PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
107 registered members (69GTX, arowbat, 69Torino, 2018matto, 2012AccentSE, 16 invisible), 1,931 guests, and 57 spiders.
Topics286,181
Posts4,903,706
Members67,574
Most Online2,967
Mar 10th, 2019
check for level vehicle #4449080
07/04/17 07:39 AM
07/04/17 07:39 AM
Iowa
mickalo Offline OP
mickalo  Offline OP
Iowa
hope everyone has safe & fun 4th of july smile
anyhow was wondering about checking the vehicle is fairly level when checking trany fluid when doing a ford 5r55s trany. sure many know you have to do underneath. just did a fluid filter change last weekend and just measured from the ground up to running boards, front & rear each side, while it was up on ramps. was pretty close but was wondering is there a better way to check to make sure vehicle level either on a flat surface or up on ramps?
TIA
2010 Ford explorer 4.0L sohc 4wd 5w-30 Full Syn.
Re: check for level vehicle [Re: mickalo] #4449098
07/04/17 08:07 AM
07/04/17 08:07 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I do transmission work, gear oil changes, and transfer case fluid changes on level ground on 4 ramps, all the same size, so it's level to begin with. If I'm working and need the vehicle level because it was jacked, and on stands I have a little bubble level which I place on a flat level surface on the vehicle and check with that.
God Bless Our Troops
Re: check for level vehicle [Re: mickalo] #4449103
07/04/17 08:12 AM
07/04/17 08:12 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Eyeball.
The "thinking" man's friend.
Re: check for level vehicle [Re: Lubener] #4449108
07/04/17 08:18 AM
07/04/17 08:18 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Originally Posted By: Lubener
Eyeball.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: check for level vehicle [Re: demarpaint] #4449135
07/04/17 08:37 AM
07/04/17 08:37 AM
Iowa
mickalo Offline OP
mickalo  Offline OP
Iowa
I was thinking about using a small bubble level maybe on the floor behind the front seats might try that next time.
I pretty much eye balled it last time and it was pretty close, even after I measured it, just like to make sure when checking the trany fluid she's close to level as possible. These ford's 5r55s tranys can be real finicky about fluid level.
Re: check for level vehicle [Re: mickalo] #4449149
07/04/17 08:46 AM
07/04/17 08:46 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Eyeballing works, sometimes I tend to over do it. You're in good company!
Re: check for level vehicle [Re: mickalo] #4449150
07/04/17 08:47 AM
07/04/17 08:47 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I've found the engine is level. I use the coil cover and a bubble level on my 4 cylinders.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: check for level vehicle [Re: mickalo] #4449175
07/04/17 09:08 AM
07/04/17 09:08 AM
Iowa
mickalo Offline OP
mickalo  Offline OP
Iowa
i found Summit Racing makes a dipstick conversion kit for these tranys but runs about $310 not quite in my budget range wink
Re: check for level vehicle [Re: mickalo] #4449230
07/04/17 10:05 AM
07/04/17 10:05 AM
MI
doitmyself Offline
doitmyself  Offline
MI
I am fortunate to have a very level pad to park my vehicle on if I am concerned about needing this for a fluid check. I used a 6 foot carpenter level to check the area. But if taken to the OCD level, which part do you measure level. The engine/transmission might sit cattywompus compared to the other parts of the vehicle. With tires sitting on level ground, the springs might have the body/frame sitting unlevel. Just observations. Gut enuf is fine by me.
I would think that some imaginative use of an inexpensive string level would get you in the ball park, if needed. Either use it on your parking surface/ramps (see link) or find areas on your rocker panel pinch welds to measure vehicle level on both length and width.
http://www.460ford.com/forum/42-general-tech/145052-where-measure-unibody.html
Re: check for level vehicle [Re: mickalo] #4449238
07/04/17 10:11 AM
07/04/17 10:11 AM
Iowa
mickalo Offline OP
mickalo  Offline OP
Iowa
doitmyself that is a nice setup, is that a ford fairlane by chance ??
Re: check for level vehicle [Re: mickalo] #4449254
07/04/17 10:24 AM
07/04/17 10:24 AM
San Antonio, TX
jorton Offline
jorton  Offline
San Antonio, TX
Some vehicles are a little high in back. I have used a torpedo level on top of the battery. Eyeball the battery first.
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Re: check for level vehicle [Re: mickalo] #4449268
07/04/17 10:36 AM
07/04/17 10:36 AM
MI
doitmyself Offline
doitmyself  Offline
MI
Not my pics. Ford Falcon according to the link.
Re: check for level vehicle [Re: Lubener] #4449317
07/04/17 11:22 AM
07/04/17 11:22 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Eyeball.
We call that the "accu-precise eyeball-o-meter"
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: check for level vehicle [Re: mightymousetech] #4449320
07/04/17 11:28 AM
07/04/17 11:28 AM
Iowa
mickalo Offline OP
mickalo  Offline OP
Iowa
Eyeball.
banana
Re: check for level vehicle [Re: mickalo] #4449324
07/04/17 11:32 AM
07/04/17 11:32 AM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
Level means when the vehicle is sitting on its own weight on level ground. So unless the suspension is shot, that's the true level. Various vehicle components/body parts may not be at true level when in this position.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
