Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
55 registered members (biron, 94astro, BeerCan, bigal51, Astro_Guy, 4 invisible), 1,158 guests, and 47 spiders.
Topics295,173
Posts4,929,151
Members66,700
Most Online2,553
Oct 27th, 2018
Which inline filter #4454648
07/09/17 07:15 PM
07/09/17 07:15 PM
Sav ga
NStuart Offline OP
NStuart  Offline OP
Sav ga
I spent over 4k when I built my 46re in my dodge,sometimes I tow a little heavy. it has about 20k on the tranny with a deep pan and 2 coolers Total 16 quarts and I have done multiple drain and fills at least 4. I am going to put an inline filter on it with a 3/4-16 thread I already bought an xg8a filter but I keep reading about the Baldwin b2-hpg. I am open to other suggestions ,the first filter will only be on for about 1k miles
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Which inline filter [Re: NStuart] #4454650
07/09/17 07:16 PM
07/09/17 07:16 PM
Sav ga
NStuart Offline OP
NStuart  Offline OP
Sav ga
And when I say tow heavy I pulled 66,000 lbs 2 miles a few weeks ago, yes 66k
08 husky sm610 t6
Re: Which inline filter [Re: NStuart] #4454655
07/09/17 07:22 PM
07/09/17 07:22 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Although I like the Baldwin filters I don't thi k there's anything to gain over the XG8A. You're not helping anything by changing it so early though. It could easily go 15,000 miles on a transmission and it will get more efficient with time. The transmission should have far less dirt load on the filter than an engine and that filter is rated to 15,000 on an engine. Run it longer than 1,000.
Luke
Re: Which inline filter [Re: NStuart] #4454664
07/09/17 07:36 PM
07/09/17 07:36 PM
Waco, Tx.
Syntheticuser Offline
Waco, Tx.
Lemme tell ya, locked in 4 low, these little trucks have some torque. They will pull given the traction. I pulled a propane truck 150 yards, when it had rained heavy and he couldn't make it up the gravel road to the neighbor's house. I used my dually crew cab 4x4 Ford. Worked great.
Re: Which inline filter [Re: NStuart] #4454902
07/10/17 02:14 AM
07/10/17 02:14 AM
Sav ga
NStuart Offline OP
NStuart  Offline OP
Sav ga
I have read some posts where I thought guys said the initial trans filter stops up quickly.
The reason I have changed the fluid so much is bc there has been lots of visible metal, it shifts hard( shift kit) it has definitely improved, since break in
08 husky sm610 t6
Re: Which inline filter [Re: NStuart] #4454906
07/10/17 03:10 AM
07/10/17 03:10 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
One XG8A wil handle EVERY SINGLE BIT of any debris the transmission might or could produce.
I will say this - - - if your transmission EVER makes or produces enough "stuff" that an XG8A needs to be changed..... it's all done for.
Re: Which inline filter [Re: NStuart] #4455028
07/10/17 07:28 AM
07/10/17 07:28 AM
Sav ga
NStuart Offline OP
NStuart  Offline OP
Sav ga
Lol I like the way you said that
08 husky sm610 t6
