AAP 25% Off
by Egg_Head
06/22/18 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
06/22/18 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
06/22/18 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fram SureGrip coating
by mobilaltima
06/21/18 08:24 PM
Manual transmissioned electric car
by mjoekingz28
06/21/18 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
06/21/18 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
06/21/18 06:02 PM
Traveller nlgi 2
by Spitter
06/21/18 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
06/21/18 05:08 PM
Any nano reefers here?
by RichardS
06/21/18 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
06/21/18 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
06/21/18 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
06/21/18 04:31 PM
help me choose...
by chaindrive
06/21/18 04:07 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
69 registered (4WD, BoiseRob, Bryanccfshr, brages, 01rangerxl, BeerCan, 7 invisible), 1166 Guests and 35 Spiders online.
65294 Members
67 Forums
285753 Topics
#4463085 - 07/18/17 04:54 PM 2007 Honda Element; 7,189mi; M1 0W20 AFE/EP
EdwardC Online   content
Loc: Chicago, IL
Nothing too exciting. I don't think I posted my previous UOA, so the 7/17 and 10/16 changes are new. As you can probably guess, I forgot to collect a sample during one of my changes (January 2016). The 8,259mi run was actually a blend of 1.5qt AFE, 3qt EP (both 0W20) and .5qt Supertech (5W20).
One thing to note, I did swap out the engine air filter half way through the 7,189mi run, which might account for the silicon (not that I'm worried). As of last year, the Element became our only vehicle, so it gets a lot more short trips when my wife commutes, mixed in with longer weekend trip. I do two oil changes per one oil filter interval. I put in 5qts of M1 0W20 EP back in. I'm trying to extend my intervals, but I usually just change it when time permits.
Code:
2007 Honda Element
Date of Change:		7/17	10/16 	4/15	5/14
Miles on Unit: 		111,056	103,867	86,415	78,226
Miles on Oil:		7,189	8,259	8,189	6,037
Oil Brand:		M1	M1	QS	M1
Oil Type:		AFE	AFE/EP	UD	AFE
Oil Grade:		0w20	0W20	0W20	0W20
Filter Change:		No	Yes	Yes	No
Metals(ppm):
Iron(Fe)		8	6	9	7
Chromium (Cr)		<1	<1	<1	<1
Lead (Pb)		<1	<1	<1	<1
Copper (Cu)		<1	<1	2	1
Tin (Sn)		<1	<1	<1	<1
Aluminum (Al)		3	3	4	5
Nickel (Ni)		<1	<1	<1	<1
Silver (Ag)		<1	<1	<1	<1
Titanium (Ti)		<1	<1	<1	<1
Vanadium (V)		<1	<1	<1	<1
Contaminants (ppm):
Silicon (Si)		14	13	10	10
Sodium (Na)		3	4	8	8
Potassium (K)		<1	<1	<5	<5
Additives (ppm):
Magnesium (Mg)		621	571	162	749
Calcium (Ca)		970	1283	1815	979
Barium (Ba)		<1	<1	<1	<1
Phosphorus (P)		576	658	680	633
Zinc (Zn)		635	730	766	738
Molybedenum (Mo)	72	76	218	72
Boron (B)		41	49	10	46
Contaminants:
Water (%)		<0.05	<0.05	<0.05	<0.05
Coolant			No	No	No	No
Physical Tests:
Viscosity (Cst @ 100C)	7.7	7.1	9.3	7.5
Fuel (%)		<1	<1
Soot (%) Infrared	0.4	<0.1
Physical/Chemical:
Base Number (mgKOH/g)	2.8	3.9	2.6	3.8
Thanks for looking!
#4464593 - 07/20/17 06:49 AM Re: 2007 Honda Element; 7,189mi; M1 0W20 AFE/EP [Re: EdwardC]
ltslimjim Offline
Loc: WatUpDoc
Nice report. Has the oil sheared some? The PDS says 8.8 at 100c.
https://www.mobil.com/English-US/Passenger-Vehicle-Lube/pds/GLXXMobil-1-0W20
TBN is still strong for what seems to be a 9 month interval and I'd assume fairly cold weather for a portion of the interval.
Considering the price for AFE and it not being marketed as an extended lube you are doing well. I'd keep monitoring potential for shearing. Not sure if it's the engine or conditions driven. Does it see short trips and several weeks of very cold weather? On the other hand, you'll notice the QSUD started to thicken up a bit pushing a year interval. shrug confused
Otherwise, the reports look good.
