Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
2017 Hyundai Tucson burning oil (Help!)
by carviewsonic. 09/23/18 11:09 AM
Never waxed ???
by SilverGt. 09/23/18 10:55 AM
Plumbing drain question
by wormwood1978. 09/23/18 10:38 AM
Post your euro cars high mileage
by Serge. 09/23/18 09:08 AM
Post your cars high mileage
by Serge. 09/23/18 09:01 AM
Post your latest mileage achievement
by Snagglefoot. 09/23/18 08:23 AM
Field repair by the Mississippi!
by Number_35. 09/23/18 08:18 AM
F150 5.0 Lost power
by hatt. 09/23/18 08:15 AM
Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
82 registered members (advocate, Al, bdcardinal, 2013ecof150, 53' Stude, 10 invisible), 1,841 guests, and 37 spiders.
Topics290,892
Posts4,852,039
Members66,047
Most Online3,590
Jan 24th, 2017
OEM gasket and seals or aftermarket? #4445479
06/29/17 10:25 PM
06/29/17 10:25 PM
Caribbean
Nissan101 Offline OP
Caribbean
Goodnight, my valve cover gasket needs changing as it has developed a weeping leak.
An aftermarket gasket seal would cost me $65 while an original nissan gasket is costing me $175. Is it worth paying the $110 more for the oem seal?
Engine is a QG18DE
Nissan N16 -10w30
Nissan S13 -20w50
Royal Purple HPS smile
Re: OEM gasket and seals or aftermarket? [Re: Nissan101] #4445498
06/29/17 10:48 PM
06/29/17 10:48 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
Can you use permatex the right stuff ? That might work instead of a gasket.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: OEM gasket and seals or aftermarket? [Re: Nissan101] #4445503
06/29/17 10:53 PM
06/29/17 10:53 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
If it is just a weep, carefully check the screws for tightness. Who makes the aftermkt gasket? If you get a new VC gasket,does it come with spark plug seals?
Thick oil is better grin2
Re: OEM gasket and seals or aftermarket? [Re: Nissan101] #4445504
06/29/17 10:53 PM
06/29/17 10:53 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
If Fel-Pro makes a gasket for it I'd gladly use that over a more expensive OE gasket. I've installed hundreds and hundreds of their gaskets in repair jobs over the years and several hundred more in rebuilt and race engines over the years. They make a really nice service part. Use with confidence.
Luke
Re: OEM gasket and seals or aftermarket? [Re: andyd] #4445594
06/30/17 01:52 AM
06/30/17 01:52 AM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
First thing to do. They shrink a bit over time from heat cycling and hardening. Sometimes re-torquing will take care of it.
If not, when you do install it, I suggest using gasket dressing. Then tighten them all finger tight before torquing in proper sequence. Then let it set overnight if you can time it, and re-torque the nex day. The gasket will take an initial set and the torque needs to be checked a few times in short order to get a good seal and make a proper repair job. And don't ignore the plug seals as already noted. If not leaking, they will before long if the main gasket is gone.
Re: OEM gasket and seals or aftermarket? [Re: FlyNavyP3] #4445626
06/30/17 05:41 AM
06/30/17 05:41 AM
Warner Robins, GA
nwjones18 Offline
nwjones18  Offline
Warner Robins, GA
+1 Fel-Pro makes good stuff.
1988 F-150. 4.9 I6 247k. 10w-40 Castrol Syn-blend ACDelco UPF2.
2005 Cadillac STS N* 108k. 5w-30 Castrol Magnatec ACDelco Classic PF61
Re: OEM gasket and seals or aftermarket? [Re: Nissan101] #4445716
06/30/17 08:15 AM
06/30/17 08:15 AM
MN
WillsYoda Offline
WillsYoda  Offline
MN
I've used FelPro for valve cover gaskets to good effect. Some things do not need OEM. This is one of them.
Re: OEM gasket and seals or aftermarket? [Re: Nissan101] #4446093
06/30/17 04:27 PM
06/30/17 04:27 PM
USA
slacktide_bitog Offline
USA
Fel-Pro, Victor Reinz, and Beck/Arnley are good brands. Sometimes they are reboxed OEM.
Re: OEM gasket and seals or aftermarket? [Re: Nissan101] #4446095
06/30/17 04:28 PM
06/30/17 04:28 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
+ On Fel-Pro. There is a good chance you will find a OE manufacturer produced gasket (not OE branded) in the box for Asian or Euro cars.
Slacktide had the same thought
Re: OEM gasket and seals or aftermarket? [Re: Nissan101] #4446253
06/30/17 08:26 PM
06/30/17 08:26 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Fel-Pro and Victor both supply OEM manufacturing for new engine production. So is it an OE gasket in a aftermarket box or a Tier one supplier part in an OE application. Chicken or the egg I suppose.
Luke
