Ghetto testing a wheel speed sensor
by Nayov
06/24/18 06:23 AM
dash cam
by DAC2018
06/24/18 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
76 registered (andyd, Astro14, 2009Edge, 1foxracing, 4WD, 6 invisible), 1149 Guests and 71 Spiders online.
65303 Members
67 Forums
285891 Topics
Page 1 of 2 1 2 >
#4453502 - 07/08/17 02:44 PM Wrong Oil Filter
C4Dave Offline
Loc: Tennessee
I recently purchased a 2002 Ford Expedition with the 4.6 V-8. Changed the oil and filter today and discovered that the old filter was significantly smaller than the new filter. The old filter had been in place for 5000 miles.
Went to Fram's website and compared the specs. The small filter is rated at 10-12 gpm flow and relief valve setting of 9-12 psi. The correct filter was rated at 11-13 gpm and relief of 12 psi.
Thread size was identical and gasket size was within about 1 mm. The small filter was not leaking when removed.
The new filter is speced for many GM and Dodge vehicles, among others. Some of the models include the GM 5.3 and Dodge 5.7 V-8's.
Being smaller, it was certainly easier to remove. With the large filter the front wheels have to be turned to clear the pitman arm.
Any reason I shouldn't use the smaller filter going forward?
#4453515 - 07/08/17 02:57 PM Re: Wrong Oil Filter [Re: C4Dave]
Donald Offline
Loc: Upstate NY
I would use the recommended filter big or small. Probably would not matter but I like to use the proper part.
2015 Ford F250 w/Powerstroke
#4453530 - 07/08/17 03:12 PM Re: Wrong Oil Filter [Re: Donald]
Kira Offline
Loc: Champlain/Hudson Valley
+1 on the proper part. Motorcraft FL820S, no?.
Look up what WIX and Hastings have listed for that application.
#4453543 - 07/08/17 03:26 PM Re: Wrong Oil Filter [Re: C4Dave]
Panzerman Offline
Loc: Port Orange, Florida
What you were seeing is the new Ford filter alot of oil change places are using. I think it's the FL500 filter.
It's sort of a one filter fits all Fords so it cuts on inventory. Being that I had alot of 4.6 L Fords. The 820S is the correct filter but the new smaller filter will suffice. I found out about all this when I bought my Ford F150 with the 5.4 L engine and found the small filter and was exactly like you [censored]. I researched it and it's what I found out.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
#4453547 - 07/08/17 03:32 PM Re: Wrong Oil Filter [Re: C4Dave]
Eddie Offline
Loc: Florida, Cape Coral
I am also of the opinion that one should used the recommended filter. Ed
CX5 Touring 2.5L :-)
#4453555 - 07/08/17 03:42 PM Re: Wrong Oil Filter [Re: C4Dave]
C4Dave Offline
Loc: Tennessee
On Fram's site, it doesn't list any Ford applications for the small filter. Part # is PH10060. Mostly GM, Chrysler/Dodge/Jeep, and several other makes. But no Ford's, not that it really matters.
Edited by C4Dave (07/08/17 03:47 PM)
#4453558 - 07/08/17 03:50 PM Re: Wrong Oil Filter [Re: C4Dave]
bdcardinal Offline
Loc: Santa Barbara, CA
FL-820S is the filter you should be using. A lot of quick lubes use the equivalent of the FL-500S. FWIW we have had a couple engines go south that had the wrong filter installed by a quick lube and the quick lube ended up paying for it. Ford's opinion was the wrong filter was installed regardless of what their interchange said.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#4453621 - 07/08/17 05:27 PM Re: Wrong Oil Filter [Re: C4Dave]
Linctex Online   content
Loc: Waco, TX
The "FL-500" size filter you took off (Fram TG and XG 10575) will eventually phase out the FL-820 size filter (Fram TG2 and XG2)
You have nothing to worry about.
The smaller filter is used on the Coyote engines in the Mustangs - your engine puts out maybe 1/3 the HP theirs do!
Here's a TG10575 (the small one you have nothing to worry about) that was run for 15,000 miles:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4426839/
Edited by Linctex (07/08/17 05:28 PM)
Edit Reason: darn typos
#4453671 - 07/08/17 06:27 PM Re: Wrong Oil Filter [Re: C4Dave]
Panzerman Offline
I don't think they will phase out the XG2/820s type filters because now that Dodge switched to metric threads that's also the same filter for thier Hemi line of motors.
#4453674 - 07/08/17 06:29 PM Re: Wrong Oil Filter [Re: C4Dave]
Panzerman Offline
I have a company truck with the 4.6 motor and have to get the oil changed at Firestone and it's the small filter in it. 230,000 miles and still going but also a reason I like changing my own oil too.
#4453791 - 07/08/17 08:46 PM Re: Wrong Oil Filter [Re: C4Dave]
WellOiled Offline
Loc: Houston, Texas
The last time I used Firestone, they used the wrong viscosity oil. They also used a Firestone TF-4651. It was my first eCore on the Ranger. Firestone did make it right. I don't trust them any more.
The eCore with combo valve loses ADBV function in less than 3000 miles. The Ranger does not seem to care.
I think your 4.6L would do better with an independent ADBV.
2004 Ford Ranger 4.0L V6
NAPA Full Synthetic 5W30 + Fram Tough Guard
#4453830 - 07/08/17 09:40 PM Re: Wrong Oil Filter [Re: C4Dave]
merconvvv Offline
Loc: il usa
Buy some fl 820s at walmart and carry them in the vehicle.
Thats what i do. They are a bargain. Pain to get on off sometimes.
Smaller one probably a lot easier.
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
#4453884 - 07/08/17 10:46 PM Re: Wrong Oil Filter [Re: Panzerman]
Hootbro Offline
Loc: DELAWARE
All the Hemi 5.7 and 6.4's with the exception of a few SRT engines, have gone over to a smaller FRAM PH10060 size equivalent filter. FL820 may fit and is what I ran in my 2015 RAM, but it is not cataloged for FCA Hemi engines.
2018 Jeep Wrangler JL 3.6L (Idemitsu 0W-20)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
#4453930 - 07/08/17 11:59 PM Re: Wrong Oil Filter [Re: C4Dave]
Nyogtha Offline
Loc: San Antonio, TX
Only true for 2013 and later MY Ram Hemi with electric power steering. My 2012 MY Ram Hemi and earlier years not spec'd for the MO-090 (PH16 equivalent) are spec'd for MO -899 (PH2 equivalent) I think it was 2009 MY the switch from SAE thread to metric thread began.
Edited by Nyogtha (07/08/17 11:59 PM)
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
#4453936 - 07/09/17 12:16 AM Re: Wrong Oil Filter [Re: Nyogtha]
dnastrau Offline
Loc: PA
Our '08 Jeep Commander 4.7 has the metric threads so it takes the MO-899 and equivalents (FL820S, PH2, etc.) The owner's manual states that as well. Maybe '08 was a transition year as I have seen application listings showing both the SAE and metric threaded filters for '08 on the 4.7 and 5.7.
Page 1 of 2 1 2 >
