Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
Cadillac CT5 Revealed
by E365. 03/18/19 01:36 AM
Scored free 0w-20 semi synthetic
by pdxglocker9mm. 03/18/19 01:13 AM
TomRx, Ozdave, Rod1701, Arbitrader, Djdecember
67545 Registered Users
115 registered members (ABerns, 65convertible, ammolab, addyguy, 928, AdditiveOCD, 9 invisible), 2,273 guests, and 59 spiders.
Topics286,013
Posts4,900,707
Members67,545
Most Online2,967
Mar 10th, 2019
Ill fitting aftermarket molded hoses for imports #4469532
07/25/17 01:07 AM
07/25/17 01:07 AM
Specific Ocean
Kibitoshin Offline OP
Specific Ocean
Had to yank out a NAPA/Gates lower radiator hose for an OEM hose on an 04 Lexus LS430 because it started to rub on the power steering pump pulley and spew coolant. Initial installation looked like it would clear the pulley with 1/2" clearance but as the hose warms up it began to expand and flex and it would begin to rub on the pulley. Before that at the parts store I compared the original hoses to the new hoses. I knew it looked sketchy that it didn't bend enough for more clearance around the pulley area. I chanced it since I've used aftermarket hoses on BMW's and Mercs with no issues and it was cheap for the pair of upper and lower hoses. Lexus dealership had the hoses and swapped it over the same day.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: Ill fitting aftermarket molded hoses for imports [Re: Kibitoshin] #4469536
07/25/17 01:27 AM
07/25/17 01:27 AM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
I might get stabbed for this comment - I was running the original OEM coolant hoses - all of them - on my '96 LS400 when I sold it last month with over 300,000 miles. I wonder if the 04 LS430 had a perfectly good set of OEM hoses replaced with new aftermarket garbage hoses as preventive maintenance.
FWIW the lower hose on the LS is quite a contortionist so it wouldn't be easy for an aftermarket company to exactly match up.
too many cars and oil combinations to list in 150 characters or less
Re: Ill fitting aftermarket molded hoses for imports [Re: Kibitoshin] #4469537
07/25/17 01:37 AM
07/25/17 01:37 AM
Specific Ocean
Specific Ocean
The car had a major collision a couple years ago where the rad hoses got bent and kinked up and the body shop hadn't replaced the hoses along with the new rad and condensor. I've let it pass but now the car has 160,000mi on it and I rather change the hoses as PM because I've seem so much cooling system failures especially when it gets hotter and getting stranded (along a freeway w/ no shoulder lane!) is not an option.
The heater core hoses are still original. I do cooling system drain/refills (pull lower rad hose) every two years to keep the cooling system healthy.
Re: Ill fitting aftermarket molded hoses for imports [Re: Kibitoshin] #4469556
07/25/17 03:02 AM
07/25/17 03:02 AM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
With Lexus parts, especially the LS series - buying OEM truly is a buy once, cry once deal. The LS series OEM parts are amazing quality compared to aftermarket.
Other makes, other models, cheaper series cars - lots of times there's not gonna be that much difference between OEM and aftermarket quality.
Re: Ill fitting aftermarket molded hoses for imports [Re: Kibitoshin] #4469743
07/25/17 08:13 AM
07/25/17 08:13 AM
NC
BigD1 Offline
BigD1  Offline
NC
Wish those Toyota/Lexus spring hose clamps with the pull tab were cheaper. Just slide the clamp on the hose in the right spot, and then pull the tab off the clamp, and it's on there good.
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: Ill fitting aftermarket molded hoses for imports [Re: Kibitoshin] #4469752
07/25/17 08:26 AM
07/25/17 08:26 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I put all new cooling hoses on my '08 Accent last month. Big radiator hoses were from Autozone and the lower one was for the auto trans but fit. Upper was OK as was the water pump 90*. The heater hoses I got from NAPA and they fit good too.
All the OE hoses looked like they could go another 100k miles but some of the OE spring clamps were rusted pretty bad.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Ill fitting aftermarket molded hoses for imports [Re: Kibitoshin] #4469805
07/25/17 09:11 AM
07/25/17 09:11 AM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
One trick for bent hoses that stick out too far, is to cut an inch or so off of one end or half as much off both ends. That way they pull in their elbow when stretched to fit. Assuming they don't interfere with something else along the way... Also when you go to cut, you'll find out just how tough modern hoses are!
Sometimes aftermarket hoses are fine, sometimes they are not. I got a coolant leak on my Dakota top radiator hose, it's really two hoses with a plastic junction in the middle holding the cap. I happily bought both sides and with great effort, removed the factory hoses and clamped-on the aftermarket. I had coolant leaks for the next couple of years until I went to the dealer and bought the whole assembly- both side hoses and junction- for about the same price as I paid for the 2 aftermarkets.
The issue was the OEM junction didn't have enough barb on either side to hold on and seal the aftermarket hoses. It was made as an assembly, and the aftermarket attempt to make it into two hoses was just misguided.
On the flip side, I've replaced countless other hoses with Gates or other brand-name aftermarket, with zero problems.
Various musings: http://hangfire.net
Re: Ill fitting aftermarket molded hoses for imports [Re: Kibitoshin] #4469868
07/25/17 10:01 AM
07/25/17 10:01 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I am having this issue now. My truck has a bypass hose. (Didn't know what it was called originally.) It runs from the water pump to the intake and is almost a u shape. Very short thing. NAPA was the only one that had it and I wanted the truck back together that day.. it's starting to kink now. I wish I would have went with AC Delco on Rock Auto.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Ill fitting aftermarket molded hoses for imports [Re: Kibitoshin] #4469962
07/25/17 12:18 PM
07/25/17 12:18 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
This year I changed the 20 year old heater hoses on the Maxima. The originals were perfectly fine. No issues with the new Gates hoses yet.
1997 Maxima 197k, Castrol GTX Synblend 5W-30, FL400S
2004 Corolla 197k, VWB + SSS + Rislone cocktail, MGL51516
Re: Ill fitting aftermarket molded hoses for imports [Re: Kibitoshin] #4470000
07/25/17 12:54 PM
07/25/17 12:54 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
Buy domestic cars instead, so you won't have this problem.
Yes, I am being sarcastic.
Re: Ill fitting aftermarket molded hoses for imports [Re: L_Sludger] #4470022
07/25/17 01:16 PM
07/25/17 01:16 PM
Dallas,Tx USA
aquariuscsm Online content
aquariuscsm  Online Content
Dallas,Tx USA
Same with my 300ZX. Had almost 20 year old original hoses. I replaced them all when I did the timing belt. They still looked and felt brand new. I of course replaced them with Nissan oem. Heck,the original timing belt looked and felt brand new too.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: Ill fitting aftermarket molded hoses for imports [Re: Kibitoshin] #4470034
07/25/17 01:33 PM
07/25/17 01:33 PM
California
nthach Offline
nthach  Offline
California
I had an Gates hose on an LS400, the lower hose. It fit OK, but I had to trim quite a bit of it off and twist it the right way to keep the hose from kissing the drive belt.
The upper hose I had to get OEM - the Gates one was kinked up a few degrees differently than OEM.
