1993 K1500 hard cold start
by BrianF. 12/18/18 05:43 PM
Put my wife's dog down yesterday
by Stelth. 12/18/18 05:04 PM
ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
O2 sensor B1S1 no voltage??
by David1. 12/18/18 03:43 PM
Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
115 registered members (53' Stude, -SyN-, ABomb369, 01rangerxl, anndel, 77GrandPrix, 12 invisible), 2,001 guests, and 47 spiders.
Topics295,229
Posts4,930,577
Members66,716
Most Online2,553
Oct 27th, 2018
Nissan 3.5L engine splash shield fasteners.. #4445867
06/30/17 10:06 AM
06/30/17 10:06 AM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
I did the first engine oil change on our new to us 2016 Nissan Quest yesterday. On later model Quests, Murranos and Pathfinders, the oil filter is accessed through the right side fender well, behind a removable panel that's held in place with 4 push plug fasteners. You basically crank the wheels all the way to the right, which gives good access to this area. The OEM plugs have 3 notches in the head that are 120deg apart, so my little push-plug pliers didn't work well, so I wound up using a 90deg pic to pop the heads on the fasteners to release them. One of them shot out on me bouncing around under the car like a pin-ball and I was never able to find it, so the panel is currently held on by 3. Does anyone know the proper size or p/n for replacement plugs? I can find the panels all day long online, but not the hardware. I can pull another plug to use as an example and try Lowes or whatnot, but I thought I'd try here first since that would render the van inop (unless I want to loose the panel entirely) Thanks.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Nissan 3.5L engine splash shield fasteners.. [Re: JTK] #4445878
06/30/17 10:19 AM
06/30/17 10:19 AM
WNY
redhat Offline
redhat  Offline
WNY
Is one of these panels the oil filter panel?
17 Taurus Limited AWD - Dealer Fill of MCSB 5W-20 FL500S, 15k
14 Civic EX Coupe - NAPA Syn 0W-20 TG7317, 64k
09 Accord Sedan 5MT - Traveler 15W-40 XG7317, 151k
87 Regal Limited - 20W-50 VR1 WIX 51042
Re: Nissan 3.5L engine splash shield fasteners.. [Re: JTK] #4445883
06/30/17 10:23 AM
06/30/17 10:23 AM
WNY
redhat Offline
redhat  Offline
WNY
Is this the clip?
Re: Nissan 3.5L engine splash shield fasteners.. [Re: JTK] #4445885
06/30/17 10:24 AM
06/30/17 10:24 AM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
Thanks! It's tough to tell from the diagram, but that 64836 w/ the 6408E's look like it!
Re: Nissan 3.5L engine splash shield fasteners.. [Re: JTK] #4445894
06/30/17 10:37 AM
06/30/17 10:37 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
Those little things usually just take a small flat blade screwdriver to remove. You should be able to take one of your originals to the auto parts store and get a Dorman replacement. They're sold in small packs of maybe 3 or 4.
Re: Nissan 3.5L engine splash shield fasteners.. [Re: JTK] #4445906
06/30/17 10:55 AM
06/30/17 10:55 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Re: Nissan 3.5L engine splash shield fasteners.. [Re: JTK] #4445914
06/30/17 11:01 AM
06/30/17 11:01 AM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
Those definitely look like the ones. I just have to get a few measurements to see if they're standard 20mm head, 10mm shaft and buy some generics, although that price isn't horrible for 25 of them.
Re: Nissan 3.5L engine splash shield fasteners.. [Re: JTK] #4445916
06/30/17 11:03 AM
06/30/17 11:03 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
If you run the Nissan part number through ebay, you'll usually get a better deal.
Re: Nissan 3.5L engine splash shield fasteners.. [Re: Merkava_4] #4445922
06/30/17 11:09 AM
06/30/17 11:09 AM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
^ Yeah, best I'm seeing is $3/ea or more for A/M or Nissan ones.
Re: Nissan 3.5L engine splash shield fasteners.. [Re: JTK] #4445925
06/30/17 11:15 AM
06/30/17 11:15 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Did you measure the hole to see if it's 8mm ?
I usually check ebay for the free shipping.
Re: Nissan 3.5L engine splash shield fasteners.. [Re: JTK] #4445931
06/30/17 11:20 AM
06/30/17 11:20 AM
WNY
redhat Offline
redhat  Offline
WNY
If you're by any chance near Blasdell, I've got a whole bunch of Honda fasteners which I believe are 10mm.
You're welcome to snag a few to see if they work. I get them on eBay. 100ct for around $7-10.
Re: Nissan 3.5L engine splash shield fasteners.. [Re: JTK] #4445933
06/30/17 11:24 AM
06/30/17 11:24 AM
Outer Banks, NC
NormanBuntz Offline
NormanBuntz  Offline
Outer Banks, NC
At least you don't have 18 10mm machine screws to remove the splash shield, like on my wife's Infiniti. The only time I took the car to a Nissan dealer in Florida for an OC, the idiots left off almost half of the screws. So the the genius service manager sent me some of your so called clips. Wrong. He finally sent the proper screws after I bought replacements at Ace Hardware.
Keep a bag of spare clips on hand, even if you have to buy them at a Nissan dealer.
2017 Honda Odyssey SE, 17K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Nissan 3.5L engine splash shield fasteners.. [Re: JTK] #4445944
06/30/17 11:40 AM
06/30/17 11:40 AM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
Yes, even though it's only 4 clips and the small cover is off on these Nissan models, I can see Kwiki-Loobs and dealers screwing it up royally. You have great access to the filter once it's off. Mine looked like it was never touched, but the genuine Nissan filter came off easily by hand and looked really good when I cut it open, so it's had atleast 1-2 oil changes in ~2yrs and 36K miles. It was a rental.
Re: Nissan 3.5L engine splash shield fasteners.. [Re: redhat] #4445947
06/30/17 11:42 AM
06/30/17 11:42 AM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
Thanks brother! I'm just going to grab a measurement and order some.
I just figured/hoped finding someone here that has run into the exact situation would be my best chance.
Re: Nissan 3.5L engine splash shield fasteners.. [Re: JTK] #4445961
06/30/17 12:07 PM
06/30/17 12:07 PM
WNY
redhat Offline
redhat  Offline
WNY
You're welcome!
