List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
2017 Hyundai Tucson burning oil (Help!)
by carviewsonic. 09/23/18 11:09 AM
Never waxed ???
by SilverGt. 09/23/18 10:55 AM
Plumbing drain question
by wormwood1978. 09/23/18 10:38 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
91 registered members (55hambone, alchargo, Bman90, 53' Stude, Al, bobbobtar, 10 invisible), 1,794 guests, and 40 spiders.
Topics290,898
Posts4,852,112
Members66,047
Most Online3,590
Jan 24th, 2017
Honda Accord P1009 #4488940
08/15/17 05:48 AM
08/15/17 05:48 AM
NY
greasegunn Offline OP
NY
My 4 cylinder Honda Accord with 98.000 miles is throwing the following codes:
VTC Advance Malfunction P1009
Misfires - P0301, P0302, P0303, P0300
A bit of research shows that the VTC strainer and VTC oil control valve can be problematic on these vehicles. Oil level is fine and the oil is in good shape. Typically run PP 0W20/Fram Ultra and change based on the OLM (about 5,000-6,000 mi). The job doesnít look to bad but Iím wondering since I will have to take everything apart to test the components that I might as well replace them too. What do you think? This may save me a repeat effort down the road. Is the VTC valve an OEM part or is an aftermarket part suitable in this application? Now suppose the VTC system checks out OK - what else could be causing so many misfire codes to come up all at once. Once again thanks for all your help.
Re: Honda Accord P1009 [Re: greasegunn] #4488942
08/15/17 05:56 AM
08/15/17 05:56 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
With those codes the valve is almost guaranteed shot. Bench testing the valve is a fools errand in my experience, it works fine cold and test good its when it gets hot after about 10 min it breaks down.
Re: Honda Accord P1009 [Re: greasegunn] #4488999
08/15/17 07:29 AM
08/15/17 07:29 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
What is the year of this Honda Accord ?
Re: Honda Accord P1009 [Re: greasegunn] #4489008
08/15/17 07:39 AM
08/15/17 07:39 AM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
If you have the coin to spare, I recommend changing the valve with a OEM one.
My son's Accord had the same problem at just a little over 100K miles. We cleaned it and got maybe another 20K miles before the code came back. Replaced it with a new OEM valve and was still running strong another 80K+ miles when he eventually sold it.
2018 RAM 2500 Cummins 6.7L (Factory Fill 5W-40)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
Re: Honda Accord P1009 [Re: greasegunn] #4489054
08/15/17 08:42 AM
08/15/17 08:42 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Usually just the strainer that gets clogged, isnt it?
The reason for Subaru high bypass spec on filters as the banjo fitting contained strainers that clogged.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Honda Accord P1009 [Re: Merkava_4] #4489116
08/15/17 10:12 AM
08/15/17 10:12 AM
NY
NY
2008 with PZEV
Re: Honda Accord P1009 [Re: Hootbro] #4489129
08/15/17 10:26 AM
08/15/17 10:26 AM
NY
NY
Thanks for the feedback. I'm strongly leaning towards the Honda part. There are two part numbers and I'm trying to figure out if there is actually any difference between the two for my application.
Re: Honda Accord P1009 [Re: greasegunn] #4490105
08/16/17 11:53 AM
08/16/17 11:53 AM
NY
NY
Did you run into any unexpected problems when you replaced the valve?
Re: Honda Accord P1009 [Re: greasegunn] #4490122
08/16/17 12:05 PM
08/16/17 12:05 PM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
No problems per-say, just getting access was bit of a pain as we had to move the power steering pump out of the way.
Re: Honda Accord P1009 [Re: Hootbro] #4490413
08/16/17 06:12 PM
08/16/17 06:12 PM
NY
NY
Thanks. After looking at this job it looks like there is more work involved in getting to the part than in the actual removal and replacement of it.
