I'm approaching 45k and five years in a '12 Avalon, "sealed trans".
Debating using the WS from Toyota vs. Redline D6.
Friend has an exchange machine, so only the leveling at correct temperature will be the task.
He is a retired Toyota tech, so the work will be straightforward. So he tells me.
My hesitation on the D6 is different thermal properties giving a false full reading. The two fluids may not expand at the same rate or temp.
Worth the worry?
Worth the worry?
