Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
Chain cleaning and lube
by dadinfo
06/23/18 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
92 registered (2004tdigls, 2009Edge, 10WSmuckers, advocate, Aero540T, 12 invisible), 1503 Guests and 40 Spiders online.
65303 Members
67 Forums
285870 Topics
#4467890 - 07/23/17 10:45 AM Toro weed eater
matrass Offline
Loc: Pa
Have a Toro weedeater that I purchased 3 years ago and has been running great.
Run it out of fuel at the end of every season and it was working great all Spring.
Starting having issues the last two weeks with it not wanting to idle, just dies when you let off the gas.
starts easy and runs full power like it always did.
Changed the fuel filter and looked at the air filter and it looks clean.
Sprayed the carb with a little Amsoil power foam and let it soak for a couple of hours with no improvement.
Dumped out the gas and put more in even though my leaf blower is running the same mix from the same can.
Did not change the plug but did remove it and cleaned it off and it did not help.
Removed spark arrestor and cleaned it off even though it looked pretty good .
Thinking it may be carb related ?
open to ideas ... thanks
Edited by matrass (07/23/17 10:47 AM)
#4467913 - 07/23/17 11:07 AM Re: Toro weed eater [Re: matrass]
TmanP Offline
Loc: MN
Sounds carb-related to me. Cleaning that would be my first step.
2006 Buick Lacrosse 3.8 V6 150,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
#4467922 - 07/23/17 11:13 AM Re: Toro weed eater [Re: matrass]
Warstud Online   content
Loc: MIchigan
Since it runs....try some Techron or Gumout-Regane in the gas tank.
#4467930 - 07/23/17 11:21 AM Re: Toro weed eater [Re: Warstud]
matrass Offline
Loc: Pa
Was hoping to not have to pull the carb off thus the reason for the amsoil power foam.
I have yamaha ring free that I could throw in the gas, not sure if that would do anything the power foam did not.
Edited by matrass (07/23/17 11:22 AM)
#4467936 - 07/23/17 11:24 AM Re: Toro weed eater [Re: matrass]
bioburner Offline
Loc: Minnesota
Sounds like the little diaphragm pump is going soft. Will probably continue to get harder to keep running on the low side of the throttle
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4467953 - 07/23/17 11:54 AM Re: Toro weed eater [Re: bioburner]
The_Eric Offline
Loc: Iowa
Agreed. That or the impulse line is cracked/leaking.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#4467969 - 07/23/17 12:16 PM Re: Toro weed eater [Re: The_Eric]
Linctex Offline
Loc: Waco, TX
I think the pulse signal is just a passage.. you can see it on the flange when the carb comes off.
The idle circuit is the smallest circuit, and the easiest to gum up.
#4467990 - 07/23/17 12:36 PM Re: Toro weed eater [Re: matrass]
Loc: MIchigan
Was hoping to not have to pull the carb off.
Don't blame you....most people don't feel comfortable doing it. Thus trying a fuel system is a no brainer
#4468025 - 07/23/17 01:26 PM Re: Toro weed eater [Re: Warstud]
matrass Offline
Loc: Pa
Suppose I will give that a shot this week and see what happens.
Remember pulling the carb off my Toro snowblower and it was not too bad but may have to .
#4468060 - 07/23/17 02:27 PM Re: Toro weed eater [Re: matrass]
andyd Offline
Loc: Marshfield , MA
I keep a can of B 12 Chem- Tool for just these occasions. Cheap and effective. I try an additive before taking a carb apart. Results are better than even that the Chem Tool will clear out the crud. Chances are the carb is a Zama, or some other Walbro clone. Parts or entire carbs are dirt cheap on the inter wbs
Edited by andyd (07/23/17 02:30 PM)
Thick oil is better grin2
