Best recommendation for Honda 10w30 trans
by Pepsibottle1
06/25/18 01:55 PM
Mills Fleet Farm Roadrunner batteries - who makes?
by volk06
06/25/18 01:09 PM
Honda ATF DW1 bottle stamp decoding
by parshisa
06/25/18 12:03 PM
How to lower throttle sensitivity?
by NICAT
06/25/18 11:41 AM
That's some service! (New Central AC...)
by xBa380
06/25/18 11:13 AM
Valvoline 2 Cycle TC-W3 Marine Oil - 6qt - $20
by Jimzz
06/25/18 10:45 AM
Plumbing/Bldg Experts: Cause of Wet Slab?
by LoneRanger
06/25/18 10:13 AM
How to CONFIRM the Country of Manufacture
by Ed_Flecko
06/25/18 09:58 AM
Replacing trans oil seal
by redhat
06/25/18 09:50 AM
VW diesels sitting in huge lots waiting......
by ZZman
06/25/18 09:09 AM
DTD/DT Independence Day Promos
by Sayjac
06/25/18 08:39 AM
It's AMSOILŪ, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
84 registered (853okg, 28oz, 9050lx, 4WD, AndyB, 8 invisible), 1738 Guests and 41 Spiders online.
65319 Members
67 Forums
285970 Topics
Page 1 of 2 1 2 >
#4440361 - 06/24/17 02:19 PM Fix for tail pipe cancer?
Oro_O Offline
Loc: Seattle-ish, WA
When doing my biennial brake fluid flush, I was surprised to find a hole developed where the tailpipe joins the muffler body. I am under the car much more frequently than very two years doing maintenance or inspections, but I never noticed this developing to this degree before. The rest of the exhaust from the header back is pretty darn clean. This is an 02 Lexus ES. In our climate, rust is a non-issue and this is the only spot. Seems like an obvious condensation trap there.
I have searched quite a bit on exhaust repair techniques but I can't find something I see working in that angle. The material around the hole itself is brittle and you can poke it and flake it away. I imagine it would need to be a putty or paste of some type initially to form and adhere. Also, the pipe is quite corroded and I think if I used a wire brush on a drill to clean it up it might erode it away.
So I was wondering if there was an inexpensive way to patch it that would last vs buying a new one? If a patch would only last a year or two, it's certainly not worth the effort vs. replacing it.
#4440363 - 06/24/17 02:22 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
Ethan1 Offline
Loc: 'murica
You can't weld to rusty metal so, no, there isn't a halfway fix.
#4440367 - 06/24/17 02:29 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
SatinSilver Offline
Loc: OH
You can call some area muffler shops and ask them how much for a new muffler with tailpipe installed. Then ask what brand they use. Should be around $120-160. You can wait till it starts to get louder, may last another year or so.
Edited by SatinSilver (06/24/17 02:29 PM)
#4440372 - 06/24/17 02:38 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
PeterPolyol Offline
Loc: toronto
Side note: always make sure your mufflers have a clear open condensation drain hole.
#4440376 - 06/24/17 02:44 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
Oro_O Offline
So if the replacement doesn't have one, should I drill one? (drain hole).
Between Bosal and Walker, which appear to be the two widely available choices, is one superior to the other?
I see that I can get one or the other for about $150 and I can install it.
#4440377 - 06/24/17 02:44 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
CT8 Offline
Loc: Idaho
See what a factory replacement pipe costs before doing anything.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4440385 - 06/24/17 02:59 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
PeterPolyol Offline
Loc: toronto
Definitely worth it to drill one if it lacks it.
#4440402 - 06/24/17 03:27 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
Chris142 Offline
Loc: Deplorable in apple valley, ca
exhaust work is one thing I will not do. Rust in your eye,dirty etc to save $35
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4440403 - 06/24/17 03:27 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
SumpChump Offline
Loc: Upper Midwest by the Lakes USA
Heck, here in Wi that would be listed as "newer exhaust" on Craigslist. Looks clean by our standards.
#4440405 - 06/24/17 03:30 PM Re: Fix for tail pipe cancer? [Re: CT8]
Oro_O Offline
They were $360+ shipping at the best price I could find. A super-clean take-off from a Texas or other dry-region wreck is not unacceptable to me. I will also shop for one, now realizing I can drill a drain and make it last longer. This is the only muffler I've had to replace on any vehicle living in the PNW given the mild climate/no salt. Even though it has high mileage, it runs great and looks good. Probably the car will stay around in use and then go to a child in three years when they start driving.
#4440420 - 06/24/17 03:45 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
Donald Offline
Loc: Upstate NY
A local guy near me welds stainless pipe and not much more than steel pipe.
2015 Ford F250 w/Powerstroke
#4440449 - 06/24/17 04:37 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
BrocLuno Offline
Loc: Kalifornia Kollective
Looks like aluminized muffler (good) but plain steel pipe (bad) ... Make sure the new one is aluminized all the way back smile
#4440499 - 06/24/17 05:49 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
Lubener Offline
Loc: N.Ohio
Get the sawsall out cut out and replace muffler and tail pipe. Any less is a temporary rig job.
The "thinking" man's friend.
#4440521 - 06/24/17 06:32 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
slacktide_bitog Offline
Loc: USA
Get a Walker Quietflow muffler. It's stainless and has a lifetime warranty smile
#4440536 - 06/24/17 06:59 PM Re: Fix for tail pipe cancer? [Re: Oro_O]
Driz Offline
Loc: northern NY
No fixin a muffler like that, it's where most fall apart. Check Rock Auto. Great prices just make sure everything comes from the same warehouse or shipping stacks up.
Page 1 of 2 1 2 >
