set for years
by 93cruiser
1 minute 33 seconds ago
Looking to replace 2005 Sienna with SUV
by i6pwr
43 minutes 22 seconds ago
Trying to fix chainsaw
by turtlevette
Today at 06:48 PM
tire rotation
by marine65
Today at 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
Today at 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
Today at 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
Today at 06:00 PM
New belt squeal cause damage to belt?
by pda1122
Today at 05:33 PM
Food Safety - If You Have Children
by Zee09
Today at 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
Today at 05:02 PM
Chain cleaning and lube
by dadinfo
Today at 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
Today at 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
Today at 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
Today at 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
Today at 04:30 PM
mobil 1 rebate check
by Fitter30
Today at 03:52 PM
Cab mount failure
by ram_man
Today at 03:31 PM
02 Saab aero oil?
by Newuser
Today at 03:00 PM
Extend wifi range
by clarkflower
Today at 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
Today at 01:57 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
102 registered (93cruiser, 69Torino, 14Accent, 2015_PSD, 2004tdigls, 12 invisible), 1519 Guests and 62 Spiders online.
65303 Members
67 Forums
285875 Topics
Page 1 of 2 1 2 >
#4457264 - 07/12/17 01:12 PM Used Oil Color - Black-ish vs. Red/Orange-ish
1JZ_E46 Offline
Loc: Oregon
I run nearly the same oil in our two daily drivers. EDGE 0W-30 goes in the Mini and EDGE 0W-40 goes in my X5. Both oils are PAO based with essentially identical add-packs.
I've noticed the color of the oil (when checking the dipstick on a white cloth) is more black-ish in the Mini and more red-ish coming out of my X5. I've had the valve cover off of the Mini, and it looks like brand new cast aluminum (strict 5k oil change schedule since new). The X5 is near spotless, but if I really look in there with a flashlight, I can see a bit of orange/brown varnish on the aluminum casting (was on a 10k schedule until about 55k miles, been 5k since). Is this the source of the orangish oil color? Is the 0W-40 slowly cleaning it?
Both engines are similar in that they are gas, non-Turbo, port-injected, with BMW VANOS and Valvetronic, but with the X5 engine being 3 times the displacement.
2007 BMW X5 4.8i, 105K: Castrol EDGE 0W-40, Mann
2012 Mini Cooper, 45K: Castrol EDGE 0W-30, Mann
#4457267 - 07/12/17 01:16 PM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: 1JZ_E46]
Vladiator Offline
Loc: NC
When I came to this board with similar question - I was told that the reddish color of oil is the result of varnish clean up that takes place inside the engine.
Thicker oils give protection for severe operations such as driving in mountains, pulling a boat, dusty conditions, short trips, high rpm, overloading, overheating and overcooling. Thin oils give MPG.
#4457323 - 07/12/17 02:29 PM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: Vladiator]
Trav Offline
Loc: MA, Mittelfranken.de
+1 Its not from only under the valve cover but the pistons get a lot of varnish on them, when you see red its varnish being removed from the engines internals which is a good thing.
#4457350 - 07/12/17 02:56 PM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: 1JZ_E46]
Donald Offline
Loc: Upstate NY
Oil color might get your curiosity up, but no conclusions should come from oil color unless it's milky.
UOA is the only way.
Edited by Donald (07/12/17 02:57 PM)
2015 Ford F250 w/Powerstroke
#4457354 - 07/12/17 03:03 PM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: Donald]
1JZ_E46 Offline
Loc: Oregon
Thanks. Sounds like the oil is doing its job cleaning. There's probably nothing to clean on the Mini engine, so all I'm seeing is the suspended soot.
Agreed. I'll be getting one next go around for both cars. Curious how well the oil holds up to our 90+% stop-go city driving with lots of elevation change.
#4457651 - 07/12/17 08:26 PM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: Donald]
Ducked Offline
Loc: Taiwan
UOA is the only way to what?
#4457742 - 07/12/17 09:59 PM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: Ducked]
Coprolite Offline
Loc: Houston, TX
The only way to see elemental PPMs...
