DEX/Merc for customer "Y"
MolaKule
Staff member
Iowegia - USA
Developed for a customer who wanted to market a full synthetic DEX/MERC formulation.
(elements less than 3 ppm not reported; ppm values were rounded)
BORON - 120
SODIUM - 3
CALCIUM - 28
PHOSPHORUS - 240
ZINC - 3
VIS@100C 7.24
FP - 425
VI - 180
Not seen of course is the dual anti-oxidant, rust and corrosion inhibitors, FM's, and VII which is in a very low treatment level.
Dispersant is an ashless dispersant.
Good for a 35k OCI in most daily drivers for those who wishing to use a DEX/MERC in older vehicles.
Understood. What is your opinion of using air compressor oil or universal tractor oil in a non-electronic transmission applicsyion? I'm looking for FP benefit in a drag racing application. Clutch material is Alto Red Eagle. Specifically in a TH350 if your familiar with it.
What's the point of a full syn that's good for only 35k OCIs? Is that intended to be under extreme heat and towing/shear?
Is this to imply that the "D/M" (since dex is no longer licensed to earlier variants than VI) that can be had OTS may not be true to the intent of Dex IIIH and similar add packs in their licensing days?
Oh yes, good racing transmission.
I would not use either of the above fluids because they do not contain the correct additive packages nor are their viscosities correct.
I would use a Type "F" such as Amsoil's "Power Shift" or Redline's LV Racing Fluid
https://www.redlineoil.com/product.aspx?pid=137&pcid=9.
It is to be marketed as a HM or heavy duty replacement for older trannies speced for DexronIII/Mercon, and for those owners who don't want to use a low viscosity fluid such as Dex VI in those older vehicles.
I don't do the marketing but the 35k suggested OCI is probably a CYA type of thing.
The additive package contains the shear stable FMs, anti-oxidants, and VII type of package.
It is my personal opinion that Dexron III(H) and prior fluids weren't to be left in for more than 40k because they sheared down to about 4.75 cSt within 20k miles.
Here is a good reference for TH350's:
TH350
Would you please stop teasing us. I'm dying have a sticker in the engine bay stating: "Designed by Mola, made in America!"
Shearing of ATF is not unlike shearing in engine oil; it may or may not have any negative affect.
I've seen about two hundred UOAs from the Allison 1000 series in GM light-duty trucks. There are guys that get away with running the old DexIIIh conventional fluids for up to 50k miles; some even more. Shears badly into the low 4s. But the wear metals never seem to be affected much by the sheared fluid. Conversely, I've seen TES-295 fluids hold their vis incredibly well, and still show about the same wear. My conclusion is that the Alli 1000, not unlike the Dmax engine sitting ahead of it, really does not care about brand/grade/base-stock.
I ran a UOA of my wife's old Villager ATF using a house-brand D/M fluid; after 30k miles it was a bit thin, but the wear was great and I extended out to 50k miles from there on out. That trans (a Nissan unit) was just a good wearing piece.
Certainly there are trannies that are sensitive to vis and need a good thick lube.
As with most things, it depends upon the application and use. Shearing of ATF may or may not have a consequence. If the equipment is well designed and has a good lube system, the small variations in lube characteristics won't matter. If the equipment has a weakness, then I think fluids matter much more.
Originally Posted By: dnewton3
...Certainly there are trannies that are sensitive to vis and need a good thick lube.
Absolutely.
My main concern is with light duty transmissions that have steel pin bearings and plain (journal) bearings made with CDA 954/SAE 660 copper-alloy materials. There are still a few of the latter used in current AT designs.
Fluid film thickness is a major concern when temps get high, as many drivers may pull loads far beyond the intended design of the transmission.
AT Heat Study
I am not so concerned with the larger roller bearings and ball bearings as they are usually over specified with respect to the intended radial loads.
Another component often overlooked is the simple thrust washer with respect to fluid film thickness verses temps and wear.
thanks Mola an interesting read for sure. we all appreciate info from a pro such as yourself!!
