Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
31 registered members (c502cid, carlprop, bbhero, Brad_C, Black_Thunder, 3 invisible), 787 guests, and 65 spiders.
Topics286,170
Posts4,903,522
Members67,572
Most Online2,967
Mar 10th, 2019
6.7 Powerstoke Upper Oil Pan Gasket Replacement #4492951
08/19/17 04:03 PM
08/19/17 04:03 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
I am unfortunately having my Upper Oil Pan Gasket replaced, which entails having the transmission taken out. Aside from being uneasy about the whole thing, once I get the truck back with new oil and filter should I do a short OCI run to remove any possible contaminates left in the oil from the job. Appreciate the advice.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: 6.7 Powerstoke Upper Oil Pan Gasket Replacement [Re: mbacfp] #4492961
08/19/17 04:16 PM
08/19/17 04:16 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
The book does not say you have to, but that being said I would sleep better at night if I was having that repair done. Not sure if you are interested but Mag Hytec makes a lower pan for the 6.7 that looks pretty sweet.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 6.7 Powerstoke Upper Oil Pan Gasket Replacement [Re: mbacfp] #4492979
08/19/17 04:33 PM
08/19/17 04:33 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Thanks Bdcardinal. I appreciate your input on all of this. Only good thing is this is being done under warranty. Will look into the lower pan. Anybody have any suggestions on short OCI...change at 500 miles, 1,000 after repair? Hope everyone is well.
Re: 6.7 Powerstoke Upper Oil Pan Gasket Replacement [Re: mbacfp] #4492997
08/19/17 04:48 PM
08/19/17 04:48 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Not sure how many miles you put on that beast. I have always done it on cars so I do the shorts OCI a week or so later.
Off Topic, one of my best friends has his 6.0 in for new heads. Normally I would look up everything on a 6.0 no problem but since it is a friends truck I have been second guessing everything. His already had studs and an EGR delete, just a random gasket failure.
Re: 6.7 Powerstoke Upper Oil Pan Gasket Replacement [Re: mbacfp] #4493004
08/19/17 04:57 PM
08/19/17 04:57 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
I really appreciate everything. Thanks for your time. Only have 19,000. Don't put too many miles on it in the off season (as is a motorhome). Will probably drive it home 90 miles and let it sit to make sure leak is fixed...then drive again and dump oil and filter.
Re: 6.7 Powerstoke Upper Oil Pan Gasket Replacement [Re: mbacfp] #4493007
08/19/17 05:03 PM
08/19/17 05:03 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Also, perhaps I am being crazy...should I get an oil analysis on that new oil to determine any level of contaminants for warranty and my sanity. I have no reservations about the Ford shop (fyi)...just curious if that is smart after any major work.
Re: 6.7 Powerstoke Upper Oil Pan Gasket Replacement [Re: mbacfp] #4493037
08/19/17 05:37 PM
08/19/17 05:37 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
If you want, go ahead and do a UOA. I should probably do one at some point on my Mustang as I will be at 30K miles in the next week or so.
Re: 6.7 Powerstoke Upper Oil Pan Gasket Replacement [Re: mbacfp] #4493172
08/19/17 07:53 PM
08/19/17 07:53 PM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
I would think that what ever contaminates are present would be picked up and held by the filter in any oil change index.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: 6.7 Powerstoke Upper Oil Pan Gasket Replacement [Re: mbacfp] #4493385
08/20/17 07:04 AM
08/20/17 07:04 AM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
I understand your concern, but if the dealer puts in new oil and filter, I wouldn't hesitate to run the oil for your normal interval. I've been in your shoes several times with my big trucks. Sometimes it's having the valve cover off for valve adjustment and other times having the pan off for a new oil level sensor on a Volvo. Unless the oil is about due for a change, I just leave the same oil in and finish the oci. There's an increase of silicon in the UOA but nothing to worry about.
As long as you don't have enemies in the dealer garage, I wouldn't worry. If you're having trouble sleeping over it, then I understand if you change the oil afterwards. At least consider running the oil for a while and draw a sample to see if there's an issue first. That's much less expensive than the oil/filter change.
2013 F150 XLT 5.0 4X4 104k miles
Edge 5W-30 / Fram 10575
Re: 6.7 Powerstoke Upper Oil Pan Gasket Replacement [Re: dustyroads] #4493421
08/20/17 07:53 AM
08/20/17 07:53 AM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Thanks Dustyroads. I feel a lot better about everything. Thanks to everyone for the help. I will certainly give everyone an update once all is complete.
