Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
06/17/18 05:37 PM
2019 Honda’s miniMOTOs (125cc)
by DuckRyder
06/17/18 05:18 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
26 registered (bubbatime, bbhero, AVB, clinebarger, bdcardinal, Bryanccfshr, 3 invisible), 1028 Guests and 35 Spiders online.
65258 Members
67 Forums
285502 Topics
#4461300 - 07/16/17 10:30 PM What oil for CR-V 2009? help
Tomo1977 Offline
Loc: USA, Connecticut
Hello Bob is the oil guy forum,
I am here today because I am needing a little advice and pointing in the right direction of what oil to buy for my New to me SUV. I understand in most situations I could normally go to the garage and ask them guys but I am living out in Cambodia at the minute and they will tell me anything to make a sale.
I have a 2009 Honda CR-V EX and she is running like a dream and I plan on keeping this way. Every month I am going to be changing the oil, checking the breaks, water etc all myself. So what oil do I need or what is best for my CR-V?
Some specs:
Make: Honda
Model: CR-V EX
Year:2009
Mileage: 54,439
Engine Cap: 2.4L / 4cyl
Doors: 5
If there is any other information you guys need please just comment below and I will be sure to get back to you all ASAP.
Thanks
#4461307 - 07/16/17 10:37 PM Re: What oil for CR-V 2009? help [Re: Tomo1977]
TmanP Offline
Loc: MN
Welcome to the forum. Clearly, you care about your car (as do most of us on here), but a monthly oil change (unless you drive 50,000 miles a year plus) is overkill. I'd recommend a quality 5w30 (really, nearly all oil is) changed as indicated by your Maintenence Minder. For added peace of mind, you could use a synthetic oil (Mobil 1, Pennzoil Platinum are two good ones), but there's no need. However, you are wise to check your fluids etc. often.
Edited by TmanP (07/16/17 10:40 PM)
2006 Buick Lacrosse 3.8 V6 150,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
#4461314 - 07/16/17 10:44 PM Re: What oil for CR-V 2009? help [Re: Tomo1977]
ag_ghost Offline
Loc: SF Bay Area, CA
Welcome to BITOG.
welcome
Change the oil vvery month? Is this ride in Cambodia? In any event, every Honda I've owned or maintained for the last 27 years has the recommended viscosity on the fill cap.
It may or may not be relevant, but the US owner's manual calls for 5W-20:
http://owners.honda.com/vehicles/information/2009/CR-V/manuals
In normal situations, I tell the garage what to do as do most here...
Kevin
Kevin
63 Galaxie 500, 390; dad bought it new...
99 Accord V6
15 CR-V
04 Accord I4, MT(!)
#4461342 - 07/16/17 11:36 PM Re: What oil for CR-V 2009? help [Re: Tomo1977]
Linctex Offline
Loc: Waco, TX
Are API rated oils available in Cambodia?
I did a google search for "motor oil in cambodia" and came up with Britonoil, Total, Castrol, and Amsoil.
Probably best to avoid Sinopec oil?
#4461361 - 07/17/17 12:35 AM Re: What oil for CR-V 2009? help [Re: Linctex]
zeng Offline
Loc: Malaysia
...... simply because it's a China made oil ?
#4461434 - 07/17/17 06:51 AM Re: What oil for CR-V 2009? help [Re: Tomo1977]
ArcticDriver Offline
Loc: USA
I use Mobil 1 0w20 in both a CRV and an Element.
The CRV is a fantastic vehicle and very low maintenance...but if you use a quality motor oil then no need to change it every month.
For the transmission and differential the best fluids are Honda brand.
Edited by ArcticDriver (07/17/17 06:54 AM)
Multiple Diesel and Gasoline vehicles
#4461667 - 07/17/17 11:28 AM Re: What oil for CR-V 2009? help [Re: Tomo1977]
EdwardC Offline
Loc: Chicago, IL
Unless you're putting down A LOT of miles, you shouldn't need to change the oil monthly. I would use 0W20, I use it in my 2007 Element with a similar engine. Like Arctic Driver mentioned, if it is 4WD, make sure to change out the rear diff fluid with Honda Dual Pump II as well.
We can make suggestions for oil, but it's probably more a matter of what's available to you locally. I'd look for a known brand with a sealed bottle camp (ideally with a foil seal, and if possible an API starburst symbol (although, I don't know how common that is outside of the USA)).
#4461791 - 07/17/17 01:05 PM Re: What oil for CR-V 2009? help [Re: Tomo1977]
ag_ghost Offline
Upon further review, since this thread started life in the passenger-diesel sub-forum perhaps the CR-V in question is equipped with the 2.2 L i-CTDI diesel engine?
OP, please clarify, notably the engine that is installed; also something about intended usage will enable further comments.
Kevin
Edited by ag_ghost (07/17/17 01:12 PM)
Kevin
99 Accord V6
15 CR-V
04 Accord I4, MT(!)
#4463404 - 07/18/17 10:22 PM Re: What oil for CR-V 2009? help [Re: Tomo1977]
aquariuscsm Offline
Loc: Dallas,Tx USA
Pennzoil Platinum 0W20 or 5W20. I do 3/3k like clockwork.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
#4468588 - 07/24/17 05:31 AM Re: What oil for CR-V 2009? help [Re: Tomo1977]
L_Sludger Offline
Loc: Ohio
A monthly oil change does not sound realistic to me.
too many cars and oil combinations to list in 150 characters or less
#4477909 - 08/03/17 01:37 AM Re: What oil for CR-V 2009? help [Re: Tomo1977]
Tomo1977 Offline
I have read through all the above and I am going to go out looking for the brands of oil above. I do-do a lot of driving sometimes upto 300k a day what are your thoughts on that? I have found a CR-V manual online here http://www.used.forsale/onkyo-home-theatre-system it's for the 2010 model will that be the same as the 2009 model I have?
#4479129 - 08/04/17 04:11 PM Re: What oil for CR-V 2009? help [Re: Tomo1977]
DS9 Offline
Loc: Belgrade, Serbia, Europe
#4480678 - 08/06/17 11:13 AM Re: What oil for CR-V 2009? help [Re: Tomo1977]
BJD78 Offline
Loc: Nebraska
I live in Lincoln Ne and have a 2002 CRV and just use what the manual calls for which is 5w20, Bought it used with about 40K on it and it had service records from Honda with regular Honda bulk 5w20 oil.Now has 150K on it with some pretty good oil seepage but no real leaks, maybe have to add half a quart between changes which I can live with. Since I do the bulk of my own maintenance I use the cheapest 5w20 I can find, usually NAPA brand or sometimes Travelers brand which is from TSC farm stores here in Lincoln.I will buy a case when they have their sales. Might be able to find bit a cheaper oil at Wall mart with their House brand but I loath going to Walmarts. I drive the CRV hard at 75 mph 4 days per week in summer heat and winter cold with OCI of about 5K to 6K IMO any regular 5w20 would do very well. Honda CRVs are quite reliable with even minimum maintenance. I have never been to Cambodia, but I would think that since many oil companies have a world wide presence that major brands like Mobil, Shell, or Exon would be available in most countries including Cambodia.
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K using the cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
