Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
103 registered members (3Aone, 69GTX, 10ecfarmer, 16 invisible), 1,727 guests, and 34 spiders.
Topics290,906
Posts4,852,275
Members66,047
Most Online3,590
Jan 24th, 2017
55gallons of m1 #4440901
06/25/17 08:29 AM
06/25/17 08:29 AM
Sav ga
NStuart Offline OP
NStuart  Offline OP
Sav ga
I have access to a 10 year old 55 gallon drum of m1. 0w? I think its 0w50 , I want to say the drum says HTC or something I will have to look again.
Any concern for additive drop out, other than rolling the drum or flipping it mixing the bottom would prove difficult
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: 55gallons of m1 [Re: NStuart] #4440915
06/25/17 08:45 AM
06/25/17 08:45 AM
Bad Axe, MI
daman Offline
daman  Offline
Bad Axe, MI
Yes you will most likely have additive fall out I've seen it, some how you need to mix that barrel, that's why I don't like getting oil form a large container like that. Check on line I think they make barrel mixers for 55's
"Always"....Mobil 1
Current fill: AFE 0w30
Re: 55gallons of m1 [Re: NStuart] #4440916
06/25/17 08:46 AM
06/25/17 08:46 AM
Great Lakes
Quattro Pete Offline
Great Lakes
What are you going to use it in?
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (FF)
Re: 55gallons of m1 [Re: NStuart] #4440926
06/25/17 08:58 AM
06/25/17 08:58 AM
The Midwest
skyactiv Online content
skyactiv  Online Content
The Midwest
Forget about it. Do yourself a favor and avoid the physical and mental drama this will turn into.
Me: 13' VW GTI 3 door 6 speed manual
Re: 55gallons of m1 [Re: NStuart] #4440936
06/25/17 09:06 AM
06/25/17 09:06 AM
OH
fdcg27 Online content
fdcg27  Online Content
OH
Have another look at the labeling on that drum.
HTC is a Schaeffer's product while SHC is a Mobil one.
Neither is suitable nor intended for IC engine use.
There is an M1R 0W-50 that is specifically not recommended for street use, although the PDS doesn't give enough detail to determine why this might be the case. SAPS is 1.3% and the verbiage indicates high levels of anti-wear protection which might be code for lots of ZDDP. HTHS is listed as 3.8, so not frighteningly high.
IIRC, there is an M1 0W-50 PCMO available in other markets but I've never seen it here.
Finally, unless you have a real need for a really thick oil, the only reason to buy this drum would be if it were a steal, like $300.00 or less. You can get M1 in jugs for less than two bucks a quart AMIR at least a couple of times each year and the 55 gal container isn't exactly a convenient package size to handle.
17 Forester 18K VME 0W-20
12 Accord LX 92K PP 5W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: 55gallons of m1 [Re: skyactiv] #4440946
06/25/17 09:26 AM
06/25/17 09:26 AM
Michigan
Greggy_D Online content
Greggy_D  Online Content
Michigan
Amen.
Greggy D.
Re: 55gallons of m1 [Re: NStuart] #4440950
06/25/17 09:34 AM
06/25/17 09:34 AM
Michigan born but my heart bel...
JR Offline
JR  Offline
roll the barrel, and start using.
-harvey
97 F250HD 7.3 320K 01 Astro 220K
93 metroXFi 94.5K
01 Impala 300K
04 RTV900R 1150hrs
Re: 55gallons of m1 [Re: NStuart] #4440955
06/25/17 09:42 AM
06/25/17 09:42 AM
Sav ga
NStuart Offline OP
NStuart  Offline OP
Sav ga
It would be free, I will get more info off of it, a friend of mine seems to think it says something about Canada on it, I'll try to get more info ASAP
08 husky sm610 t6
Re: 55gallons of m1 [Re: NStuart] #4440974
06/25/17 10:13 AM
06/25/17 10:13 AM
FL
mcrn Offline
mcrn  Offline
FL
you could always send in a virgin oil sample to test and see what the additives are like.
2012 Nissan Rogue
Re: 55gallons of m1 [Re: NStuart] #4440997
06/25/17 10:38 AM
06/25/17 10:38 AM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
It's FREEEEEEEEEEE!!!! YaYY!!
Just check to make sure no water on the bottom.
Re: 55gallons of m1 [Re: mcrn] #4441025
06/25/17 11:10 AM
06/25/17 11:10 AM
Connecticut
69GTX Online content
69GTX  Online Content
Connecticut
Not if some of them are stuck to the bottom.
I had a 20 yr old bottle of M1 15w-50 out on the garage. After using most of if it for a flushing oil, I noticed a big pile of chunky, dark deposits on the bottom. Those didn't come no matter how hard or long I shook the bottle. I finally got a 12" long file with a pointy end and started poking at the stuff. It was still very hard to get off. Took about 10 min of playing with it to get most of the chunks broke free....though no idea if they dissolved. If you're trying to do this with a 55 gall drum, good luck.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: 55gallons of m1 [Re: 69GTX] #4441062
06/25/17 12:07 PM
06/25/17 12:07 PM
FL
mcrn Offline
mcrn  Offline
FL
Ok maybe I did not get my point across correctly......he could get a virgin oil analysis to see what was suspended still in the oil.
2012 Nissan Rogue
Re: 55gallons of m1 [Re: mcrn] #4441156
06/25/17 02:02 PM
06/25/17 02:02 PM
OH
OH
Exactly.
55 gallons of free oil is worth a $20.00 VOA to show what's in it and whether it would be suitable for use, not what's stuck to the bottom of the drum.
95 318i
Re: 55gallons of m1 [Re: 69GTX] #4441162
06/25/17 02:08 PM
06/25/17 02:08 PM
Waco, TX
Waco, TX
Those didn't come no matter how hard or long I shook the bottle. Took about 10 min of playing with it to get most of the chunks broke free....though no idea if they dissolved.
Amazing..... I have never experienced anything similar with jug of new oil. No matter how long they sat....
and even then, the amount of the bottom was just a "trace".
Re: 55gallons of m1 [Re: Linctex] #4441398
06/25/17 06:57 PM
06/25/17 06:57 PM
OH
OH
I haven't seen this either and I have a stash of more than 300 qts and have maintained one for years, long before I came here.
Sonofjoe has posted that the sludge on the bottom is probably moly which he has written has poor solubility.
It may be that better oils have less problem with additives falling out of suspension, or it may be that low or no moly oils don't show additive fallout.
95 318i
