WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
27 registered members (chance, Anduril, DirtyOilGuy, dishdude, 4 invisible), 761 guests, and 32 spiders.
Topics290,810
Posts4,850,740
Members66,036
Most Online3,590
Jan 24th, 2017
Anyone do UOAs with different oils #4489063
08/15/17 08:54 AM
08/15/17 08:54 AM
Texas
AnarchyX Offline OP
AnarchyX  Offline OP
Texas
Just wondering is anyone has done UOAs of different oils on the same vehicle. And if so, were the results significantly different?
I think it would be interesting to see what a Super Tech and Pennzoil UOAs look like in the same vehicle, if for anything but to see how the engine treats each oil.
Re: Anyone do UOAs with different oils [Re: AnarchyX] #4489067
08/15/17 08:58 AM
08/15/17 08:58 AM
SE Texas
2015_PSD Offline
2015_PSD  Offline
SE Texas
Here are a few:
2010 Ford F-150 FX4 UOAs
2018 MB AMG GLC43 3.0L Coupe - Castrol 0W-40/Purflux
2018 MB C300 2.0L - M1 0W-40/OEM
2015 F-250 6.7L PS Diesel - Delo 15W-40/CQ Blue
2014 Explorer 3.5L Limited - M1 AFE 0W-20/FU
Re: Anyone do UOAs with different oils [Re: 2015_PSD] #4489075
08/15/17 09:07 AM
08/15/17 09:07 AM
Texas
AnarchyX Offline OP
AnarchyX  Offline OP
Texas
Originally Posted By: 2015_PSD
Here are a few:
Thanks!
Looks like Pennzoil and Mobil synthetics were pretty similar in their numbers.
What's interesting is that Mobil 5000 had similar numbers to Motorcraft Semi-synthetic. Why would that be is Mobil 5000 has no synthetic oil in it?
Re: Anyone do UOAs with different oils [Re: AnarchyX] #4489084
08/15/17 09:15 AM
08/15/17 09:15 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Here are a few:
Thanks!
Blackstone's cheap UOAs can not tell the difference between synthetic and dino oil.
2007 Ford Fusion 232,000 miles
M1 0-20 EP
2017 Ford Fusion 55K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Anyone do UOAs with different oils [Re: tig1] #4489085
08/15/17 09:16 AM
08/15/17 09:16 AM
Texas
AnarchyX Offline OP
AnarchyX  Offline OP
Texas
Here are a few:
Thanks!
Is there someone else that does UOAs? Are they "better" than Blackstone?
Re: Anyone do UOAs with different oils [Re: AnarchyX] #4489089
08/15/17 09:21 AM
08/15/17 09:21 AM
Texas (south)
FermeLaPorte Offline
Texas (south)
Seems like Blackstone are the ones that offer more bang for the buck. I bet if you one dig around, one could find some that are really good.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Anyone do UOAs with different oils [Re: AnarchyX] #4489111
08/15/17 09:56 AM
08/15/17 09:56 AM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
Here are a few:
Thanks!
Maybe it is the other way around?
Re: Anyone do UOAs with different oils [Re: AnarchyX] #4489118
08/15/17 10:12 AM
08/15/17 10:12 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
In my '04 Jeep Grand Cherokee, 4.0, tested ST Syn, M1, VWB and Amsoil at 5000 miles. I no longer have the UOAs but all wear metals were within 1ppm for all four oils, except the M1 which showed about twice the iron as the other oils. (This is well documented in the 4.0)
Would not hesitate to run any of them that distance.
Did not do a test with Pennzoil.
Thick vs Thin test: 15k / 43k miles complete
Re: Anyone do UOAs with different oils [Re: AnarchyX] #4489122
08/15/17 10:18 AM
08/15/17 10:18 AM
USA
Reddy45 Offline
Reddy45  Offline
USA
Are we talking about wear metal numbers being different between oils? A good candidate for that type of testing would be someone who does a lot of interstate driving as that would make for a somewhat consistent set of operating conditions.
But if SuperTech conventional results in 15ppm iron and Amsoil synthetic results in 11ppm iron, is it worth the extra cost to save 4ppm? (Which could be noise or lab error?)
I think the best use of UOAs I've seen to date is on HD earth moving equipment where detecting early signs of component failure can save hundreds of thousands of dollars.
Re: Anyone do UOAs with different oils [Re: tig1] #4489132
08/15/17 10:33 AM
08/15/17 10:33 AM
SE Texas
2015_PSD Offline
2015_PSD  Offline
SE Texas
Here are a few: 2010 Ford F-150 FX4 UOAs
Thanks! Looks like Pennzoil and Mobil synthetics were pretty similar in their numbers. What's interesting is that Mobil 5000 had similar numbers to Motorcraft Semi-synthetic. Why would that be is Mobil 5000 has no synthetic oil in it?
To bring things back into context--the engine could not either and that was the whole point of my experiment.
AnarchyX - not sure what you are trying to learn, but modern conventional oils are not those from yesteryear. You can see that I took MS5K out on an OCI much further than many on this site run synthetic and yet the wear metals were nearly the same. Also, for your benefit my FX4 was not a cream puff, it saw regular towing in varying climates and conditions. You also have to remember that UOAs only measure certain sized particles and therefore you cannot really use them to determine wear rates. Particle counts can help with that to a small degree as does trending as I did on the full life of the truck (I traded it at 158K, but the spreadsheet is every UOA performed on every fluid change).
Re: Anyone do UOAs with different oils [Re: AnarchyX] #4489137
08/15/17 10:38 AM
08/15/17 10:38 AM
Great Lakes
Quattro Pete Offline
Great Lakes
Here are a few:
Thanks!
Sure, but are you willing to spend hundreds if not thousands of dollars just to confirm if an oil contains synthetic or not?
Also, how do you define synthetic?
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (FF)
Re: Anyone do UOAs with different oils [Re: 2015_PSD] #4489139
08/15/17 10:38 AM
08/15/17 10:38 AM
Texas
4WD Offline
4WD  Offline
Texas
Know of a GM 5.3L going 400k on Mobil Super bulk - and the entry level filter from the cheapest change.
Re: Anyone do UOAs with different oils [Re: 2015_PSD] #4489141
08/15/17 10:40 AM
08/15/17 10:40 AM
Texas
AnarchyX Offline OP
AnarchyX  Offline OP
Texas
I was just trying to learn if engines actually are affected differently if different oils are used in them, and if they wear down different oils based on what they're made of. And if there was a significant amount of difference in comparison.
Re: Anyone do UOAs with different oils [Re: AnarchyX] #4489144
08/15/17 10:43 AM
08/15/17 10:43 AM
Great Lakes
Great Lakes
Just FYI, a $30 UOA's primary purpose is to see if thee are any issues with the engine, and that is best understood by trending analysis over time. Its purpose is not to compare oils.
Re: Anyone do UOAs with different oils [Re: AnarchyX] #4489167
08/15/17 11:06 AM
08/15/17 11:06 AM
SE Texas
2015_PSD Offline
2015_PSD  Offline
SE Texas
These days, I do not think you are going to find a vast difference in any of the major branded oils. Pick one and run it or pick several and run them--your engine will not care.
