Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
debris in my engine oil--what to do?
by Jasper8146. 09/22/18 03:50 PM
Is this seal bad?
by parshisa. 09/22/18 03:44 PM
Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
83 registered members (4WD, ABomb369, A310, 53' Stude, Ag76, 92saturnsl2, 8 invisible), 1,435 guests, and 44 spiders.
Topics290,853
Posts4,851,486
Members66,044
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Piece of oil cap gasket fell in fill hole. #4467253
07/22/17 04:29 PM
07/22/17 04:29 PM
Ca
OceanRuns Offline OP
Ca
Vehicle: 1983 Ford Fairmont, 3.3, 6 cylinder.
I went to top off the oil, and a gasket that is on the bottom of the cap broke in two. One half fell in the fill hole. I was able to fish most of it out. It was quite brittle, and some appears to have 'gone in'. In the photo below, the amount that went in probably isn't that much greater than the small piece on the right (could be a little more, or less. And, there are also a few really small pieces that broke off when I was fishing the rest out).
One can break this fairly easily by hand, but of course once the pieces are small enough, they're hard/coarse. I am not sure what this is made of. It seems like a gasket that is meant to be replaced?
So, given that some went in, should I worry? Or, am I all good.
Also, does the cap really need such a thing?
Thanks for any advice. (Quarter for comparison.)
Re: Piece of oil cap gasket fell in fill hole. [Re: OceanRuns] #4467257
07/22/17 04:33 PM
07/22/17 04:33 PM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
It will be waiting for you to remove it next time the valve cover is removed
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Piece of oil cap gasket fell in fill hole. [Re: OceanRuns] #4467260
07/22/17 04:37 PM
07/22/17 04:37 PM
South OZ
KL31 Offline
KL31  Offline
South OZ
Have you started the car since that bit fell in? If not, I'd pop the valve/rocker cover and get it out. I've never had a car with an oil cap gasket. You can try without one and check for leaks I suppose.
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
Re: Piece of oil cap gasket fell in fill hole. [Re: NStuart] #4467262
07/22/17 04:38 PM
07/22/17 04:38 PM
Ca
Ca
I wasn't planning to do that anytime soon, unless it's really needed.
Re: Piece of oil cap gasket fell in fill hole. [Re: OceanRuns] #4467263
07/22/17 04:39 PM
07/22/17 04:39 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Yes, it needs it, another oil fill cap will be needed (or a gasket if there is one available). If the chunk was small enough to make it down a drainback hole, it might find its' way into the sump and the oil pickup. Any chance of using a cheap borescope to look inside the valve cover and find it?
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Piece of oil cap gasket fell in fill hole. [Re: KL31] #4467265
07/22/17 04:40 PM
07/22/17 04:40 PM
Ca
Ca
Yes, I drove it home from WalMart (where this happened). No oil came out. The crankcase has positive pressure right? So the gasket would conceivably be to prevent that happening?
Re: Piece of oil cap gasket fell in fill hole. [Re: bullwinkle] #4467268
07/22/17 04:43 PM
07/22/17 04:43 PM
Ca
Ca
The way the fill hole is constructed doesn't show any of the internals. It's an angled piece of metal to make the oil flow in. That's really all one can see. I wouldn't be able to get something around that. I know in some cars you take the cap off and can see quite a bit.
Re: Piece of oil cap gasket fell in fill hole. [Re: OceanRuns] #4467271
07/22/17 04:51 PM
07/22/17 04:51 PM
USA
ArcticDriver Offline
USA
I always worry about this with the airtight aluminum seals and remove them fully before pouring.
But I also pour first into a second container....one of those big metal oilcans with the long trigger release spout.
Multiple Diesel and Gasoline vehicles
Re: Piece of oil cap gasket fell in fill hole. [Re: OceanRuns] #4467383
07/22/17 06:57 PM
07/22/17 06:57 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
The older Ford engines had those gaskets. They are needed so dirty air will not get sucked into the engine. PCV valve.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Piece of oil cap gasket fell in fill hole. [Re: ArcticDriver] #4467404
07/22/17 07:19 PM
07/22/17 07:19 PM
NJ
raaizin Online content
raaizin  Online Content
NJ
I did this many years ago on a 1990 t-bird with a 3.8. Car went over 200k miles. I guess it wasnt an issue.
Re: Piece of oil cap gasket fell in fill hole. [Re: OceanRuns] #4467406
07/22/17 07:20 PM
07/22/17 07:20 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
That'll get sucked into the oil pickup screen. When the oil pressure drops down to near zero, you'll know why.
Re: Piece of oil cap gasket fell in fill hole. [Re: OceanRuns] #4467413
07/22/17 07:26 PM
07/22/17 07:26 PM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
You got 34 years out of that one. Treat her to a new cap, she has earned it.
2018 RAM 2500 Cummins 6.7L (Factory Fill 5W-40)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
Re: Piece of oil cap gasket fell in fill hole. [Re: Merkava_4] #4467434
07/22/17 07:47 PM
07/22/17 07:47 PM
Ca
Ca
So you're saying it will block oil flow?
Re: Piece of oil cap gasket fell in fill hole. [Re: OceanRuns] #4467437
07/22/17 07:50 PM
07/22/17 07:50 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
If it sticks to the screen it will.
Re: Piece of oil cap gasket fell in fill hole. [Re: CT8] #4467451
07/22/17 08:01 PM
07/22/17 08:01 PM
Ca
Ca
The way this particular cap is set up is the cap itself has a rubber hose going directly to the intake. It seems positive pressure is being vented out through the cap itself.
So, would the gasket be there to ensure the gases vent through the hose rather than just out to the atmosphere? How would anything be sucked in? Forgive me if I am misunderstanding, just would like to know how it works.
I do intend to replace the gasket if I can find one.
Page 1 of 3 1 2 3