Edited by ltslimjim (07/20/17 06:51 AM)
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#4464763 - 07/20/17 10:38 AM Re: 2007 Honda Element; 7,189mi; M1 0W20 AFE/EP [Re: EdwardC]
bigt61 Offline
Loc: Virginia
You have some nice trends going. That engine isn't wearing out anytime soon. Ever add any make up oil? Good post.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#4465171 - 07/20/17 04:34 PM Re: 2007 Honda Element; 7,189mi; M1 0W20 AFE/EP [Re: EdwardC]
Loc: Chicago, IL
Nope, no make up oil at all. Sometimes, I wish it would use just a little oil so I can top off with some of the snow blower's 0W30 to thicken it up a little, knock on wood. It definitely gets short tripped all year round. However, I don't think it ever goes more than 2 weeks without getting fully up to temperature (I would estimate every week on average).
Yeah, that QSUD was interesting, being as thick as it was at the end of the run. I've been wanting to run that again just to see if it's consistent, but M1 AFE/EP has been cheaper with the rebates. Edit: Wow, I just checked the QSUD data sheets, it had a starting viscosity of 8.3 cSt at 100C!
I'm interested to see the viscosity of the EP. The data sheet says that it's 8.6 cSt at 100C. I'm thinking about putting in a 80%/20% blend of 0W-20/0W-30 AFE to get a thick 0W20 next time. I don't know why, maybe the thick oil guys are rubbing off on me a little, but I want to be on the thicker end of an 20 weight.
Thanks for the comments!
Edited by EdwardC (07/20/17 04:48 PM)
#4465183 - 07/20/17 04:47 PM Re: 2007 Honda Element; 7,189mi; M1 0W20 AFE/EP [Re: EdwardC]
ltslimjim Offline
Loc: WatUpDoc
For short-tripping and cold weather I don't see the need in going thicker. Shearing some but it stays in grade. I think you found your sweet spot.
I noticed my BIL started getting AFE 0w-20 to thicken up a bit on his 18k and 21k yearly OCI (Honda Fit in warm weather year round and hardly any short trips) and later it developed oil consumption.
So, some shearing isn't necessarily a bad thing as it stayed in grade (5.6 is the lower min. requirement for 20 grade) and the numbers aren't showing any issues with regards to apparent wear. I'd definitely say the AFE performed better overall compared to the QSUD in terms of thickening vs shearing. I'd rather an oil shear some than thicken up as long as I'm not at a track.
#4465200 - 07/20/17 05:02 PM Re: 2007 Honda Element; 7,189mi; M1 0W20 AFE/EP [Re: ltslimjim]
Loc: Chicago, IL
Wow, 18k and 21k, do you remember the TBN at the end of that?
#4465690 - 07/21/17 01:19 AM Re: 2007 Honda Element; 7,189mi; M1 0W20 AFE/EP [Re: EdwardC]
ltslimjim Offline
Loc: WatUpDoc
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3563224/
2.1 TBN at 21k
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3134924/
2.4 TBN at 17k (correction not 18k)
He added oil within the last couple thousand miles of each report. As noted, he began using oil at some point after extending his interval out far. So, he either let it get slightly low without topping off and also could have cut the interval short. So, in my usage I'm capping AFE 0w-20 to 15k on my Fit. Maybe if I had a bypass system...
Again, he drove lots of fairly long trips and highway miles. If he were driving in your conditions like this app in the OP shows, it's doubtful that the oil makes it out appearing as good. Note the insols started ticking up as well in the 21k mile report. So, perhaps the 17k run was the sweet spot. Also, the 21k mile longer run yielded higher viscosity numbers than the previous 17k run. As I later mentioned to him reading his report and giving feedback: The oil seemed to be thickening slightly, it shears down to a point over extended use and then thickens up again after becoming overloaded with suspending combustion byproducts/deposit removal or dispersant. Therefore, in theory a bypass system makes this repeatable without leading to functional problems developing, such as perhaps oil control rings becoming stuck from varnishing, etc.
#4466018 - 07/21/17 10:45 AM Re: 2007 Honda Element; 7,189mi; M1 0W20 AFE/EP [Re: EdwardC]
Loc: Chicago, IL
Wow, thanks Itslimjim!
My plan for the current OCI is to run the Maintenance Minder down to 15% twice. The MM seems to do an OK job of accounting for driving and environmental factors. As in, the summer I did a lot of highway miles the MM went to 0% at about 7,500mi, then the winter before, mostly short trips and very cold temps, it went to 0% closer to 6,000mi. Running down to 15% twice should get me in the 10k-13k range, right where I think I want to be (especially since I'm running EP now).
#4466401 - 07/21/17 04:50 PM Re: 2007 Honda Element; 7,189mi; M1 0W20 AFE/EP [Re: EdwardC]
ltslimjim Offline
Loc: WatUpDoc
Your goal sounds reasonable. I'd caution going as long as your QSUD run, but 10 months or 10k is a nice goal of extending the AFE compared to your results here. I'd just watch out for thickening like the QSUD run seemed to do at 11 months despite only 8k. Could likely be the short trips/cold weather service.
