Best recommendation for Honda 10w30 trans
by Pepsibottle1
37 minutes 17 seconds ago
Mills Fleet Farm Roadrunner batteries - who makes?
by volk06
Today at 01:09 PM
Honda ATF DW1 bottle stamp decoding
by parshisa
Today at 12:03 PM
How to lower throttle sensitivity?
by NICAT
Today at 11:41 AM
That's some service! (New Central AC...)
by xBa380
Today at 11:13 AM
Valvoline 2 Cycle TC-W3 Marine Oil - 6qt - $20
by Jimzz
Today at 10:45 AM
Plumbing/Bldg Experts: Cause of Wet Slab?
by LoneRanger
Today at 10:13 AM
How to CONFIRM the Country of Manufacture
by Ed_Flecko
Today at 09:58 AM
Replacing trans oil seal
by redhat
Today at 09:50 AM
VW diesels sitting in huge lots waiting......
by ZZman
Today at 09:09 AM
DTD/DT Independence Day Promos
by Sayjac
Today at 08:39 AM
It's AMSOIL®, not Amsoil
by Rat407
Today at 06:39 AM
VW Passat 2007
by madRiver
Today at 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
Today at 03:40 AM
Towing without 85w140?
by OilFilters
Today at 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
Yesterday at 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
Yesterday at 11:13 PM
Darn dogs
by AZjeff
Yesterday at 10:21 PM
New GC?
by Bullwinkle007
Yesterday at 10:04 PM
The guy with the plexiglass head on you tube
by andyd
Yesterday at 09:21 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
93 registered (28oz, 4WD, bbhero, 853okg, AndyB, badtlc, 11 invisible), 1718 Guests and 36 Spiders online.
65319 Members
67 Forums
285971 Topics
Page 1 of 2 1 2 >
#4389454 - 04/26/17 01:36 PM 'Broad Spectrum' ATF, how does it work?
MoneyJohn Offline
Loc: Southern NY
Hello folks,
I don't understand ATF chemistry so apologies in advance if this is a stupid question.
I plan to drain ATF in my 2006 Sentra for the first time, with ~103,000 miles on it. Although the fluid is still red/pink, I have never changed it nor do I remember paying for the change. So as an insurance, I am planning to drain.
I am toying between the use of Nissan Matic-D type ATF or aftermarket. Many are suggesting Valvoline Max Life ATF. Found the following link on another thread about its compatibility. This fluid is compatible with all Nissan fluids, in addition to other brands. What I don't understand how one fluid can be compatible with all of these? I assume they are named differently because they ARE different, right?
Any clarification in this regard is welcome. Thanks in advance.
2015 Subaru Forester 2.5i Premium w/ EyeSight
2006 Nissan Sentra 1.8S Special Edition
#4389474 - 04/26/17 02:03 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: MoneyJohn]
slacktide_bitog Offline
Loc: USA
they're similar enough for it to be possible to make a fluid that meets all of them smile
#4389480 - 04/26/17 02:14 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: MoneyJohn]
OneEyeJack Offline
Loc: S California
Transmissions are very expensive. Be careful with your choice, very careful. Take the time to do exactly what you're doing, research, ask and if there is any doubt after all this then default toward a fluid that is made specifically for your vehicle instead of a one size fits many.
I use Red Line D4 in my 2003 4Runner. I periodically drain the pan (usually 4 quarts) and replace it with new D4. I have a bit over 160K miles with a lot of dirt roads and towing and so far, so good.
Your query has got me thinking that maybe I'll send in a sample to see how things are going. I'll post the results. Thanks for the reminder.
#4389498 - 04/26/17 02:27 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: MoneyJohn]
28oz Online   content
Loc: Utah, USA
I'll take this opportunity to make my first post (yay!) and chime in. Just this weekend, I switched my 2004 Nissan Quest over to Maxlife ATF from Matic-D. The sloppy 1st to 2nd shift appears to have completely smoothed over (now at 142,000 miles). If you have any concern, stay with the Matic-D, but many have had great results with Maxlife ATF. As to how they meet many different specs, I couldn't tell you. I'm not that well versed on the chemical compositions. Generally, I would tend to argue stay with a specific fluid that is spec'd for the application and not a universal type. In my case, however, the spec'd Matic-D fluid just wasn't cutting it and was a lot more expensive. Good luck with whatever you decide!
1990 Nissan 300zx - Castrol Edge Euro 0W-40
2004 Nissan Quest - Pennzoil Platinum Euro 0W-40
2003 Ford Excursion 7.3 PSD - Mobil 1 TDT 5w-40
#4389514 - 04/26/17 02:41 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: MoneyJohn]
RichardS Offline
Loc: Melbourne, Florida
What a really good question!
