Car for short, elderly person?
by BBDartCA - 01/22/20 08:34 PM
Amsoil discontinues ACD SAE 30/10w30 HDEO
by CleverUserName - 01/22/20 07:34 PM
Chromium-based Microsoft Edge
by uc50ic4more - 01/22/20 07:13 PM
Reason for new car problems
by Exhaustgases - 01/22/20 05:50 PM
Selling the VW need a replacement.
by ram_man - 01/22/20 05:48 PM
Williams Tools Made in Taiwan
by BBDartCA - 01/22/20 05:32 PM
Synthetic Power Steering Fluid?
by TXCarGeek - 01/22/20 05:03 PM
New 5% RA discount code
by bullwinkle - 01/22/20 04:12 PM
17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Npt fitting torque?
by motor_oil_madman - 01/22/20 11:47 AM
Tracing wires in walls
by Dave Sherman - 01/22/20 11:32 AM
WM Castrol HM magnatec 6 GALLON BOX $45
by GMguy84 - 01/22/20 11:30 AM
Steering Lubricant Suggestion
by lancerplayer - 01/22/20 11:08 AM
Neglected AW55-50 - Plan Of Attack?
by Bailes1992 - 01/22/20 09:14 AM
Jeff1024, EricWestland, Brian200001, Phildrum, 335xiE92FBO
70506 Registered Users
114 registered members (allgm59, antonmnster, AC1DD, 2009Edge, 9 invisible), 1,811 guests, and 17 spiders.
Topics300,444
Posts5,175,954
Members70,506
Rebarrel Old Rifle? #4482989 08/08/17 05:48 PM
tom slick Offline OP
I have a sporterized Mexican Mauser chambered in .22-250 with a worn throat. Is it worth having a new barrel installed? I would probably change to .243 or .308 or something similar.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Rebarrel Old Rifle? [Re: tom slick] #4483000 08/08/17 06:00 PM
B
billt460 Offline
B
If you're going larger in bore diameter, you might get away with getting it rebored and rechambered.
Re: Rebarrel Old Rifle? [Re: tom slick] #4483024 08/08/17 06:25 PM
A
AirgunSavant Offline
A
I'd say no.
New rifles are relatively cheap compared to gunsmithing work.
Re: Rebarrel Old Rifle? [Re: tom slick] #4483059 08/08/17 07:02 PM
N
nwjones18 Offline
N
The correct answer is it is if you like it.. Life is to short to have the same guns as everyone else. haha
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 and Mopar filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
2007 Mazda 3 2.3 130k 5w-30 syn-blend and Denso filter
Re: Rebarrel Old Rifle? [Re: tom slick] #4483062 08/08/17 07:06 PM
B
BrocLuno Offline
B
Yeah, but gunsmithing keeps the dollars where you want them. Employs fellow shooters, etc.
The simplest approach is to have the barrel set back say two threads and the chamber re-cut. Your barrel will be something around 1/4" shorter, no big deal.
But, if you don't want that caliber anymore, sell it and get something else ...
Is it registered? Was the bolt-face altered? Was the mag altered?
Re: Rebarrel Old Rifle? [Re: tom slick] #4483099 08/08/17 07:42 PM
H
HangFire Offline
H
Installed a new barrel is like putting a new engine in a car. Setting back a barrel is like rebuilding an engine in a car. People do it (or have it done) all the time, but the cost/benefit has to be analyzed versus total replacement.
If it's a Mexican Model 1895 (small ring action) I'd think hard about not doing it.
If it's a M1902 ('98/Large Ring action) in good shape, I really liked the gun, it already fed and extracted well, and the receiver checks out OK, I'd go for it. Have the gunsmith check out the receiver lugs for setback. If there's already signficant setback, even in a large ring, I'd pass on a rebarrel.
Various musings: http://hangfire.net
Re: Rebarrel Old Rifle? [Re: tom slick] #4483108 08/08/17 07:50 PM
demarpaint Offline
I'd have them rebarrel it, that's if you like the rifle. You could probably have it set back, but 22.250 is hard on barrels, so a new barrel would be the way to go. .243 and .308 are good choices. If you have a good gunsmith he can bed the new barrel too, and you could end up with a real nice shooter.
God Bless Our Troops
Re: Rebarrel Old Rifle? [Re: demarpaint] #4483183 08/08/17 09:40 PM
H
HangFire Offline
H
If the magazine is blocked, the follower cut and the top rails reshaped for feeding 22/250 properly, trying to move to 243 or 308 would NOT be good choices. Likewise if it was an Oviedo small ring, too soft for a cartridge both that large and that high pressure.
Re: Rebarrel Old Rifle? [Re: tom slick] #4483229 08/08/17 11:05 PM
I hadn't thought about having the chamber recut if the the rifling is still okay. It saves a lot of work having the other parts fitted to a new caliber.
Functionality it's a nice shooter, it feeds good and is smooth. It was custom built back in the late
60's as a hunting rifle and I've had it for about 30 years. It It has sentimental value but not "can't touch it" sentimental value.
Re: Rebarrel Old Rifle? [Re: tom slick] #4483300 08/09/17 04:13 AM
B
billt460 Offline
B
It was custom built back in the late 60's as a hunting rifle and I've had it for about 30 years.
It would most definitely be worth rebarreling, or whatever gunsmith work you put into it, if that's the case. Custom built rifles from the 60's show an era of craftsmanship that is lost in a lot of todays rifles that are pedaled at the, "Big Box Stores".
Re: Rebarrel Old Rifle? [Re: tom slick] #4483442 08/09/17 07:56 AM
B
bsmithwins Offline
B
The throat is worn, but has the group size opened up?
As the others have said, your options are:
1) Have the barrel moved back and rechambered.
2) New barrel.
3) Sell it and get what you actually want.
There are pluses and minuses to all three option, just like most things in life.
BSW
Re: Rebarrel Old Rifle? [Re: tom slick] #4483997 08/09/17 06:07 PM
Groups aren't consistent. I can almost push the bullet out of the case before it hits the lands.
Re: Rebarrel Old Rifle? [Re: tom slick] #4484007 08/09/17 06:16 PM
B
bsmithwins Offline
B
Then it's probably time to pick an option.
Good luck.
BSW
Re: Rebarrel Old Rifle? [Re: tom slick] #4484044 08/09/17 06:53 PM
U
userfriendly Offline
U
Some of the new bullets might want a tighter rate of twist than your old barrel. Is your action long enough for 5.5x55? Everyone danced right over 260 & 7mm-08 Rem.
Re: Rebarrel Old Rifle? [Re: tom slick] #4484309 08/10/17 05:38 AM
H
HangFire Offline
H
Before going crazy picking new cartridges, consider that the receiver and/or magazine may need to be modified to feed properly. That can be a tedious process. I provided my gunsmith with a bunch of dummies and it took him considerable time (and $$$) to get it to feed, and that was a 57mm long case in a '98 Mauser receiver, but the body taper was different.
If it feeds/ejects OK right now, ask your gunsmith how much more extra the work will be for a cartridge change.
