Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
Cadillac CT5 Revealed
by E365. 03/18/19 01:36 AM
toplscuda, swrve, TomRx, Ozdave, Rod1701
67547 Registered Users
112 registered members (928, 2009Edge, 97f150, 2015_PSD, 12 invisible), 2,291 guests, and 60 spiders.
Topics286,014
Posts4,900,738
Members67,547
Most Online2,967
Mar 10th, 2019
lubegard heavy duty engine protectant 32 oz. #4474270
07/29/17 11:42 PM
07/29/17 11:42 PM
oklahoma
hyperscion Offline OP
oklahoma
question. will adding lubegard hd eng protectant. i thank its the bio formula? into a 2008 f-150, 7qt sump, calling for 5w20 oil.
will it raise the oil thickness or thin it down????
it has good reviews just dont know about the visc>
thanks any info is appreciated.
Re: lubegard heavy duty engine protectant 32 oz. [Re: hyperscion] #4474274
07/30/17 12:08 AM
07/30/17 12:08 AM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
Also would like to know, I just ordered some and got it in today.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: lubegard heavy duty engine protectant 32 oz. [Re: TheKracken] #4474285
07/30/17 12:36 AM
07/30/17 12:36 AM
oklahoma
oklahoma
ok. you add it first... then tell me what happened. smile
Re: lubegard heavy duty engine protectant 32 oz. [Re: hyperscion] #4474310
07/30/17 02:54 AM
07/30/17 02:54 AM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
TheKracken and I were both on this thread I started:
https://bobistheoilguy.com/forums/ubbthr...es?#Post4472170
I was disappointed it did not develop more discussion, it seems a point of little interest now. That is in comparison to much more vigorous discussions I found on the subject back in '03 and '06 on esters as additives. I have done hours of research on this and I think he has too (TheKracken). Molakule weighed in with some science in the thread above (and the old ones years ago), and apparently as far as we (the sea monster and I) are concerned, it's worth checkin' out!
Based on that, I also ordered a quart last night. Heck, at $15/qt delivered vs. $60/24 ozs delivered for AutoRX, it was kinda a no-brainer to give it a try.
I also don't know the viscosity, but at the recommended dosages, it shouldn't matter. On my vehicle, I'm going to do (yet another) kerosene flush, then (yest another) piston soak with ATF and acetone overnight. Then a second round of the above. Then a another kerosene flush. Then an oil rinse and dump. New full synthetic filter (already running them a while), and M1 0W-40 and Lubegard bio/tech. I'm trying to clear stuck oil rings and drain holes.
I've done piston soaks and kerosene flushes in the past with measurable results. But they regress after a few thousand miles because of the bad ring and drain hole design on the engine. I'm willing to try this as a final effort before having to pull the engine fully out to drill more piston drain holes in the oil ring grooves.
Folks who say "a good oil has all you need in it" without fulling eliciting the situation clearly have no clue and don't understand that some people wrestle with engineering defects that even a great oil can't uniformly address. But it's a good litmus test of who to put on your "block" list to not see their puffy pontifications again! tig1 earned that in my book for his hit-and-run bloviating in the above linked thread.
Re: lubegard heavy duty engine protectant 32 oz. [Re: Oro_O] #4474320
07/30/17 03:31 AM
07/30/17 03:31 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
For al, the effort youve gone to it would have been just as easy to put new pistons in.
Cable ties should hold it
Re: lubegard heavy duty engine protectant 32 oz. [Re: Oro_O] #4474326
07/30/17 03:41 AM
07/30/17 03:41 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I've used it on and off for a lot of years, and found it to be a good product. Where are you getting it for $15/ qt. delivered? Can you post it or PM me a link. We have a potential test mule for it. Thanks!
God Bless Our Troops
Re: lubegard heavy duty engine protectant 32 oz. [Re: Olas] #4474330
07/30/17 03:49 AM
07/30/17 03:49 AM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
Parsing that discordant response, I'd say "No," the modest efforts I've taken and the measurable positive results have been WELL WORTH not pulling an engine. And nothing about this issue requires new pistons at all. I get the impression you really don't know the pain, expense, and effort that takes vs other approaches.