I've always wondered the same, and just figured it was because they were similar enough that you could meet each of the specs well enough to be functional.
You bring up a good point though, are we losing something extra on one spec to meet a minimum requirement of another?
Tagging along.
2008 Dodge Caliber SE 2.0 117k
4qt Imeditsu 0w-20, 1/2qt Mobil SS 5w-20 Fram HM
2003 Buick Century 107k
4.5q Havoline 5w-30 HM Fram XG
#4389548 - 04/26/17 03:12 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: 28oz]
MoneyJohn Offline
Loc: Southern NY
I didn't mention in the OP, but my car jerks between 1st to 2nd shift every time whether I accelerate gently or not. The jerk is like whole car jerks, only once and then it smoothens. Lately, a subtle jerk started between 2nd to 3rd. Can you explain your sloppy shift? Was it the same feeling?
FWIW, I never take this car on highways because it rattles beyond 60mph, it always did (bought pre-owned at 72,000 on the odometer). I thought that's the pleasure of buying an econobox.
Edited by MoneyJohn (04/26/17 03:13 PM)
#4389588 - 04/26/17 03:48 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: MoneyJohn]
28oz Online   content
Loc: Utah, USA
Yeah, it wasn't every time either. Sometimes it was a jerk, and other times, I'd describe it more of a stumble......like it just didn't know what to do. A couple gallons of Maxlife shouldn't be prohibitively expensive to try out. If it doesn't work, drain it and put Matic-D back in. IMO, it's worth a try. It sure helped mine.
#4389627 - 04/26/17 04:30 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: MoneyJohn]
dubber09 Offline
Loc: Vancouver, Canada
Cannot answer original question but I changed Kia FF ATF on 2014 Forte at 30K miles to MaxLife and shifting improved (silky smooth now) quite noticeably.
#4389779 - 04/26/17 06:59 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: MoneyJohn]
SoNic67 Offline
Loc: VA, US
And new fluid will smooth the shifting when compared to the worn fluid that you replace.
#4389923 - 04/26/17 09:21 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: MoneyJohn]
MolaKule Offline
Loc: Iowegia - USA
NissanMatic S replaces NissanMatic D in most applications, except for the Nissan Transfer Cases which still specify NissanMatic S, or Dex/Merc.
The secret of Multi-Vehicle ATF's such as MaxLife or D4 or D6 or Amsoil ATF's is the mix of specialized friction modifier chemistry's which cover a spectrum of dynamic friction coefficients.
#4390500 - 04/27/17 03:05 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: MoneyJohn]
Jetronic Offline
Loc: down in the park
We're using Castrol ATF Multivehicle at my work. We're pretty much exclusively working on Hyundai or Mitsubishi transmissions though.
Keeping one engine oil, one ATF, one MT oil and one two differential oils in stock only, suitable for all vehicles we service, avoids mistakes. We have one LS diff oil, and one non-LS.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
#4390806 - 04/27/17 09:41 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: MolaKule]
MolaKule Offline
Loc: Iowegia - USA
Whoops, should have said:
NissanMatic S replaces NissanMatic D in most applications, except for the Nissan Transfer Cases which still specify NissanMatic D, or Dex/Merc.
#4468106 - 07/23/17 03:12 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: slacktide_bitog]
Linctex Offline
Loc: Waco, TX
Except..... Mercon V
#4468128 - 07/23/17 03:44 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: MoneyJohn]
MolaKule Offline
Loc: Iowegia - USA
Valvoline MaxLife labeling indicates MerconV coverage except in California which took issue with the viscosity requirement but which PQIA accepted a statement indicating Valvoline's line of reasoning.
Quote:
*Please note that legislation in California prohibits Valvoline from recommending MaxLife™ ATF in certain applications where the viscometrics of MaxLife™ ATF do not match those of the official OEM specification. Valvoline therefore does not recommend the use of MaxLife™ ATF in these applications in California.
Of course we are aware of California's pendent for Overregulation.
Edited by MolaKule (07/23/17 03:48 PM)
#4468453 - 07/23/17 09:41 PM Re: 'Broad Spectrum' ATF, how does it work? [Re: MoneyJohn]
mclasser Offline
Loc: The Northeast
Matic-D is nothing to write home about. With Matic-D in my Infiniti, I found the shifting would get sloppy 15k miles after a D&F. I switched to MaxLife and haven't looked back since.
ML & LG Red ftw!
2018 Hyundai Elantra VE -- 3K
2013 Honda Pilot EX-L 4WD -- 55K
2002 Honda Accord EX-L -- 210K
Page 1 of 2 1 2 >
