Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
Cadillac CT5 Revealed
by E365. 03/18/19 01:36 AM
Scored free 0w-20 semi synthetic
by pdxglocker9mm. 03/18/19 01:13 AM
TomRx, Ozdave, Rod1701, Arbitrader, Djdecember
67545 Registered Users
114 registered members (ABerns, 65convertible, addyguy, 928, AdditiveOCD, 9 invisible), 2,296 guests, and 60 spiders.
Topics286,013
Posts4,900,707
Members67,545
Most Online2,967
Mar 10th, 2019
6L80 #4451609
07/06/17 06:26 PM
07/06/17 06:26 PM
Kentucky
JeePing Offline OP
JeePing  Offline OP
Kentucky
Any one installed an external oil filter in one of those transmissions? Dropped the pan on my 2015 sierra with only 35k miles had a nice coat of metal glitter built up all on the inside, magnet was pretty loaded as well. Nothing out of the ordinary, but still, makes one wonder if an external filter would be a good addition. Plenty of room to plumb one some place just not sure if tapping into a cooler line is a good idea.
If it an't broke, take it a part and see why not.
Re: 6L80 [Re: JeePing] #4451614
07/06/17 06:33 PM
07/06/17 06:33 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Is this the first oil change
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 6L80 [Re: JeePing] #4451623
07/06/17 06:38 PM
07/06/17 06:38 PM
Kentucky
JeePing Offline OP
JeePing  Offline OP
Kentucky
Yep
Re: 6L80 [Re: JeePing] #4451625
07/06/17 06:39 PM
07/06/17 06:39 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
First change will have more material due to breaking in. An external transmission cooler, or larger one, would add more life than a external filter.
yup
Re: 6L80 [Re: JeePing] #4451628
07/06/17 06:43 PM
07/06/17 06:43 PM
Kentucky
JeePing Offline OP
JeePing  Offline OP
Kentucky
Jim I would have to respectfully disagree, factory cooler is an excellent heat exchanger. External unit will add no benefit.
Re: 6L80 [Re: JeePing] #4451641
07/06/17 07:01 PM
07/06/17 07:01 PM
BC, Canada
userfriendly Offline
BC, Canada
How is the material on the bottom of the pan going to get to the remote filter without being trapped in the internal filter?
I think the solution, if there is a problem, is to install a drain plug on the bottom of the oil pan.
Re: 6L80 [Re: userfriendly] #4451649
07/06/17 07:17 PM
07/06/17 07:17 PM
Kentucky
JeePing Offline OP
JeePing  Offline OP
Kentucky
Its the materiel that internal filter isn't catching that I'm trying to filter out.
Re: 6L80 [Re: JeePing] #4451811
07/06/17 09:55 PM
07/06/17 09:55 PM
Canada
i_hate_autofraud Offline
Canada
If there's clearance in the pan I'd add extra magnets, filters can't catch the small stuff, and getting
metal particles out of the oil helps prevent wear, sticking and other damage in the tight clearances
of the valve body.
GM already admitted they used crummy magnets in a whole slew of trannies, search "4T65E magnet" there's a
GM TSB that covers several GM models.....
Re: 6L80 [Re: JeePing] #4451892
07/06/17 11:25 PM
07/06/17 11:25 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The factory in pan filter is maybe 100 microns at best. It's pretty coarse.
I added a 10 micron inline spin on WIX filter from my spare "hydraulic log splitter parts stash". If you need a filter & filter head, I'll sell you one cheap.
Re: 6L80 [Re: JeePing] #4451949
07/07/17 01:58 AM
07/07/17 01:58 AM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
As long as the the new filter doesn't add any leaks the extra filtration is only a positive especially if you using some very efficient like a Fram Ultra which can hit 80% @ 5 microns, much better than the internal felt fitler
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: 6L80 [Re: JeePing] #4452026
07/07/17 06:43 AM
07/07/17 06:43 AM
Kentucky
JeePing Offline OP
JeePing  Offline OP
Kentucky
Ok at this point does any one know or have a fluid flow diagram of this trans? Adding a ~15 psi restriction inline with the cooler will have any adverse effect on how transmission operate?
Linctex, what transmission you installed your filter on?
Re: 6L80 [Re: JeePing] #4452029
07/07/17 06:51 AM
07/07/17 06:51 AM
BC, Canada
BC, Canada
How much pressure do you have now in your cooler lines?
Re: 6L80 [Re: userfriendly] #4452034
07/07/17 06:55 AM
07/07/17 06:55 AM
Kentucky
JeePing Offline OP
JeePing  Offline OP
Kentucky
Don't have a clue, was hoping to get lucky and someone with knowledge of this trans would give me an answer. Doesn't look like it, have to go digging on google.
I don't know if that fluid is used to operate the trans/perform other functions with in it, or it just simply dumps back in the sump.
Re: 6L80 [Re: JeePing] #4452180
07/07/17 09:57 AM
07/07/17 09:57 AM
BC, Canada
BC, Canada
The filter may reduce flow to the cooler, will this affect your warranty or cause the transmission to overheat?
We are not talking using 5W30 instead of 0W20 here, this is a visible modification to the vehicle.
Re: 6L80 [Re: JeePing] #4452279
07/07/17 12:01 PM
07/07/17 12:01 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Where on earth did you get that info from?!?!?!!?
There is ZERO restriction.
It's the same filter used on a freakin' 16HP log splitter, with like 8-10 gpm flow or something like that!
It's on a 4R75E, but with 3/4 NPT ports it'll flow as well as any big truck/bus trans would need!
