VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
31 registered members (4WD, AurionX2, CB900F2, bubbatime, Burks21, 5 invisible), 610 guests, and 60 spiders.
Topics286,267
Posts4,905,525
Members67,589
Most Online2,967
Mar 10th, 2019
Luqui moly mos2 or not? #4494800
08/21/17 08:46 PM
08/21/17 08:46 PM
La us
Serolim Offline OP
Serolim  Offline OP
La us
I have a 5.7 Vortex engine with a small leak from rear main seal, and maybe back of oil pan, or perhaps just one. It's maybe half a quart per my 5k mile oil change.
I use PUP 10w30, and I'm very strict with my vehicles, they only use the same oil that I decide on never swap brands due to not liking to mix oil ( regardless if it's harmful or not ) which leads to the question, is it okay to mix it with a G2L oil? I'd normally repair the seals properly but as of lately I work 100+ hrs weekly. And I do all my own work, so a shop touching it is out of the question since it's restored and highly modded both Engine and trans, heck even have a coolant filtering kit on it.
I've read many postings on this site giving it good rating, but not one particular to my concern.
First post, long time reader for many years.
Re: Luqui moly mos2 or not? [Re: Serolim] #4494806
08/21/17 08:50 PM
08/21/17 08:50 PM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
I'm not a big fan of using over the counter additives in the crankcase. Been there done that on most products (except this one).
Why not try Pennzoil Platinum HM?
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: Luqui moly mos2 or not? [Re: Serolim] #4494807
08/21/17 08:52 PM
08/21/17 08:52 PM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
I assume you're talking about Liqui Moly Motor Oil Saver. I've used it in my Alfa, which is a chronic oil leaker. So far it's been less than 400 miles but I believe it IS closing up some of the leaks. I believe the reputation of the product is pretty good, but time will tell.
2017 Honda Odyssey SE, 18K
2013 Honda Accord LX, 59K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Luqui moly mos2 or not? [Re: Serolim] #4494809
08/21/17 08:54 PM
08/21/17 08:54 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I'm not sure what you're asking. Is it a leak you're trying to stop? If it's a leak their Motor Oil Saver is a better suited product for leaks than MOS2.
God Bless Our Troops
Re: Luqui moly mos2 or not? [Re: Serolim] #4494814
08/21/17 09:01 PM
08/21/17 09:01 PM
South Oz, Australia
ozdrrider Offline
ozdrrider  Offline
South Oz, Australia
Leave it until you have time to fix it, they way you know how.
Your pan maybe a bit loose, it might just need a re-torque. No additive will fix a loose pan.
15 Pajero 3.2 Penrite 10w40 full syn 50K km
06 Suzuki Swift Sport 1.6L 5w30 Nulon full syn
17 Suzuki DR650: Trialing LUBEALLOY LA 35 ES
83 350 Chev powered Ski Boat: Nulon 15w40
Re: Luqui moly mos2 or not? [Re: Serolim] #4494816
08/21/17 09:04 PM
08/21/17 09:04 PM
La us
Serolim Offline OP
Serolim  Offline OP
La us
Yes, my mistake the oil saver. And yes I hate using oil additives, but this one peaked an interest.
And I did one 5k miles with platinum high mileage, no change same loss.
Re: Luqui moly mos2 or not? [Re: ozdrrider] #4494818
08/21/17 09:05 PM
08/21/17 09:05 PM
La us
Serolim Offline OP
Serolim  Offline OP
La us
Yes I've tightened the pan to be sure it wasn't loose.
Re: Luqui moly mos2 or not? [Re: Serolim] #4494934
08/22/17 05:11 AM
08/22/17 05:11 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
AT205 Reseal
And quit with the synthetic until you have time to do those seals. The syn can get out more easily.
Re: Luqui moly mos2 or not? [Re: Serolim] #4494948
08/22/17 06:30 AM
08/22/17 06:30 AM
Kuwait
Falcon_LS Offline
Falcon_LS  Offline
Kuwait
Motor Oil Saver is what you want, which is an ester based product. One can is sufficient for 5L (5.3 quarts) of oil, you may wish to purchase a second can to make sure you have enough for your 6 quart (IIRC) sump. Give it ~500 miles to do its job.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
03 Expedition SSV: XG2
05 Envoy: XG9837
06 XJ8L: C2C41611
07 SRX: XG8765
Re: Luqui moly mos2 or not? [Re: Serolim] #4495014
08/22/17 08:40 AM
08/22/17 08:40 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Dump the full syn ( at next OCI) and try Pennzoil bronze bottle - NOT gold bottle. Its a great oil.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Luqui moly mos2 or not? [Re: Serolim] #4495032
08/22/17 09:11 AM
08/22/17 09:11 AM
St. Catharines Ontario Canada
03s Offline
03s  Offline
I was down about 1/4 liter topped it up with Lucas Engine Oil Stop Leak 2 weeks ago and no oil loss since then. Besides stopping leaks it is an additive for worn and older engines, reducing engine noise and oil consumption while raising oil pressure.
2005 Chevrolet Optra
Canadian Tire MotoMaster F1 Premium Synthetic / F1 High Mileage 5w-30
Mobil 1 m1-101
Re: Luqui moly mos2 or not? [Re: 03s] #4495128
08/22/17 11:35 AM
08/22/17 11:35 AM
La us
Serolim Offline OP
Serolim  Offline OP
La us
Lucas black stone labs tests show it's very little more than base stock more so just a thickener, I have 80 cold and 60 oil pressure hot on syn 10w30.And although it's a old engine design it's not old, it's restored, with advancements that we have today.
Re: Luqui moly mos2 or not? [Re: ARCOgraphite] #4496020
08/23/17 10:41 AM
08/23/17 10:41 AM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
Although I agree whole hearted (+1) bronze bottle doesn't exist anymore smile.
It's YBRC - Yellow Bottle Red Cap
Re: Luqui moly mos2 or not? [Re: Serolim] #4498334
08/26/17 05:04 AM
08/26/17 05:04 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
LiquiMoly MOS2 is a fantastic product, significant reduction in friction which means more mpg&bhp.
It is NOT a substitute for replacing a failed gasket. Only REPLACING the failed gasket will stop the leak.
Cable ties should hold it
Re: Luqui moly mos2 or not? [Re: DoubleWasp] #4505700
09/02/17 06:35 PM
09/02/17 06:35 PM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
Originally Posted By: DoubleWasp
AT205 Reseal
I have used AT-205 as well with great results.
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