#4457796 - 07/12/17 11:35 PM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: Coprolite]
Ducked Offline
Loc: Taiwan
The OP has given no indication that he's interested in elemental PPM's.
He's interested in why his oil looks red, and elemental PPM's are unlikely to be relevant (unless its rust).
I dunno enough about UOA's to say whether they'll give him clues on that, but I suspect not.
I THINK they sometimes do a centrifugation which might show up some sedimenting oxidation products which might be varnish precursors.
These can also show up on a millipore filter patch test, or even on a blotter spot test, if you can interpret it, but (a) I don't think these are part of standard UOA's, and (b) IIRC (don't have time to look it up now) varnish precursors are often in true solution, so may not show up by any of these methods.
Colour changes in true solution, which may be indicators of varnish formation or removal, are quantified by Fourier Transform Infrared Spectroscopy, but that isn't provided by a standard UOA either.
Edited by Ducked (07/12/17 11:49 PM)
#4457829 - 07/13/17 01:50 AM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: 1JZ_E46]
Bailes1992 Offline
Loc: South Wales, UK
I'm currently having the same issue with my partner's VW Polo. Everything has an orange varnish to it and a few hundred miles after I've changed the oil it turns the same orange.
However, are you sure EDGE 0w40 is PAO based? If you look up the German label of 0w40 A3/B4 it says "HC-SYNSTHE" which I'm sure makes it a Group III oil. Not that I'm saying it's a bad oil!
'13 Suzuki Jimmny - '16 Dacia Duster 1.5DCi 4WD
'96 LR Defender 300TDi - '12 BMW 320d
Engine Oil - Fuchs Titan XTL GT1 5w40
Gearbox Oil - Fuchs Sintofluid 75w80
Diff Oil - Fuchs Sintopoid 75w90
#4457941 - 07/13/17 07:52 AM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: Ducked]
Coprolite Offline
Loc: Houston, TX
Ducked, calibrate your sarcasm detector. I was agreeing with you on the applicability in this situation.
smile
#4458096 - 07/13/17 10:24 AM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: Bailes1992]
1JZ_E46 Offline
Loc: Oregon
According to this U.S. SDS from March 2017, it appears to be a PAO based oil.
Also, regarding your HC-Synsthe comment, EDGE 0W-40 on Amazon.de (Germany) says Vollsynth (fully synthetic).
Edited by 1JZ_E46 (07/13/17 10:26 AM)
#4458130 - 07/13/17 10:57 AM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: 1JZ_E46]
1JZ_E46 Offline
Loc: Oregon
I just translated some of the comments from the German Amazon page, and there were three from June 2017 stating that they received HC-Synsthe. However, I still believe what we have here in the U.S. is still PAO based on the most recent SDS sheet available. Maybe they rolled out a new formula to Germany first and it will be making its way here shortly...
Edited by 1JZ_E46 (07/13/17 11:02 AM)
#4458689 - 07/13/17 08:08 PM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: 1JZ_E46]
BrocLuno Offline
Loc: Kalifornia Kollective
well, we actually need to know. I don't buy oils like this for any other reason that they are >50% PAO so they can be used as cleaners in an engine. If it's going to the marketing dept to sell just Group III, might as well look elsewhere ...
#4458695 - 07/13/17 08:15 PM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: 1JZ_E46]
Shannow Online   content
Loc: 'Stralia
Actually PAO is probably one of the worst oils for cleaning...it's not a good solvent.
#4458797 - 07/13/17 10:18 PM Re: Used Oil Color - Black-ish vs. Red/Orange-ish [Re: Shannow]
1JZ_E46 Offline
Loc: Oregon
Based on the recent U.S. SDS I posted, I don't see how it's not a Group IV PAO based oil.
Not really an issue unless your really trying to de-sludge/varnish an old engine. For that I would probably choose PUP.
Now a PAO / GTL oil, that would be killer cool
Edited by 1JZ_E46 (07/13/17 10:20 PM)
Page 1 of 2 1 2 >
