conversely, we have a wealth of data showing that extended oil change intervals, coupled with ultra thin oils increase chain wear, often requiring replacement inside the warranty period.
Either GM forgot how to make engines or the thin oils and extended drain intervals play a role. Strange that more viscous oil and more frequent changes fix the problem..... AND, not only on the GM and Ford vehicles, but the Prius also.
http://www.equinoxforum.net/31-engine-drivetrain/6533-balancing-chain-service-advisory.html
Re: oil viscosity to protect plastic from rubbing metal [Re: HerrStig] #4495037
08/22/17 08:18 AM
08/22/17 08:18 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Correct, manufacturers who choose to use particular oils need to engineer properly for those oils.
Re: oil viscosity to protect plastic from rubbing metal [Re: merconvvv] #4495050
08/22/17 08:39 AM
08/22/17 08:39 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
If thicker oils promote hydrodynamic lubrication, which I understand they do, and this eliminates contact, which I understand it does, then it wont matter what the non-contacting surfaces are made of. Thicker oil will be better for all materials.
If there is contact then all that tribofilm jazz comes into play, it gets more complicated and the materials become relevent, but you want to avoid that.
Re: oil viscosity to protect plastic from rubbing metal [Re: Cujet] #4495089
08/22/17 09:45 AM
08/22/17 09:45 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
^^^ This is interesting to read. ^^^
Re: oil viscosity to protect plastic from rubbing metal [Re: Linctex] #4495101
08/22/17 10:08 AM
08/22/17 10:08 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
I was going to say, arent there lots in the wild that made very high mileage on 20wt?
I can think of a few delivery trucks in ultra severe service in the Caribbean that are liking 5w-20 havoline in a area where 100k odometer miles is more like 250-300k in the US.
Re: oil viscosity to protect plastic from rubbing metal [Re: ARCOgraphite] #4495164
08/22/17 11:24 AM
08/22/17 11:24 AM
il usa
il usa
Synthetic softening the plastic ?
Re: oil viscosity to protect plastic from rubbing metal [Re: merconvvv] #4495601
08/22/17 08:01 PM
08/22/17 08:01 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I'd guess that the tribofilm jazz is mostly optimised for metal=metal contacting surfaces, though I don't know this for fact.
IF this is true, it suggest that the general superiority of thicker oils in reducing wear will be relatively greater for plastic surfaces, since the backup / second line of defence is likely to be less effective.
Re: oil viscosity to protect plastic from rubbing metal [Re: JHZR2] #4495615
08/22/17 08:16 PM
08/22/17 08:16 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Yes, there are plenty of high mile engines operated on 5W-20. There are fewer ultra high mile engines operated on the thinner oils though. Quite typically, the 500K and up club use a higher viscosity oil. Clearly the Ford Modular engines, many GM engines and certain Toyota engines last a very long time without trouble, on a somewhat higher viscosity synthetic. Consider the Crown Vic and Town Cars with 500K. Nearly all of them use 10W-30 or 10W-40 to achieve that. The ones with 900K miles all use the thicker oil. The 5.4L powered "million mile van" used 10W-40 to achieve 1.3M miles.
