Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
5w30 vs 5w40 Mercedes E220 BLUETEC
by Costas00. 01/17/19 09:56 AM
Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
119 registered members (anndel, Andy636, addyguy, aquariuscsm, 28oz, AandPDan, 13 invisible), 2,179 guests, and 49 spiders.
Topics296,731
Posts4,957,830
Members66,960
Most Online2,577
Jan 14th, 2019
JCB Mini Excavator 8018 CTS Perkins 403D-11 Engine #4381708
04/17/17 01:01 PM
04/17/17 01:01 PM
NJ
cloves Offline OP
cloves  Offline OP
NJ
Hi all,
Hoping I could get some guidance on oil. I have a JCB mini excavator with a Perkins 403D-11 Diesel Engine. Machine has a little less then 1000 hours on it currently. Don't really know how regularly the oil on the machine was done. Just purchased the machine and the oil and filter were serviced. The engine runs but it vibrates a lot imo at the low idle settings. I checked the motor mounts and they all seem attached. I gasoline engine diy'er and not 100% if is just be being paranoid or diesel engines just tend to run like this. A few times I notice a little bit of white smoke when the engine is running but the last day it had cleared up. So not sure if the machine just hasn't been worked hard and might be some glazing on the cylinders. I am watching my coolant to make sure its not a leak. So I am now thinking should I try to switch to a synthetic see if that helps clean out any old deposits, or could that lead to a worsening situation.
Ok so the specs on oil. I would like to do another oil change on the machine and switch i over to Synthetic oil. I was thinking about Rotella T-6 15w-40. I am located in the North NJ.
Manual shows this "Engine (Oil) lists 2 JCB 10W/30 Multigrade (above -15C (above 5F)) MIL-L-46152, API CC/SF & 5W/20 (-15C to -25C (5F to 13F)) API CC/SE (recommended).
Now on the forums I am reading that Rotella has recently switched specs so I am totally confused! Is it a smart idea to switch over to T-6 or should I stick with T4 or T5?
Re: JCB Mini Excavator 8018 CTS Perkins 403D-11 Engine [Re: cloves] #4381949
04/17/17 06:32 PM
04/17/17 06:32 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Any HDEO 5w-40, 15W-40 or straight 30 in the summer will be fine.
The oil isn't your issue -
the white smoke & roughness means the injectors need to be cleaned, or the fuel is really old.
Re: JCB Mini Excavator 8018 CTS Perkins 403D-11 Engine [Re: cloves] #4381951
04/17/17 06:34 PM
04/17/17 06:34 PM
Waco, TX
Waco, TX
A diesel engine with only 1000 hours will typically have have NO "deposits" to clean out. NONE.
It's not at all like a gas engine in that regard.
I have worked on 100's of diesels and never seen "deposits" inside like you see in gas engine.
Re: JCB Mini Excavator 8018 CTS Perkins 403D-11 Engine [Re: cloves] #4381952
04/17/17 06:35 PM
04/17/17 06:35 PM
Waco, TX
Waco, TX
What year is your machine? If it's before 2007, you need to add a little lube to the fuel.
Re: JCB Mini Excavator 8018 CTS Perkins 403D-11 Engine [Re: cloves] #4483210
08/08/17 10:35 PM
08/08/17 10:35 PM
NJ
cloves Offline OP
cloves  Offline OP
NJ
Hi @Linctex, I guess the forum isn't emailing to let me know I got response.
Anyways the machine is a 2014. I was talking to a guy who works on the JCB machines and he was telling me he had one machine that was having the same issues as mine and said he changed the glow plugs and the fuel injection pump, and that cleared up the rough idle.
Linctex, any recommendations for what I could try to clean up the injectors?
