Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
25 registered members (DaHen, eljefino, bbhero, 4WD, Char Baby, ArrestMeRedZ, 2 invisible), 775 guests, and 37 spiders.
Topics295,047
Posts4,926,769
Members66,672
Most Online2,553
Oct 27th, 2018
Switch from Royal Purple 10-40 to? #4444408
06/28/17 09:26 PM
06/28/17 09:26 PM
New England
555 Offline OP
555  Offline OP
New England
Running RP 10-40 in my fox-body 5.0 but was considering a switch to Valvoline Max Life for the additive package. Engine builder recommended Kendall dino 10w40 but eventually switched to full synthetic after break in. Car is driven then parked for months at a time. No leaks, no consumption. Engine builder has since passed away years ago(rest in peace Bob Pucel).
Was considering different oil because the engine was rebuilt 16+years ago(aftermarket intake, cam, rockers and of course aluminium heads and aftermarket cats) and oil technology has changed. Cost not a consideration since it doesn't get driven that much(so sad).
Thanks for reading and responding.
84 XJ6 M1
92 Mustang 5.0 Redline
99 Tahoe 2 door Castrol Edge
99 MX5 Miata Anniversary Edition M1
04 Subaru STi Motul
Re: Switch from Royal Purple 10-40 to? [Re: 555] #4444416
06/28/17 09:41 PM
06/28/17 09:41 PM
socal
barkingspider Offline
socal
Maxlife 10w40 will be fine in your application
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Switch from Royal Purple 10-40 to? [Re: 555] #4444425
06/28/17 09:55 PM
06/28/17 09:55 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
many engine builders seem to recommend dino. (mine did) they need to hang out here....
while you certainly should not need synthetic, I would run M1 10w-30; PP; Castrol Edge. of course, I don't know your bearing clearances.... But I would imagine that 10w-30 would provide very good protection.
I'm running VR1 20w-50 dino in my 408 and will switch to VR1 synthetic next oil change - probably frankenbrew it with half 20w-50 and half 10w-30. (my clearances are around .035) my builder used an initial fill of Gibbs; but recommends VR1. its all he stocks: VR1 and Gibbs.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Switch from Royal Purple 10-40 to? [Re: 555] #4444437
06/28/17 10:13 PM
06/28/17 10:13 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
RP (at least the Synerlec/HPS/XPR versions) would have a superior add pack to Valvoline.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 5W20
Re: Switch from Royal Purple 10-40 to? [Re: 555] #4444442
06/28/17 10:22 PM
06/28/17 10:22 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
I would agree that Valvoline is really nothing special. just using it for the first year for "warranty". after that I will likely go M1 or Amsoil.
Re: Switch from Royal Purple 10-40 to? [Re: 555] #4444469
06/28/17 11:28 PM
06/28/17 11:28 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have had EXCELLENT results keeping a turbo 5.0 alive with just 15W-40 HDEO.
Re: Switch from Royal Purple 10-40 to? [Re: 555] #4444618
06/29/17 07:17 AM
06/29/17 07:17 AM
NorCal
Seventh Offline
Seventh  Offline
NorCal
I've always run 30wt oils in my full roller 331 stroker in my old ford truck with success. Same 302 engine platform. I won't bother listing all the specs but it's got a very lopey cam and high compression. Just shy of 400 horse.
Oil pressure gauge never shows me anything scary, even after running her real hard for an hour plus. Lowest I've ever seen is 25psi at idle in gear, after some serious flogging.
I fill the sump with 4qts of T5 10w30 and one quart M1 racing 0w30 to give the aw additive levels a kick in the pants. Doesn't burn any oil at all.
Re: Switch from Royal Purple 10-40 to? [Re: 555] #4444703
06/29/17 08:20 AM
06/29/17 08:20 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Why are you wanting to switch oils?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Switch from Royal Purple 10-40 to? [Re: 555] #4444868
06/29/17 10:48 AM
06/29/17 10:48 AM
CBUS OH
BironDanmum Offline
BironDanmum  Offline
CBUS OH
If price isn't an issue stick with the Royal Purple. If you want to get away from synthetics go with Brad Penn. Either one of those would be a better choice than the Valvoline for your application.
Re: Switch from Royal Purple 10-40 to? [Re: 555] #4444879
06/29/17 10:53 AM
06/29/17 10:53 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
I'd stick with Royal Purple, but move to the HPS line. Much healthier additive package. V8s don't need anything terribly special like a high-pressure turbo 4 cylinder would.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: Switch from Royal Purple 10-40 to? [Re: 555] #4445359
06/29/17 07:35 PM
06/29/17 07:35 PM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
Read this: Amsoil Z-rod 10W-30
I know some guys with classic cars/hot rods that like it for their modified engines, and it has special anti-corrosion additives for cars that sit a lot as well.
Or, buy a 5 qt. jug of M1 HM 10W-30 or 10W-40 and throw a can of Liqui Moly MOS2 (German-made quality stuff) in there for extra anti-wear. I get these cans 6 at a time on amazon for less than $6 each, free shipping. Just keep in mind this additive gives your new oil a grayish tint, as it goes in very dark gray out of the can. I have been using this stuff on nearly every oil change for some time. I typically go 1 year or 10,000 miles on this oil/additive combo with a long life filter (15,000 mile-rated), but went 16,000 miles one time and engine still spotless inside. This was with the M1 HM 5W-20 on the wife's daily driver Honda minivan.
For less yearly miles, the Maxlife 10W-30 or 10W-40 would surely do the job just fine, but me personally, I would still add the can of moly.
Re: Switch from Royal Purple 10-40 to? [Re: 555] #4445376
06/29/17 07:57 PM
06/29/17 07:57 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
You don't give the year for the 5.0 ...
But I'm guessing it's a roller cam? If not, be careful ... You need 1,000 PPM Zn and Ph.
If roller cam you are good to go on most modern oils smile
You could run it fine on Rotella T6, or similar smile
Re: Switch from Royal Purple 10-40 to? [Re: 555] #4445525
06/29/17 10:26 PM
06/29/17 10:26 PM
midland tx
askani79705 Offline
askani79705  Offline
midland tx
As suggested earlier a good HDEO will do the trick.
2017 Ford F150 NAPA syn 5w30 Fram 11955.
2000 Chevy 2500 Silverado NAPA conv 5w30 AC Delco Filter
2012 Impala Pennzoil Ultra 10w30 AC Delco Filter
Re: Switch from Royal Purple 10-40 to? [Re: CT8] #4445695
06/30/17 06:53 AM
06/30/17 06:53 AM
New England
555 Offline OP
555  Offline OP
New England
Just curious if there was something better for this application.
84 XJ6 M1
04 Subaru STi Motul
Re: Switch from Royal Purple 10-40 to? [Re: BrocLuno] #4445698
06/30/17 06:54 AM
06/30/17 06:54 AM
New England
555 Offline OP
555  Offline OP
New England
Thanks for the responses. I will stick with Royal Purple,
84 XJ6 M1
04 Subaru STi Motul
