Originally Posted By: TheKracken
Originally Posted By: Nick1994
Not sludge, but I think the 3.4L is known to blow head gaskets. So maybe coolant is getting into the oil and sludging?
3vz fe (3.0) is known to blow head gaskets. Not the 3.4 (5vz fe). Absolutely amazing motor and pretty easy to work on. Doesn't mean its not possible but not a known issue.
OP, if you want to run the oil 8-10k go for it. I am sure the oil is good for it. I personally run 5k OCI on my 3.4 but it is not rusting to [censored] and I plan to own it for a long while.
The 3.4 5VZ-FE had head gasket issues. In fact, my Dad had a 1995 T100 with the 5VZ-FE that had the head gaskets replaced under a Toyota special service campaign.
Good engine, but no, not exempt from head gasket problems.
