Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
74 registered members (BeerCan, 94astro, 25ring, b1amgm47, advocate, aquariuscsm, 6 invisible), 1,370 guests, and 46 spiders.
Topics295,173
Posts4,929,169
Members66,700
Most Online2,553
Oct 27th, 2018
Eccentric alignment bolts are pure evil #4464664
07/20/17 07:36 AM
07/20/17 07:36 AM
Rochester, MI, US, World
Klutch9 Offline OP
Klutch9  Offline OP
I posted last week about alignment bolts frequently being rusted into place and not wanting to come out. On my Sedona, it ended up being worst-case. In the process of trying to remove a bad rear lateral arm on Friday, I unknowingly was hammering so hard that I completely bent the mounting points for the arm. I was hammering from underneath the van, so I couldn't see what was happening. With no effective way to bend it back myself, and with the arm STILL stuck in place, I hobbled the van to a local shop I've used before. It ended up that the subframe mounting was so bent, it couldn't safely be bent back. They had to source a used subframe (which was actually reasonable in cost), and 2 new lateral links, since both of the old ones were completely seized and had to be cut, even the good one. Van should be ready by Saturday, but the total cost is just over $1,200 frown seeing that this is a work vehicle and I can't be without it for more than a few days, I really had no other option.
TLDR; don't bother hammering, just cut those darn alignment bolts out.
'11 Fusion SE 2.5L - 83k miles - HK 0w20 syn, Wix XP filter
'08 Sedona LX LWB 3.8L - 129k miles - Havoline HM 5w20, Auto7 filter
Re: Eccentric alignment bolts are pure evil [Re: Klutch9] #4464737
07/20/17 08:40 AM
07/20/17 08:40 AM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Eccentric alignment bolts are not evil. Lack of regular maintenance, lack of anti-seize, etc. is evil.
Various musings: http://hangfire.net
Re: Eccentric alignment bolts are pure evil [Re: Klutch9] #4464740
07/20/17 08:45 AM
07/20/17 08:45 AM
Canuck living in California
KrisZ Offline
KrisZ  Offline
That's where oil rustproofing pays off.
When I brought in my Mazda 3. which is infamous for rust, for an alignment after an LCA and strut change, I was told that it may take longer than normal because of rust and the age of the car. They did it about 20 earlier than normal because nothing was stuck.
2015 Dodge Grand Caravan-27k miles.
2006 Mazda 3-163k miles
Re: Eccentric alignment bolts are pure evil [Re: Klutch9] #4464749
07/20/17 08:54 AM
07/20/17 08:54 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Removing rotten bolts is like the black art of torture, enough to get it to succumb without killing it as you found out.
Re: Eccentric alignment bolts are pure evil [Re: Klutch9] #4464758
07/20/17 09:22 AM
07/20/17 09:22 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
I live in the salt belt. Whenever I buy a new car, I take out the adjuster bolts, put a nice coat of silicone grease on them and reinstall, same goes for the tie rod threads. Never have a problem with them seizing after that.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Eccentric alignment bolts are pure evil [Re: Klutch9] #4465555
07/20/17 08:54 PM
07/20/17 08:54 PM
Minneapolis
antonmnster Offline
antonmnster  Offline
Minneapolis
For some reason my e90 BMW needs to be aligned every 6-12 months. Each time, some part is seized. Both front tie rods and both rear toe adjusters have been replaced at least once.
Had it at Firestone last week. They "couldn't align" the rear, and one of the rear's toe is "in the red zone".
I'm not sure what to do. I suppose I should go under it myself and try to free them up.
Re: Eccentric alignment bolts are pure evil [Re: Klutch9] #4465607
07/20/17 09:52 PM
07/20/17 09:52 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I think Firestone is one of the last places I would take a vehicle in for repairs .
I have heard Fluid Film helps prevent rust ?
Rusty fasteners = torch . Get it red hot and spray with penetrating oil . Repeat as necessary .
God bless
Wyr
Wyr
God bless
Re: Eccentric alignment bolts are pure evil [Re: Klutch9] #4465655
07/20/17 10:49 PM
07/20/17 10:49 PM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
Can confirm. Firestone is lousy. I still do go there once a year for a free (lifetime) alignment for my truck I hardly drive but beat on. The alignment is always different. The steering wheel is straight and it pulls or the steering wheel is crooked and tracks straight. Never is really good but tire wear is fine so I don't really care. If it was a DD I would never go back.
Re: Eccentric alignment bolts are pure evil [Re: Klutch9] #4468076
07/23/17 01:45 PM
07/23/17 01:45 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
Wow...you guys in the rust/salt belt have to deal with a lot.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Eccentric alignment bolts are pure evil [Re: WyrTwister] #4468177
07/23/17 03:41 PM
07/23/17 03:41 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
A torch is not always a good idea. Some eccentric bolt's receiving bushings are integrated with a rubber donut. A torch would NOT be a good idea here.
I am thinking of my Honda Pilot rear as I write this, it has rubber there around the metal collar that receives the eccentric bolt, on the inside end of the rear a-arm. I had to free up an eccentric bolt last year in order for the (local, trusted) tire shop to finish the alignment job. I would have had them risk breaking the bolt, but it was on a Saturday and they didn't want to break my car for the weekend until they could get parts on Monday.
Anyway the bolt laughed at my air impact because: rubber bushing absorbed impacts. LOL. 3 foot breaker bar on one side and impact gun on the other got it moving again. I had it parked in their parking lot Monday morning.
LOL great line. I just kill'em and get it over with. Of course I'm DIY and not on the clock. Fortunately my Honda eccentric was not broken, just stuck.
