Diagnosing gas furnace
by Oro_O. 09/19/18 01:16 PM
Let's talk dipsticks and oil capacity
by csandste. 09/19/18 12:32 PM
Here's my fram filter at least 18 thousand miles
by Ablebody. 09/19/18 11:31 AM
How much is my truck worth?
by wallyuwl. 09/19/18 09:56 AM
Looking for Spray Detailer Advice
by knerml. 09/19/18 09:51 AM
LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:28 AM
by dedonderosa. 09/19/18 09:26 AM
When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
111 registered members (Abax25, 2004tdigls, 53' Stude, 12 invisible), 1,817 guests, and 39 spiders.
Topics290,668
Posts4,847,992
Members66,011
Most Online3,590
Jan 24th, 2017
Motive power bleeder? #4468425
07/23/17 09:20 PM
07/23/17 09:20 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
So I've been looking at these Motiv "power bleeders" for some time now. Seems I have to twist arms something fierce to get extra help bleeding brakes and I never feel like I get to spend enough time doing it. Plus, looking at the price of speed bleeders, just doing one car would come close to the cost of the motiv. Specifically my fleet currently includes '11 and '05 F150, '96 Mustang, '14 Explorer and one lone Nissan Rogue which sees the dealer for repairs. Of course, these change periodically so there is that.
Anyways, talking with Motiv they note that the 0107 should work with most of this list, though a few reviewers note otherwise. Has anybody used the Motiv Power Bleeder? Good stuff or are there better options? I don't want to break the bank but I would like something effective and that will last more than a job or two.
Link: http://a.co/gcJrLov
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Motive power bleeder? [Re: buck91] #4468443
07/23/17 09:32 PM
07/23/17 09:32 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Save your money. All you need to do a one person bleed, is 3 feet of clear tubing and a little jar 1/2 full of brake fluid to make an air lock. You want a snug fit on the bleeder. Open the bleeder and pump the pedal by hand. Keep an eye on the reservoir level.
Thick oil is better grin2
Re: Motive power bleeder? [Re: andyd] #4468460
07/23/17 09:44 PM
07/23/17 09:44 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Never in my life have I had tubing stay on a bleeder unless I physically hold it in place.
I love using the motive. Twist it onto the res, pump it up and I usually just crack the bleeder and let it whiz where it will, hopefully hitting a oil drain pan.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: Motive power bleeder? [Re: buck91] #4468470
07/23/17 09:57 PM
07/23/17 09:57 PM
Michigan
MrHorspwer Offline
MrHorspwer  Offline
Michigan
I have a Motive bleeder and absolutely love it. I've owned it for at least a decade, primarily for cars that see HPDE/auto-x use. I tend to flush every year, sometimes more than once. Full flush with a solid pedal every time, no mishaps, and it's quicker than anything around.
Flushing out my Camaro earlier this year before it's first auto-x:
I'm not a big fan of pricey single-purpose tools, but:
Re: Motive power bleeder? [Re: buck91] #4468475
07/23/17 10:08 PM
07/23/17 10:08 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
LOL nice meme.
2011 F150 4x4 5.0L
Re: Motive power bleeder? [Re: buck91] #4468476
07/23/17 10:14 PM
07/23/17 10:14 PM
Milwaukee, WI.
beechcraftted Offline
Milwaukee, WI.
I have used the Phoenix "reverse" bleeder for a number of years. 1 man operation, and the hose has always stays on the bleeder nipple for me.
'66 Chevelle 496 big block
'69 Corvette 427 4 speed
'70 Rebel "Machine" 390 4 speed
'04 Suburban
'10 Impala
'15 Honda F6B
'92 Suzuki Katana 1100
Re: Motive power bleeder? [Re: buck91] #4468478
07/23/17 10:23 PM
07/23/17 10:23 PM
5600 feet elevation, Arizona
double vanos Offline
On top of a motive bleeder I have a Griots Garage "sucker style " bleeder that pulls the fluid out at the wheel cylinder / caliper. Works well .
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Motive power bleeder? [Re: buck91] #4468508
07/23/17 11:03 PM
07/23/17 11:03 PM
USA
ArcticDriver Offline
USA
I prefer a device that pressurizes and pushes fluid through rather than one that pulls by vacuum. The vacuum type typically attached over the bleeder nipple has a tendency to suck air around the threading of the nipple.
Either technique is better than pumping the brakes because there is a risk the brake pedal will be depressed beyond its typical range and damage the seals resulting in leaks.
From my experience having relied on each of these techniques over the years.
Multiple Diesel and Gasoline vehicles
Re: Motive power bleeder? [Re: MrHorspwer] #4468511
07/23/17 11:08 PM
07/23/17 11:08 PM
Upper Midwest by the Lakes USA
SumpChump Offline
SumpChump  Offline
Any negatives to the Motive bleeding process, design, etc? I'd kinda fear a "blowout" and soray of brake fluid on paint.
Re: Motive power bleeder? [Re: buck91] #4468590
07/24/17 05:33 AM
07/24/17 05:33 AM
Greece
Panos Offline
Panos  Offline
Greece
I have bought a Chinese hand vacuum kit from e bay last year... Cost about 20 bucks delivered. Works like a charm. Best guaranteed result and speed for the fluid change. And at last I managed to service my car buy myself after 12 years of ownership beside my bikes which I already could change the fluid by the manual method pumping the levers.
Ford fiesta 1.6 mk6 Motul specific 913D/Motul Gear 300
Kawasaki ninja 250r Motul 5100 10w40
Honda cbr600f Pc41 Motul 7100 10w30
Re: Motive power bleeder? [Re: buck91] #4468643
07/24/17 07:00 AM
07/24/17 07:00 AM
Indianapolis, IN
09_GXP Offline
09_GXP  Offline
Indianapolis, IN
My power bleeder is one of my favorite tools. I sometimes bleed the brakes on my race car a half-dozen times a week. Using the power bleeder it takes longer to jack the car up than actually bleed the brakes.
2017 Miata Global Cup Car #02 - Castol A3/B4 5w30 w/ OEM Fitler
2017 Miata RF - PP 0w20 w/ M1 Filter
2015 F-150 2.7L Ecoboost - PPPP 5w30 w/ MC
Re: Motive power bleeder? [Re: buck91] #4468671
07/24/17 07:42 AM
07/24/17 07:42 AM
NE Ohio
knerml Online content
knerml  Online Content
NE Ohio
I started using a Motive bleeder to flush clutch cylinders. Could not get the clutch to pump enough fluid to flush.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W20 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: Motive power bleeder? [Re: buck91] #4468673
07/24/17 07:43 AM
07/24/17 07:43 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Since I started using the Motive, I won't do it any other way. Just get under, and hit all 4-6 wheels.
No monitoring the reservoir, no pumping, no nothing.
This a Godsend for trailers and my forklifts. Some of my lifts have 4 stages of bleeding thanks to the complex braking systems. No way I'd do the traditional method ever again.
Amazing for clutches too.
Re: Motive power bleeder? [Re: DoubleWasp] #4468679
07/24/17 07:48 AM
07/24/17 07:48 AM
USA
USA
+1.
Well worth the initial investment.
Re: Motive power bleeder? [Re: buck91] #4468840
07/24/17 10:52 AM
07/24/17 10:52 AM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
I had one for a while (Motive bleeder).
Decided to sell it on CL to some 911 enthusiast after discovering gravity bleeding.
Never looked back
coffee
06 Lexus IS350- Wife
88 BMW 325is- Mistress
