I recently replaced all the low pressure rubber return lines on my Nissan's power steering system. They specify Dexron for the PS system, so I refilled the system using Mobil D/M and bleed according to the procedure in the FSM. As I bleed the system I continue to monitor the reservoir for bubbles, but I cannot seem to get rid of these tiny "soda" like bubbles. The pump is not making any noise and the power steering seems to be working fine. I let the car sit overnight, in the morning the reservoir showed no signs of bubbles, but after starting the engine and running for a minute, the soda-like bubbles reappear. It's the same consistent amount of bubbles no longer how long I let it run for. While some bubbles recycle back down the supply/suction line, a fraction of them rise to the surface and go away, which makes me think there is air being constantly sucked in somewhere?
Not sure if this is normal(never really paid attention to it in the past) or could it be a o-ring the pump's suction inlet? The reservoir is higher than the pump and is fed down via a 5/8" hose which is brand new as well. No fluid leaks anywhere on the PS system.
Thanks all!
Video below
Thanks all!
Video below
