Civic @ 172,000 on Mobil Oil
Scruffy City
See: Civic @ 100,000 for 72,000 miles ago.
Was time for a major service. Had a slight leak into spark plug tube #1 so I figured I’d go ahead and check the valves while I was in there. (all fine)
Oil changed (0/20AP and a genuine 20,000 Ultra)
Transmission flushed (4 drain and fills per Honda Service news procedure DW1)
Coolant changed (Honda Type 2)
PS fluid changed (Honda PSF)
Tires ordered. (Premier A/S)
She looks simply marvelous - really good job right there ...
Originally Posted By: Linctex
DuckRyder, still 7500 mile OCI's?
I’ve been stretching them closer to 10,000 and either running a Honda filter for one OCI or a Ultra for two.
Originally Posted By: aquariuscsm
... Have you always used Mobil 1 0W20?
From about 30,000 on it has been M1 5/20 (mostly) or 0/20 with only a couple of exceptions (5/30). For the first 30,000 it was Mobil Clean 5000 5/20 (which was a blend IIRC) and either a Honda or Purolator filter.
Very clean. I'd give anything to see those piston ringlands.
What do you use to clean the outside of the engine? Simple Green or something?
Originally Posted By: oil_film_movies
... What do you use to clean the outside of the engine? Simple Green or something?
I don’t clean it very often, but either simple green HD (the aluminum safe purple stuff) or gunk foamy. Then I wipe the plastic down with Honda spray cleaner.
Have you noticed any difference in engine performance in 0W20 vs 5W20 vs 5W30?
No. The car was originally speced for 5/20, was back speced to 0/20 and of course earlier models were speced for 5/30. The car doesn’t seem to care, but I think I will stick with what is recommended by Honda.
Just out of curiosity, did they ever give a reason for the back spec?
