Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
35 registered members (Aero540T, 69Torino, 2strokeNorthstar, 4WD, 1WildPig, Anduril, 1 invisible), 1,049 guests, and 38 spiders.
Topics295,135
Posts4,928,342
Members66,691
Most Online2,553
Oct 27th, 2018
2009 Ford Edge LED? #4484548
08/10/17 09:32 AM
08/10/17 09:32 AM
Texas
2009Edge Offline OP
2009Edge  Offline OP
Texas
I have a 2009 Edge with 3 wire rear brake/signal/tail light sockets.
I am trying to replace the factory bulbs with LED's.
I am wearing out the wiring trying to installing the resistors across the proper wires.
What is the right/proper way to connect the resistors?
I have 50W 6RJ resistors, installed in line with the flash wire on the front and back.
When I turn the key to ACC the blink is normal.
The blink goes to rapid flash when the engine is running.
HELP!
Re: 2009 Ford Edge LED? [Re: 2009Edge] #4484592
08/10/17 10:21 AM
08/10/17 10:21 AM
Richmond, BC, Canada
mechjames Offline
mechjames  Offline
Don't bother with resistors, and just buy Canbus Compatible Leds. This will keep bulb burnt out messages/indicators from coming on if you have them. If not, then don't worry about it at all.
For your hyperflash, do you have a mechanical flasher relay? Rockauto says you do. Tridon sells an EP27 electronic LED flasher relay that should cure your hyperflash.
https://www.rockauto.com/en/catalog/ford,2009,edge,3.5l+v6,1443379,electrical,flasher,10139
86 Mustang 5.0L 170km - Amsoil XL 5w30 / Baldwin B2-HPG
14 Ram 1500 5.7 - Amsoil XL 5w20 / Baldwin B7443
98 Jeep ZJ 5.9 - Amsoil OE 10w30 / Baldwin B34
Re: 2009 Ford Edge LED? [Re: 2009Edge] #4484595
08/10/17 10:28 AM
08/10/17 10:28 AM
Texas
2009Edge Offline OP
2009Edge  Offline OP
Texas
I bought Canbus and they came with resistors. Front works except for the hyper flash.
Rear ones do not provide tail/clearance lights.
Turn signal and brakes work fine except for hyper flash.
I do not have a mechanical flasher.
Re: 2009 Ford Edge LED? [Re: 2009Edge] #4491368
08/17/17 06:32 PM
08/17/17 06:32 PM
Texas
2009Edge Offline OP
2009Edge  Offline OP
Texas
I finally installed mine according to the following: And they work GREAT.
The 6-ohm 50W resistor needs to be installed between the power wire and ground. The power wire is the one for the turn signals - it is unnecessary for running lights. The ground can be any chassis ground or the ground wire from the lamp socket. The resistors do not go inline in any wire. They connect to the wire using a ScotchLock or similar connector that leaves the original wire intact and allows the resistor to "tap into" it (electrically, the resistor is in parallel with the bulb). In other words, do not cut any factory wire to install resistors.
You will generally need a resistor for each location where you install an LED bulb in place of an incandescent bulb in the turn signals (i.e. both sides front and rear if you replace all bulbs).
