Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
113 registered members (Astro14, bbhero, Ablebody, 2010Civic, anndel, 12 invisible), 1,708 guests, and 41 spiders.
Topics290,904
Posts4,852,218
Members66,047
Most Online3,590
Jan 24th, 2017
'03 Ford 7.3 with 91k first UOA. Thoughts welcome #4484152
08/09/17 10:08 PM
08/09/17 10:08 PM
MD
amcguru Offline OP
amcguru  Offline OP
MD
Don't use the truck much unless I'm towing or need large vehicle for something, so this oil has gone 6k miles in two years. Curious about the Copper & Silver levels. I Installed a ball bearing turbo about 1k miles before the oil was changed, so I'm hoping that has something to do with it. Moly seems lower than I expected.
Wondering how long I should run this batch?
Schaeffer 9000 5w40. Analysis performed by Schaeffer.
Fe 19
Cr 1
Pb 6
Cu 30
Sn 0
Al 2
Ni 1
Ag 16
Ti 0
V 0
Si 16
B 50
Na 18
K 1
Mg 153
Ca 1997
P 1083
Zn 1402
Mo 102
Viscosity 12.36 @ 100c
BN 6.89
Particle count 0
H2O <.1
Glycol 0
Soot .1
OXI 15.28
NIT 0
'16 Mercedes C300 -M1 5w40 formula M, OE filter
'03 Ford Excursion 7.3 PSD -Schaeffer 9000 5w40, Donaldson ELF7405
Re: '03 Ford 7.3 with 91k first UOA. Thoughts welcome [Re: amcguru] #4484184
08/09/17 10:54 PM
08/09/17 10:54 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
If that was one of my gassers, the metals would worry me. Chrome is rings Iron is the block and cam, the rest is bearing material head and piston.and maybe
Thick oil is better grin2
Re: '03 Ford 7.3 with 91k first UOA. Thoughts welcome [Re: amcguru] #4484496
08/10/17 09:50 AM
08/10/17 09:50 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
I would guess that the high metals is from the turbo breaking in yes. Only way to know for sure is to test a few more OCIs at least and see if it starts trending down.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: '03 Ford 7.3 with 91k first UOA. Thoughts welcome [Re: amcguru] #4484573
08/10/17 11:01 AM
08/10/17 11:01 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
The Si is not silver, but Silica (or silicone; both are seen the same by spectral analysis). Silica is dirt ingestion. This Si level may be accounting for a bit of the Fe, but not a lot.
I'd not do anything to it except upon the next OCI, do another UOA and see if the wear metals come down a bit.
The ol' 7.3PSD is a good engine and has plenty of life left in her. With only 93k miles in 14 years, it's not likely you'll ever wear it out.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: '03 Ford 7.3 with 91k first UOA. Thoughts welcome [Re: amcguru] #4484576
08/10/17 11:04 AM
08/10/17 11:04 AM
Austin, Texas
Brons2 Offline
Brons2  Offline
Austin, Texas
Has sheared back to 30wt. One one hand, with the viscosity loss and considering the elevated metals, a change might be good. But on the other hand, the TBN is great still at 6.89, so it definitely has the additive levels to go longer. Maybe run it another 3-4K and sample again, paying particular attention to the rate of metal wear per 1000 miles.
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
Re: '03 Ford 7.3 with 91k first UOA. Thoughts welcome [Re: amcguru] #4484627
08/10/17 11:58 AM
08/10/17 11:58 AM
MD
amcguru Offline OP
amcguru  Offline OP
MD
The HEUI loves to shear oil down to a 30 wt, and the 7.3's for the most part seem to happy with it, so I m not too concerned about the viscosity. Schaeffer flagged it for the silver (Ag) level, so that's what I'm most curious about. Guessing ball bearings in the new turbo? Checking for air leaks as silica is higher than I would expect with the AIS air cleaner I'm running.
Re: '03 Ford 7.3 with 91k first UOA. Thoughts welcome [Re: amcguru] #4485208
08/10/17 10:17 PM
08/10/17 10:17 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Did you use any silicone sealers when you did the turbo r&r? That might account for some of the Si.
-Colton
Re: '03 Ford 7.3 with 91k first UOA. Thoughts welcome [Re: amcguru] #4485377
08/11/17 06:49 AM
08/11/17 06:49 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
To be clear, the silver (Ag) and the silica (Si) are not the same thing. I thought you were looking at the Si, but I now see the Ag is a bit up as well. I'm not used to looking for Ag in a UOA.
I'm not sure of the source of the Ag.
The Si would be of more concern to me. Not that the level of Si is "bad", but a tad elevated. However, given that the engine had a turbo removed and installed, it's possible that amount is elevated from the work. If it drops upon the next OCI, no issues whatsoever.
Re: '03 Ford 7.3 with 91k first UOA. Thoughts welcome [Re: amcguru] #4486194
08/11/17 11:04 PM
08/11/17 11:04 PM
MD
amcguru Offline OP
amcguru  Offline OP
MD
I did a little digging and it seems Schaeffer uses Si as an anti-foam agent. I found VOA's of this oil with Si in the 9-14ppm range, so that explains that. Thanks everyone for your input.
