2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
2003 Honda power steering problem
by hogpops
06/24/18 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
06/24/18 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
06/24/18 03:21 PM
Castrol 0W40 vs 5W40??
by Realfine69
06/24/18 03:02 PM
Paint impurities on a new car
by Quattro Pete
06/24/18 02:49 PM
2014 Ram wheel FIT on a 2005 Ram?
by SumpChump
06/24/18 02:41 PM
Do people buy from telemarketers?
by Chris142
06/24/18 02:06 PM
TGMO 0W20, 8100km/5mo, 2013 Lexus GS350AWD 118K KM
by David_Corbett
06/24/18 01:54 PM
Sonoma Raceway
by Warstud
06/24/18 01:51 PM
Zipcode error
by aquariuscsm
06/24/18 01:36 PM
NHRA drag racing Racing question??
by daddi
06/24/18 01:33 PM
Milesyn 5w30 5 gal pails $50.94 w/prime
by Samrsnow
06/24/18 01:20 PM
Removing Broken Bathtub Drain
by Warstud
06/24/18 01:15 PM
Buffer Pads
by TheLawnRanger
06/24/18 01:10 PM
Recommend an oil to me... Pennz, M1, Castrol...?
by chinee
06/24/18 12:39 PM
Filter for Hydro Gear ZT2800 - Toyota???
by Lancruza
06/24/18 12:39 PM
Motul 5W30, 3000KM/12 mo, 06 Acura RSX-S 161K KM
by lemaitrix
06/24/18 12:38 PM
DeWalt dcf887b 3spd impact driver
by JC1
06/24/18 12:34 PM
crrider, EdDmax, 2018matto, Lancruza, IanSampson
65312 Registered Users
92 registered (55hambone, aquariuscsm, 93cruiser, 2018matto, 97prizm, Altima2, 5 invisible), 1609 Guests and 43 Spiders online.
65312 Members
67 Forums
285927 Topics
#4454142 - 07/09/17 09:44 AM Napa ProSelect Oil Filters
ChesterCopperpot Offline
Loc: West Virginia
Hello All,
Is there a general consensus regarding the overall quality/reliability of the Napa ProSelect Oil filters? I know that there has been talk about filtering efficiency being below some standards as well as the combo valve used for ADBV/Bypass. I've seen a lot of complaining/concerns about the combo valve but haven't seen or heard any "true" failures. Additionally, I noted that this combo valve has been in use for some time, I almost want to say since 2007 based on the revision of the technical bulletin on the web. I would think if there was some serious issues with this design, the manufacturer (Wix) would have likely changed the design. Your input is greatly appreciated.
BTW, I only ask because I have access to a box of these on the real cheap and was wondering if they are ok to use for my application. My OCI's are generally 4500-5000 miles. 2012 Ram 1500 5.7L (Napa 27899).
Thanks!
#4454185 - 07/09/17 10:47 AM Re: Napa ProSelect Oil Filters [Re: ChesterCopperpot]
Linctex Offline
Loc: Waco, TX
I really haven't heard anything bad about them.
I believe the SuperTech at walmart is now a "Pro Select"
If you are worried about low efficiency at all,
then maybe it's best to spend another $3-$4 on a better filter.
#4454193 - 07/09/17 10:57 AM Re: Napa ProSelect Oil Filters [Re: ChesterCopperpot]
Run Offline
Loc: Canada
I would avoid the proselects that use the combo adbv/bypass valve. I noticed more start up noise with those filters. Every proselect I cut open had a fairly stiff valve even after 3000 miles.
03 Neon 2.0 - VSP 5W-30 Pentius XL
#4454201 - 07/09/17 11:07 AM Re: Napa ProSelect Oil Filters [Re: ChesterCopperpot]
slacktide_bitog Online   content
Loc: USA
welcome
The Proselect will be fine for 5k smile
#4454202 - 07/09/17 11:09 AM Re: Napa ProSelect Oil Filters [Re: ChesterCopperpot]
Rolla07 Offline
Loc: MTL, CANADA
I use them regularly. Filter construction is A1. Efficiency on some OEM filters is low ie Toyota OEM and you dont hear many Toyota owners having issues related to filter efficiency.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4454311 - 07/09/17 02:12 PM Re: Napa ProSelect Oil Filters [Re: ChesterCopperpot]
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
Help save the landfills by buying the mid-level Frams and mid-level Wix, then use it for two 5K OCIs. That would also include the NAPA Golds.
#4454312 - 07/09/17 02:13 PM Re: Napa ProSelect Oil Filters [Re: ChesterCopperpot]
blupupher Offline
Loc: Katy, Republic of Texas
How cheap is real cheap? If less than $2.85 each, then they are a deal and fine for a 5000 mile OCI.
The reason for the $2.85 cut-off price, that is the price of the SuperTech filters at Walmart that are the same thing.
I have a ST2 (same as the 27899) on my truck right now with no concerns. While some complain about the unknown efficiency @ 20 microns (estimated by some to be around 68%), it is at least as good as most OEM (Toyota, Hyundai and estimated around 50% @ 20 microns from what I have read). Others complain about the combo-valve. While I am not crazy about it, it works and has not caused any issues that I know of for me.
I think it could be a problem in extreme cold and long intervals due to it being nitrile, but for me (almost never gets even too freezing, much less below it, and ~5000 mile intervals) it is fine.
Why are you putting you filters into the landfill? AZ, AAP, O'Reilly all take used filters around here, as do many city and county facilities.
For me, I cut them open and all metal goes into recycle bin. Media itself (with almost no oil left on it) goes into regular trash, although I have been debating using it as fire kindling out at the lake.
1994 Honda VT1100C: Peak 15w-40/TG/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
#4454350 - 07/09/17 02:55 PM Re: Napa ProSelect Oil Filters [Re: ChesterCopperpot]
CT8 Offline
Loc: Idaho
All that really matters about an oil filter is that doesn't fail. The air filter is what is important for long engine life.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4454482 - 07/09/17 05:24 PM Re: Napa ProSelect Oil Filters [Re: blupupher]
Loc: West Virginia
I'm getting them for free from a friend that no longer needs them. I didn't want to take them if they were a substandard filter. I do generally use Napa Golds. Sounds like its an acceptable filter based on the consensus so far...
Thanks for the input.
#4454489 - 07/09/17 05:31 PM Re: Napa ProSelect Oil Filters [Re: ChesterCopperpot]
Marco620 Offline
Loc: Deplorable Kansan,HK fan!
Napa PS ran rough in my Hyundai,went Gold and no problem.Also like Fram Ultra or M1 and Royal Purple oil filters.
2015 Civic 162k mi.0w20 Redline/Archoil,HPS SRI,Yokohama/Moog links Borla Exhaust/Vibrant Resonator/Tein Suspension
Go Nashville Predators!
#4454680 - 07/09/17 08:59 PM Re: Napa ProSelect Oil Filters [Re: CT8]
bbhero Offline
Loc: Virginia
Makes sense to me CT8. Which air filter do you use??
Very good job here OP. I thought it could be a Fram TG like CT8 thought as well.
Nissan Altima 3.5 Coupe Valvoline Advanced Full Synthetic 5w30 Federated Auto 4612ex
"Treat your family like your friends and treat your friends like your family."
#4454755 - 07/09/17 10:11 PM Re: Napa ProSelect Oil Filters [Re: ChesterCopperpot]
blupupher Offline
For that price, I would definitely use them for a 5k interval.
