1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
47 registered members (anndel, billpace1956, carloz, Brad_C, Ammofirst, BikeWhisperer, 4 invisible), 1,094 guests, and 30 spiders.
Topics296,903
Posts4,961,300
Members66,997
Most Online2,688
Jan 19th, 2019
3.4 toyota sludge prone or no? #4458790
07/13/17 09:14 PM
07/13/17 09:14 PM
NC, USA
spencerdiesel Offline OP
NC, USA
Hey everyone,
I've got a '97 Tacoma with the 5vzfe. 253k on the original engine and I know it's had a rough life. Peering into the valve cover you can see some minor sludging it looks like.
Are 3.4s more susceptible to sludging with extended OCIs and conventional oil? I would like to run 8k OCI, as I drive all highway 70 miles per day.
Right now I'm running semi syn valvoline 5w30.
Thanks yall
Re: 3.4 toyota sludge prone or no? [Re: spencerdiesel] #4458838
07/13/17 10:01 PM
07/13/17 10:01 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
No, I just finished doing my valve cover gaskets on my 3.4 and no sludge at all. The fill hole is NOT a good indicator of the rest of the engine. Also these are not known to sludge but if you have a leak it is most likely the valve covers and it is a easy but long job. Congrats on getting the most reliable engine (non diesel) ever.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: 3.4 toyota sludge prone or no? [Re: spencerdiesel] #4458839
07/13/17 10:02 PM
07/13/17 10:02 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Sludge or varnish? The latter is pretty harmless. If it's sludge, most modern synthetics will do a good job of slowly cleaning it with 5k changes. Of course you can run 8k, just don't expect the sludge change much. As long as it's not chunky, it's probably harmless.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: 3.4 toyota sludge prone or no? [Re: spencerdiesel] #4458844
07/13/17 10:05 PM
07/13/17 10:05 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
Also personally I would not run a semi synthetic that long in this engine. I believe OEM was 3k on conventional. If you suspect neglect then run a few short OCI and then run a synthetic for 10k miles.
Re: 3.4 toyota sludge prone or no? [Re: spencerdiesel] #4458966
07/14/17 05:14 AM
07/14/17 05:14 AM
NY
Oey12 Offline
Oey12  Offline
NY
The 3.4 in my experiences have been extremely clean engine. I have owned multiple Tacomas as well as a 4Runner all with the 3.4. In addition it didn't seem to care what oil you put in them. I really liked the 3.4 motor and that motor should far outlast anything on that truck...my biggest concern with the the Tacoma is frame rust.
Re: 3.4 toyota sludge prone or no? [Re: Oey12] #4459043
07/14/17 06:51 AM
07/14/17 06:51 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Originally Posted By: Oey12
The 3.4 in my experiences have been extremely clean engine......
Ditto. 3.4L timing belt engine very easy on oil, reliable and no sludger ime. Don't be fooled by the valve cover baffle at the fill hole that can be misleading, not an indication of valvetrain appearance and condition.
As for Tacoma frame rust, ime very location specific. Very little salt used here so no worries on an 01. Some were repurchased by Toyota in northern climes.
Re: 3.4 toyota sludge prone or no? [Re: spencerdiesel] #4459292
07/14/17 12:31 PM
07/14/17 12:31 PM
SC
leemajors Offline
leemajors  Offline
SC
Yep--the baffle under the fill cap holds a little oil that sludges up but thats not indicative of whats beneath.
The maintenance interval in my little booklet shows 5k for severe service (towing, dusty, etc.) and 7.5k for normal conditions. I just stick w/ ~5k no matter what (hot weather, lots of hwy miles)--clean oil is cheap insurance. After I got my gaskets and seals changed out I use nothing in a 5-6k interval.
2007 Toyota 4Runner 131k mi
Toyota YZZD3/PP 5w30
2000 Toyota 4Runner 204k mi
NAPA Gold 1516/Castrol GTX 5w30
Re: 3.4 toyota sludge prone or no? [Re: leemajors] #4459324
07/14/17 12:57 PM
07/14/17 12:57 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
If it looks like this:
Then that's not sludging at all, it is how the baffle is supposed to look (it is a coating). On a lot of older Toyota engines you cannot see the engine internals through the fill hole, you have to remove the valve cover to see anything.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: 3.4 toyota sludge prone or no? [Re: kschachn] #4459352
07/14/17 01:27 PM
07/14/17 01:27 PM
SC
leemajors Offline
leemajors  Offline
SC
On the 5vz-fe it looks a little different--you can see past it a little bit. Mine has a bit of crustiness on it that isn't consistent so it doesn't appear to be a coating. I just always assumed it was some oil that was trapped behind it from spinning cams and the heat cycles had sludged it a bit.
Either way, I'm agreeing with you that it's almost impossible to judge sludge from the 5vz-fe fill cap.
Edit:
Here's mine at least. You can see varnish underneath and the crust just looks like captive sludge. Either way, no big deal.
Re: 3.4 toyota sludge prone or no? [Re: spencerdiesel] #4459355
07/14/17 01:33 PM
07/14/17 01:33 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Any engine that's neglected will sludge. My old 3.4L in my 2002 Tacoma was spotless. 190K at trade in.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: 3.4 toyota sludge prone or no? [Re: spencerdiesel] #4459369
07/14/17 01:51 PM
07/14/17 01:51 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Originally Posted By: spencerdiesel
Hey everyone,
Thanks yall
Mind posting a picture of what you see under the valve cover? Anyone can do it. You can even upload pictures to this website.
too many cars and oil combinations to list in 150 characters or less
Re: 3.4 toyota sludge prone or no? [Re: spencerdiesel] #4459386
07/14/17 02:02 PM
07/14/17 02:02 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
It is a pretty intensive job to get the valve covers off. If I knew how to upload pics I would of mine with 240k. Looks really good.
Re: 3.4 toyota sludge prone or no? [Re: spencerdiesel] #4460955
07/16/17 12:39 PM
07/16/17 12:39 PM
NC, USA
NC, USA
Lot of informative responses. I feel better now, leemajors mine looks very similar to your pics you posted. TheKraken, why do you not recommend running 8k on the syn blend?
Keep the talk coming
Re: 3.4 toyota sludge prone or no? [Re: spencerdiesel] #4460981
07/16/17 01:19 PM
07/16/17 01:19 PM
MD
claluja Offline
claluja  Offline
MD
I've got a 3.4 in my 97 4runner with 300+k, and my oil doesn't even change color until about 4k into each OCI (I run dino Pennzoil 5w30 HM - have never put synthetic in her). OCI i tend to 6 or 7k. Like someone said above, rust is the real issue. Valve cover gaskets and rear main like to leak oil, but I still haven't replaced mine yet (just tighten the valve covers down once a year or so).
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
2018 Jeep Rubicon, Pentastar 3.6L
Re: 3.4 toyota sludge prone or no? [Re: spencerdiesel] #4461102
07/16/17 04:37 PM
07/16/17 04:37 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
If it looks like Lee Majors' picture, then I'd propose that what you saw is mere varnish, which is unsightly but functionally not harmful.
Therefore, no cause for concern, in my opinion.
